Where can I see the doc containing....
- Normal user
about how to make webmail up and running on hmailserver? I couldn't find any... -_-
Re: Where can I see the doc containing....
- Normal user
lol... so sad... It's beyond my current knowledge to be done....
But, thanks for pointing out that. Really appreciate it.
- Normal user
Its honestly not that hard to do. I had no knowledge of how squirrelmail worked, and after a few hours of tinkering, I got it to work. There's really only one file that you have to modify to get it to work. If you use XAMPP and Squirrelmail, its basically a bunch of copying and pasting, with editing of that one file.
hMailServer v5.2.1 Build 360
XAMPP 1.70
Horde Groupware Webmail 1.2.3
Windows Server 2003 SBS
XAMPP 1.70
- Normal user
Alright. Thanks for the support, though.
