Webmail
Steve Hale
Webmail
Post by Steve Hale » 2010-02-23 00:23
I am using Squirrelmail with hMailserver.
When composing an email and sending it I get the error message:-
error 530 SMTP authentication is required
Where do I set this in either Squirrelmail or hMailserver please?
Cheers
Steve B
Re: Webmail
Post by mattg » 2010-02-23 01:37
in your squirrelmail config
C:\inetpub\wwwroot\squirrelmail\config\config.php
$smtp_auth_mech = 'login';
(C:\inetpub\wwwroot is IIS, different for apache etc)
bescher
Re: Webmail
Post by bescher » 2010-02-23 10:27
If I recall you have the option to tell Squirrell to make the user use a password to login. Just as Hmail requires you to.
Steve Hale
Re: Webmail
Post by Steve Hale » 2010-02-23 18:02
Thanks Moderator.
Works.
Cheers
Steve
Re: Webmail
Post by mattg » 2010-02-24 01:35
No worries Steve. Glad you got it working...
Matt
