SPAM settings question
pearsondan99
Post by pearsondan99 » 2009-11-16 05:34
I m trying to crack down on the amount of spam entering my environment I ve implemented spam settings fairly tightly but have two questions that concern me;
- SPAM delete threshold - assume this means if it matches this spam score the message will be automatically deleted - I m nervous about tightening this one in case emails go missing without notifiying the end user - is there any way round this?
notification when spam is received - Maybe I m missing something but hmailserver doesnt seem to have a quarantine for spam which has a self release mechanism - is this correct (it ether sends them to the user or deletes them?)
Many thanks in advance
Re: SPAM settings question
Post by mattg » 2009-11-16 05:55
yep you have it about correct.
I use the notification part to change the subject of the message, and then use a rule to forward all messages with that exact wording in the text, directly to an account named spam@mydomain.com and then delete message. Make sure that you exclude all messages being delivered to spam@mydomain.com from the forward or you will create a loop.
You could do this without decreasing the delete threshold score, you could even increase the delete threshold...
I also use 'greylisting' with incredible effect. Almost zero SPAM.
pearsondan99
Post by pearsondan99 » 2009-11-16 06:25
thanks for the swift response Mattg
so to clarify in your example if the spam filter picks up the message as being spam based on the configured rules using the {spam} tag in the subject line it forwards it to a catch all email address (such as spam@domain.com) ?
in your case if a user has identified a missing email you go into the spam@domain.com mailbox and forward it to them or after a period of time auto delete it...
Post by mattg » 2009-11-16 06:36
yep.
I check the spam account every week or three and just delete them, normally.
The only missing mail I have ever been asked about is some newsletters, whose senders do not try again for greylisting. I just add theses sender to the greylisting - whitelist and all goes well.
If you go with my rule and don't delete the message as last step, the users will still receive the message and just a copy will be sent to the SPAM account. Do that for a while to test if you like...
Post by ^DooM^ » 2009-11-16 11:51
That is what I do. I never globally delete email I just mark it as spam that way my end users can either setup a filter in their mail client to delete them or have me move it to a spam IMAP folder (if they are using IMAP) or have the server delete it at the door with an account rule.
westdam
Post by westdam » 2009-11-16 15:00
or you can just have a spam treeshold very high.. so if, for example,
spf fail, dnsbl match, mx check failed this is 99.9% spam..
