Bug in adding accounts
skrzat
Post by skrzat » 2010-01-29 12:35
When you add new account with weak password there is bug. When you click "Save" and then click "No" on message "The password appears to be weak. Are you sure you want to use it?" it returns to window with adding new account. But when you try to change window selecting another option in left menu without clicking on "Save" and you click "Yes" on message "Do you want to save the changes" and then "No" on message "The password appears to be weak. Are you sure you want to use it?" it should return to window with adding new account but it changes to selected option from left menu losing all changes to new account.
pepsi
Re: Bug in adding accounts
Post by pepsi » 2010-01-29 16:09
what version and build of HMS are you using?
Post by martin » 2010-01-29 19:17
Yeah, I guess it could be categorized as a bug. I'll fix it for 5.4. :)
skrzat
Post by skrzat » 2010-02-01 11:16
5.3.2 b1761
