Running external scripts after hacker/ spammer detection?
GlenC
Post by GlenC » 2008-12-31 00:41
I'm wondering if it's possible to do something with hmail's internal scripting. What I'm thinking is something along the lines of this. If a DNSBL returns a positive result for a known spammer, then I can run an external script to add that particular IP to my firewall. Or, another example, if a user fails authentication X number of times, run the external script to add that IP to the firewall. I see in my logs quite a few repeat offenders that really shouldn't be wasting my resources.
If this isn't something readily scriptable in eventhandler, what are others thoughts on this as a possible future feature request? Perhaps an option to run an external program or script on detection of certain events such as above? I think it could be useful.
Re: Running external scripts after hacker/ spammer detection?
Post by ^DooM^ » 2008-12-31 01:04
I like the idea, I wouldn't mind a way to perhaps add offending IP's to a database or my own DNS zone or something similar so I can use my own DNS server as an RBL check.
GlenC
Post by GlenC » 2008-12-31 01:56
I already do something similar with my website... there are certain requests that can't be interpreted as anything other than pure hack attempts. So, if nothing else, it makes me feel good to close the door on them. :) I was hoping to find something to hook into in hmailserver but I don't think there is any current way of doing it.
I'm sure there are other useful things that could be accomplished with this capability too.
Post by mattg » 2008-12-31 02:23
Perhaps scripting something similar to what Martin has suggested here - http://www.hmailserver.com/forum/viewto ... 437#p76437
The database could be accessed by some external programs that auto add the IPs to the firewalls blacklist. If the same table is used then perhaps Martin's (planned) built-in purge facility will work just as well. The table could contain IPs and times of both unsucessful logins and suspected SPAMMers and still work the same...
Just a thought. :D
GlenC
Post by GlenC » 2008-12-31 15:26
mattg wrote:Perhaps scripting something similar to what Martin has suggested here - http://www.hmailserver.com/forum/viewto ... 437#p76437
That will be a handy feature when added. It would be nice if that event is exposed so that it could be tested for in real time without having to monitor the database constantly.
I guess I'm a little biased in my way of wanting to accomplish things. The firewall blocking script that I used for my website worked so well I now want to add it to EVERYTHING. I'm a little obsessive compulsive like that sometimes :)
