i just upgraded to the actual Version, but now i have to Problems:
1:) I cant select German Language but the german.ini is in the language folder
2:) I wonna use HMailServer with Plesk but it seams that is not working with the Actual HMailServer........anyone got this working?!
Thank you for your help!
HMail Server 5.X
- Hosters.at
- New user
- Contact:
Re: HMail Server 5.X
1) Add German to ValidLanguages in hMailServer.ini. Then restart the service and the problem will be solved. You may want to download an up-to-date translation before doing this:
http://www.hmailserver.com/devnet/trans ... age=german
2) I recommend contacting Plesk on this one. Maybe someone else has gotten it to work but as far as I know, Plesk is closed-source and can't really be modified by its users.
