aschoenf
- New user
Post
by aschoenf » 2010-03-12 10:16
I have yet another strange problem (don't know if it comes from the hMailServer).
I'm sending out ~13.000 newsletters for a customer with an ASP.net Webservice, but it always stops arround 1.300 mails (+/-100).
Now my question:
Is there any limit like max. messages (don't think so because of the difference) or time limit for an SMTP session?
Thanks in advance
Best regards,
Alex
- Site Admin
Post
by ^DooM^ » 2010-03-12 12:01
No to both your questions. More likely your web asp script is timing out.
Tezcatlipoca
- Senior user
Post
by Tezcatlipoca » 2010-03-12 13:09
A word of caution here. If you're sending out mass mails you might risk getting yourself placed on a spam blacklist, especially if you have a static IP address.
If this is a regular thing, I'd suggest finding alternatives for your mass mails. The company I work for, for example, does its mass mailing via a DotMailer account, specifically so our public IPs, which handle our emails amongst other things, don't get listed as spam servers.
Rainer
- Normal user
Post
by Rainer » 2010-03-12 15:45
Hello aschoenf, if You are using ASP - Classic or .Net - You must take care for the timeout of Your script!
I send every month a newsletter - with classic ASP - to about 20.000 recipients with no problems.
Kind regards
Rainer Noa
