install/configure PHPWebAdmin
cola4ever
Post by cola4ever » 2005-02-27 20:04
I have an issue installing and configuring;
My context:
Windows XP Pro SP 2
Apache 2.0.53
Mysql 4.1.10
PHP 5.03
These are the steps I took;
Copied the phpwebadmin folder to my documentroot.
Copied config-dist.php to config.php
Created template_c and temp directories
Changed config.php settings to;
$hmail_config['rootpath']          = "c:/apache2/htdocs/phpwebadmin/";
$hmail_config['rooturl']           = "http://127.0.0.1/phpwebadmin";
$hmail_config['includepath']       = $hmail_config['rootpath'] . "include/";
$hmail_config['temppath']          = $hmail_config['rootpath'] . "temp/";
$hmail_config['pluginpath']        = $hmail_config['rootpath'] . "plugins/";
$hmail_config['admin']             = "user";
$hmail_config['adminpassword']     = "password";
$hmail_config['defaultlanguage']   = "english";
$hmail_config['defaulttheme']      = "default";
All I get when I enter "http://127.0.0.1/phpwebadmin/" in my browser is a blank page.
Other web application like phpmyadmin, phpbb, vbulletin and mambo work fine.
I have absolutely no idea what to do.
Thanks in advance.
layer
Post by layer » 2005-02-28 02:03
upgrade php for 5 version...
cola4ever
Post by cola4ever » 2005-02-28 11:24
I already have PHP 5 installed
My context:
Windows XP Pro SP 2
Apache 2.0.53
Mysql 4.1.10
PHP 5.03
vasi
The same problem but solved
Post by vasi » 2005-02-28 18:46
sorry for my english :(
so a have the same problem and downloaded PHP 5.03 installed and...the same... so i do the following things to get web administration working. I rename my directory to "mail" for fast typing
$hmail_config['rootpath'] = "C:/apache/Apache2/htdocs/mail/";
$hmail_config['rooturl'] = "http://127.0.0.1/mail/";
$hmail_config['admin'] = "********";
$hmail_config['adminpassword'] = "*******";
look at end slashes ("/") at rooturl and rootpath. They are as i understand VERY important.
second thing is to have subfolder "sessiondata" in your php folder. I did't have it and receive some stupud errors, but after i created this "sessiondata" folder, everythings go normaly.
I hope that helps 8)
Post by martin » 2005-02-28 19:27
Also, you could try turning on error_reporting in php.ini to see if that shows some error.
cola4ever
Post by cola4ever » 2005-03-02 20:47
I added the forward slashes to the 'rootpath' and 'rooturl' and now everything seems to be working fine.
So, thanks :)
Post by martin » 2005-03-08 21:12
callforsitters
Post by callforsitters » 2005-05-22 04:20
I'm running IIS 6.0, PHP 5.03 and hmailserver with MSSQL. I'm having the same blank-page problem as mentioned above but nothing seems to be fixing it. Below is my config file.
// Global configuration
$hmail_config['rootpath']		= "C:/Inetpub/wwwroot/PHPWebAdmin/";
$hmail_config['rooturl']		= "http://127.0.0.1/PHPWebAdmin/";
$hmail_config['admin']			= "PRIVATE";
$hmail_config['adminpassword']		= "PRIVATE";
[/code]
Post by martin » 2005-05-22 17:07
Then why do you think it would be "the same" problem? :)
You're problem is probably the same as the end of this thread:
http://www.hmailserver.com/forum/viewtopic.php?p=9908
callforsitters
Post by callforsitters » 2005-05-24 16:08
Hi Martin,
I'm still at the blank page stage and haven't gotten as far as the login form yet. :(
mcampbell
Post by mcampbell » 2005-05-24 18:30
Try commeting out the "doc_root" line in your php.ini file I had the same problem but commeting that line makes it all work. (though I have IIS)
HM 4.2B195 :: MySQL 4.1 :: PHP 4.3.11 :: Win2k
Power over "them"
callforsitters
Post by callforsitters » 2005-05-24 18:49
I too have IIS 6.0. Thanks for the suggestion but it didn't do anything.
I just realized I'm running php 5.0.4 if that makes a difference.
edit
Okay, I fixed the problem. I created the temp folders and gave the user Write/Read control but not FULL control. Changing that fixed the problem. Thanks for all of your help.
