A little help needed please.
I've got through the install but am a little confused on MX records.
In my usual mail client I have to specify an smtp server name and a pop server name. So where do I create these in hmailserver settings. It's not clear to me whether I can call my mail server mail.mydomain.com or have to call it something else in my mx record setup. So where and what do I call my mailserver? I would like to call both my smtp and pop server names mail.mydomain.com. Can I do that?
Thanks.
Thanks.
Re: A little help needed please.
elo,
If you run your own DNS server have a read of http://www.iisanswers.com/dns_for_iis.htm ... if you do tht you'll need your glue records updating ... most likely though your ISP manages your DNS so login to your ISP management page and add an A record for mail.yourdomain.com and its public IP address and then add an MX record of mail.yourdomain.com and you should be good to go.
Cheers
S.
MX wants to be the same.It's not clear to me whether I can call my mail server mail.mydomain.com or have to call it something else in my mx record setup
Yep ... no worries.I would like to call both my smtp and pop server names mail.mydomain.com. Can I do that?
Cheers
S.
in hmailserrver what do I put in smtp host ? is it mail.mydomain.com?
sheffters wrote:elo,
Cheers
S.
Have you checked this?
http://www.hmailserver.com/documentatio ... x_problems
It explains how to set up MX records. In the MX record, you should put a host name which resolves to the TCP/IP address where hMailServer is running. That may be mail.mydomain.com, if that host matches the IP address of your server.
This is all very new to me but I think I have done everything OK. I just setup my home pc as a web server today and dns records are working for that as apache is serving up new pages from my machine so some dns information has propogated. But when I try to fetch email from hmailserver address to my server doesn't resolve. I ran nslookup and it is still pointing to domain registrar MX records even though I have setup my own MX record and an a record for it.
I'll check tomorrow as it could just be that dns hasn't propogated unless you have other suggestions.
martin wrote:Have you checked this?
or external people won't resolve against your dns server. (same prob for your web server too)you'll need your glue records updating
probably locally ... I know people keep harping on about 24/48 hours for dns to propogate properly ... but in reality its never taken that long for me and I do lots of domain changes and the like ... so more than likely its not going to go external if it hasn't fairly quickly.dns information has propogated
Use http://www.squish.net/dnscheck/ to see how its being seen on the interwebs ... it doesnt cache and quieries right though the dns system ... any changes I've ever made are seen on there instantly (or post your domain name - easier and no risk imho as its all public info anyway, although some people like to hide them).
You'll need to contact your registrar to add your dns ip's to the registry so the interweb knows to use your server and not a.n.other.
Are you sure you want to run a mail server at home? ... most people will probably block your mails unless your on a static ip (if you are theres no reason why you can't, just most people don't have static at home).
S.
Progress
Not sure why because I made many changes but it was probably becuase I hadn't configured ports properly.
Anyhow I now have problem that one on-route server is rejecting mail becuase:
"Remote server replied: 550 Sender verify failed"
So it doesn't like me. How do I get around that?
I have a static IP and I tested my apache webserver page from my mobile phone which can access my web page so that seems to work fine via the dns. Squish and intodns look OK except for glue?
Why do I need glue records? Isn't that for the dns owner to sort out?
the domain I'm playing with is websitedesignerdevon.co.uk which I'm just using as a learning exercise for this. I'm fed up with web hosts support levels and making sweeping changes which require a lot of work at my end so I've decided to try and run my own server from home and email is part of that.
sheffters wrote:or external people won't resolve against your dns server. (same prob for your web server too)you'll need your glue records updating
S.
the rDNS on your IP is set to port-233.xxx.th.newnet.co.uk it should be set to your domain name. Have you setup SPF?
I haven't setup SPF. That's something else I guess I will need. Haven't a clue how to go about that yet.
How do I set the rDNS ?
^DooM^ wrote:the rDNS on your IP is set to port-233.xxx.th.newnet.co.uk it should be set to your domain name. Have you setup SPF?
Contact your ISP and ask them to change it. If that domain is only temporary though you may want to change it to your permanent domain instead as it takes upto 72 hours to make the change (only works on static ip)
Would life be easier if I bought Simple DNS Plus" so that I had total control over the DNS. The only thing that concerns me about doing that is that I may use significant amounts of bandwidth and resource just running a DNS for a handful of domains. Something else to learn about. I'll be moving soon so don't really want to get a full setup before that as I will probably move ISP too and have to go through the whole process again.
^DooM^ wrote:Contact your ISP and ask them to change it. If that domain is only temporary though you may want to change it to your permanent domain instead as it takes upto 72 hours to make the change (only works on static ip)
Upto you, you would have to notify your ISP either way if you want to run your own DNS server or not. The joys of being a server admin
If you are new to mail servrs, I would suggest that you take it easy on adding more variables to the equation that would make your learning curve even more steep. Your own DNS can come later.
That said, having your own DNS is a natural when you have a mail server because you will probably end up hosting more and more domains for email addresses.
As DooM said... the joys of being a server admin...! I know what you are going through... the frustrations, the questions and that elevated feeling you get when you get to get things working like a charm. I still go through these feelings even after so many years.
Best wishes on your new adventure...
Thanks all. With your help and advice I'm 98% there. hmail seems to be working OK now and I can send and receive messages OK. Just have one domain being problematic but I don't think that is anything to do with hmailserver.
rDNS PTR record is now setup.
One further question which is slightly off at a tangent and that is can anyone give me pointers on how to make php mail() function use hmail as smtp server. Have looked at PHP docs but it is not clear to me where the link to the server is being defined in php.ini. Or what actually links the mail() function to the hmail service.
It is in the PHP.ini
[mail function]
; For Win32 only.
SMTP = 127.0.0.1
smtp_port = 25
; For Win32 only.
sendmail_from = mail@yourdomain.com
Thanks,
It wasn't working because it needs the hostname rather than the IP number. I have several domains and it needs the domain host name so SMTP mydomain.com worked.
Looks like I've already had some attempted hack attacks since putting my site up
only to be expected I suppose.
Anyhow all seems to be working OK for now so thanks again...
