550 Sender verify failed
Gatzu78
Post by Gatzu78 » 2009-11-16 15:17
Hi Martin,
I have a problem sending mails to some domains.
This is an example, the sender email exist on the mail server, so on't understand why the merlin2.net mail server is compleing.
sales@merlin2.net
Error Type: SMTP
Remote server (80.237.138.5) issued an error.
hMailServer sent: RCPT TO:<sales@merlin2.net>
Remote server replied: 550 Sender verify failed
Thank you.
Re: 550 Sender verify failed
Post by mattg » 2009-11-16 15:48
Gatzu78 wrote:Remote server replied: 550 Sender verify failed
if you enable all logging, recreate the issue you will get more detail in the logs.
This error says that the recipient server told your server that it didn't verify itself. could be many things, including that you perhaps us a home type dynamic IP address, have no SPF records set, didn't send from the IP detailed in the MX records...
Post by martin » 2009-11-16 18:39
Not sure if this is what mattg meant, but the error (typically) means that the recipients server tried to verify that your sender-address actually exists. They do this by connecting back to your server. If your MX records is not set up properly or other servers cannot connect to your server for another reason, or the sender address does not actually exist (or is inactive), you will get this error.
Post by mattg » 2009-11-17 16:09
yes, that's what I meant
(English is my first language, and yet you do it much better - with English not being your fist language, Martin) :shock:
westdam
Post by westdam » 2009-11-17 16:14
hehhehhee :) yeah martin has a good english!! :)
but even yours is not so bad :P
(jokes of course )
