Hi, when I first installed hMailServer it gave the option to have each domain in a separate folder. Initially, I had it running fine, but I wanted to change the database and ran into all sorts of problems that caused me to reinstall. However, when reinstalling, I was not given the option to put each domain in a separate folder. Is there a way to manually set this option? Or will I need to uninstall and remove some registry keys or something before reinstalling?
Thanks!
folders for each domain
Re: folders for each domain
As far as i know there is no option like that. Messages are always put in "domain"-folders. And in the domainfolders there are max 256 other folders. Why? Performance! Alle messages in one folder is getting performance issues with lot of emails
hmailserver 4.3 (242 Live)
hmailserver 5.0 (605 Test)
Windows 2003
MSSQL
ASSP 1.3.2
ClamAV (SOSDG)
http://www.realdesign.nl
Windows 2003
MSSQL
ASSP 1.3.2
ClamAV (SOSDG)
