Running hmail on p2 300, 64mb ram, XP SP2, 10Gb HDD....
- Normal user
Would the H/W be able to run it smoothly?
- Normal user
Re: Running hmail on p2 300, 64mb ram, XP SP2, 10Gb HDD....
No, simply because XP SP2 won't run smoothly. You'd want at least 256MB of RAM for XP SP2 (I recommend no less than 512)
hMailServer v5.2.1 Build 360
XAMPP 1.70
Horde Groupware Webmail 1.2.3
Windows Server 2003 SBS
XAMPP 1.70
- Normal user
Ah I see..... thanks.
Also, there is a lot of different factors which applies as well, such as number of users, protocol used, virus scanning, spam protection method, volumes and more. No-one can say whether a computer fast enough if they don't know what it's going to be used for..
