Cleanup question.
Cleanup question.
Hi!
Can I delete the unneeded eml files from an account in Hmailserver just by deleting them in Windows explorer, or will this damage some kind of indexing system or something?
Thanks.
C.
Thanks.
C.
Re: Cleanup question.
Yes... the metadata database will get out of sync with the eml files stored (or listed in the database as stored) in the Data folders. Best to log in the account using an email client and delete un-needed email from there.
Quickest way would be to delete the account in the admin and re-add it assuming you know the password.
^Doom^: Cassy, I have a very, very, very cunning plan.
Cassy: Is it as cunning as a fox what used to be Professor of Cunning at Oxford University but has moved on and is now working for the U.N. at the High Commission of International Cunning Planning?
^Doom^: Yes it is.
Cassy: Hmm... that's cunning.
.. gotta love Blackadder!
S.
^Doom^: Yes it is.
S.
lol nutter
I'm not privy to your private cunning joke. In any case, I'll share with you the story of the cunning farmer and his watermelons (you may have already heard this.)
A farmer had been pestered by a thief who had been taking liberty on his watermelons without hindrance. The high fence he built around his farm had no effect whatsoever.
Then he got a really bright idea. He put up the sign:
The next morning, the farmer walked to his watermelon farm with a smile. "Surely, the thief would not have dared steal a watermelon," he thought. He was right.
What he found was his sign edited with red paint:
Now that was really cunning. The farmer could not help congratulating himself for such a simple, cunning solution."Warning - One of these watermelons is poisoned."
"Warning - Two of these watermelons are poisoned."
haha classic
the cunning one is a quote from http://en.wikipedia.org/wiki/Blackadder an 80's comdy thing in the UK.
S.
S.
- Normal user
- Contact:
But there is an other problem in hMailserver.roi wrote:Yes... the metadata database will get out of sync with the eml files stored (or listed in the database as stored) in the Data folders. Best to log in the account using an email client and delete un-needed email from there.
After a while there are a lot of .eml files in the directories without a reference in the database.
hMailserver went that slow that i had to act.
I found 700Mb !!??!!??
So we're back to where we were.Arnold van Walen wrote:But there is an other problem in hMailserver.
I found 700Mb !!??!!??![]()
emails that could be deleted.
Is there a command in hms to repair the database, or to re-index? If so, how does one access it?
Thanks.
C.
are you getting a lot of database errors in the logs? ... seems weird to have so many orphaned files
S.
S.
Take a look at the following three links.
First, howto repair corrupted SQL tables but while you are in there you can optimize etc.
http://www.hmailserver.com/documentatio ... pair_mysql
Now the next two links are dependant on what you want to do.
Re-Enter database entries based on the emails that are orphaned.
http://www.hmailserver.com/documentatio ... ssage_list
Or a cleanup with this script i wrote a while back to removed orphaned emails if their database info does not exist.
http://www.hmailserver.com/forum/viewto ... 20&t=15514
Thanks, Doom; so far, so good.
As far as I know, my db isn't corrupted (yet), but there's one thing I want to clarify:
http://www.hmailserver.com/documentatio ... pair_mysql says:
"Enter your main hMailServer Administrator password. This is the password you specified during the installation when you first installed hMailServer. Click OK."
I never entered a server name. I just click "Enter" to ender the HMS Administrator. What do I enter for that step to repair the db?
Thanks.
C.
Thanks.
C.
- Normal user
- Contact:
No i do not get database errors in the log.sheffters wrote:are you getting a lot of database errors in the logs? ... seems weird to have so many orphaned files
S.
To get rid of the problem i wrote a program that checkes the files versus the database.
If the file is orphaned then i delete the file.
The only files i have to delete manually are the orphaned files in the root directory.
Queued files that are not processed.
That problem occurred when the mailserver crashed about once a day leaving a number of queued messages in the directory.
Since i stopped checking the email with WinClam the CPU usage dropped from 80-90% to max 5%.
Now i only see orphaned email after a system reboot. (Microsoft updates).
try to run DDS , it will check for orphan file..
after only a few days of running hMS with ~150 accounts and ~20 domains, we have in the respective data directories too many empty folders (containing 0 (zero) files in them)
is it safe to manually shift+delete them?
if yes, is there a way that this cleanup task is done via the hMS?
You can delete them, but your wasting your time. They will only be rewritten at a later date if needed, and are left for performance reasons.
Michael
Michael
we were just wondering why all the empty folders, your link (FAQ) was very enlightening
thank you
