decoding IPs in DB
PeterK2003
decoding IPs in DB
Post by PeterK2003 » 2010-05-18 17:22
i used to decode the IP in the DB like so: inet_ntoa(`hm_greylisting_triplets`.`glipaddress1`) AS `IP'
Somewhere along the line that broke...i guessing IPv6 support
how can i decode them now?
Thanks,
Peter
Re: decoding IPs in DB
Post by ^DooM^ » 2010-05-18 18:03
IP's were stored as LONG. I'm not sure how IPV6 IP's are stored. can you post a few IP's from your table in their current format?
PeterK2003
Post by PeterK2003 » 2010-05-18 18:06
'1652667516' decoded with above method '39382e3132392e3138302e313234'
PeterK2003
Post by PeterK2003 » 2010-05-18 18:07
and it is a bigint
Post by ^DooM^ » 2010-05-18 18:23
hmm i see what you mean.
First one is 98.129.180.124
Second one i get back as an error using long2ip
inet_ntop is supposed to replace ip2long in PHP but is PHP5 only.
PeterK2003
Post by PeterK2003 » 2010-05-18 18:28
Just to make sure we are on the same page
if i do:
inet_ntoa(1652667516)
it returns
i am using the inet_ntoa function in mySQL not PHP
dzekas
Post by dzekas » 2010-05-18 18:39
PeterK2003
Post by PeterK2003 » 2010-05-18 18:51
is that what is going on though? I was just speculating that it had to do with ipv6.
Post by ^DooM^ » 2010-05-18 19:35
1652667516 = 98.129.180.124 using php's long2ip();
Perhaps dzekas's link will shed more light.
dzekas
Post by dzekas » 2010-05-18 19:39
PeterK2003 wrote:is that what is going on though? I was just speculating that it had to do with ipv6.
You speculated that it is ipv6 and I searched for inet_ntoa and ipv6 support in mysql. Result - that bug report. But '39382e3132392e3138302e313234' is not ipv6 address. It is hexadecimal representation of '98.129.180.124'
<?php
$str = '39382e3132392e3138302e313234';
$length = strlen($str);
for($i=0;$i<=$length;$i=$i+2) {
   echo chr(hexdec($str[$i] . $str[$i+1]));
I have other link for you. http://ronaldbradford.com/blog/tag/inet_ntoa/
PeterK2003
Post by PeterK2003 » 2010-05-18 19:50
ohhh that looks like what is going on...guess a bug in mysql then.
Interesting.....
dzekas
Post by dzekas » 2010-05-18 19:54
PeterK2003 wrote:ohhh that looks like what is going on...guess a bug in mysql then.
Interesting.....
Blog talks about quirk in mysql odbc and not in mysql itself. You have whole chain of programs. Check how address is stored in mysql database and do inet_ntoa queries in mysql client console. not in some program through odbc or some other library.
PeterK2003
Post by PeterK2003 » 2010-05-18 20:37
cast(inet_ntoa(`hm_greylisting_triplets`.`glipaddress1`) as char) AS `IP`
^^^^that works
