iphone sending error
plobby
Post by plobby » 2009-03-13 03:51
Im not sure what happened, but I setup my email account on my iphone and after I upgraded to version 5 I cannot send email. I can download/read it just fine but when I send an email I get this error
"The connection to the outgoing server "mail.---.com" failed"
"SMTPD" 2520 89380 "2009-03-12 20:33:34.640" "127.0.0.1" "SENT: 220 Shakes hand, hello!"
"SMTPD" 2520 89380 "2009-03-12 20:33:34.703" "127.0.0.1" "RECEIVED: XXXX [10.10.10.245]"
"SMTPD" 2520 89380 "2009-03-12 20:33:34.703" "127.0.0.1" "SENT: 502 Use HELO/EHLO first."
"SMTPD" 2520 89380 "2009-03-12 20:33:34.765" "127.0.0.1" "RECEIVED: RSET"
"SMTPD" 2520 89380 "2009-03-12 20:33:34.765" "127.0.0.1" "SENT: 250 OK"
"SMTPD" 2520 89380 "2009-03-12 20:33:34.843" "127.0.0.1" "RECEIVED: HELO [10.10.10.245]"
"SMTPD" 2520 89380 "2009-03-12 20:33:34.843" "127.0.0.1" "SENT: 250 Hello."
"SMTPD" 2520 89380 "2009-03-12 20:33:34.937" "127.0.0.1" "RECEIVED: MAIL FROM:<waylon@---.com>"
"SMTPD" 2520 89380 "2009-03-12 20:33:34.968" "127.0.0.1" "SENT: 250 OK"
"SMTPD" 2520 89380 "2009-03-12 20:33:35.171" "127.0.0.1" "RECEIVED: QUIT"
"SMTPD" 2520 89380 "2009-03-12 20:33:35.171" "127.0.0.1" "SENT: 221 goodbye"
Re: iphone sending error
Post by ^DooM^ » 2009-03-13 11:38
Do you have a cisco firewall in front of hMail?
plobby
Post by plobby » 2009-03-13 15:40
Oh yeah I remember something happening with this before. I have a pix in front of it, what rules does it have to do with again?
plobby
Post by plobby » 2009-03-13 16:50
I believe it is the fixup protocol, one minute.
Post by ^DooM^ » 2009-03-13 17:57
Yep
If you are using a Cisco router, you may need to disable SMTP Fixup protocol. If this is enabled, the router will sometimes intercept SMTP traffic and replace data in it before it reaches hMailServer which will cause problems.
plobby
Post by plobby » 2009-03-13 20:00
Yupp that did it - thanks!!
