Is there any automatic backup in hmail?
black zero
Post by black zero » 2009-03-18 03:54
Well.. I am surprised my previous thread was moved to this subforum, o.O so I posted this thread here instead on general discussion.
As the topic title says, I want an automatic backup function either built in or script. The script matt provided to me is working wonderfully, and I am very satisfied with it. But it's even better if I have automatic backup functionality for hmail.
Re: Is there any automatic backup in hmail?
Post by mattg » 2009-03-18 04:49
Easy...
In C:\Program Files\hMailServer\Addons\Utilities there is a utility called StartBackup.vbs
Edit this with your password.
Make sure that the backup settings that you need are set with hMailserver Backup.
Create a new windows scheduled task Start >> Control Panel >> Scheduled Task >> Create New Scheduled Task
browse to the C:\Program Files\hMailServer\Addons\Utilities\StartBackup.vbs and select your schedule (I do mine at least daily)
The e-mail swill then let you of both successful and unsuccessful backups....
black zero
Post by black zero » 2009-03-18 06:03
Done all you listed above.
Let's see for the result then. Thank you very much.
Post by martin » 2009-03-21 13:39
(Since this is a fairly frequent question from users (not reading the documentation) I've added a help text in the backup section of hMailServer Administrator which tells you that you can use that script to automate backups)
