adding email from hmail server to another hmail server
Heeter
Post by Heeter » 2008-05-13 06:32
Hi all,
I have two separate hmail servers running on two separate server towers. I would to add the existing domains from one hmail server to the other hmail server.
I know that I can just create the accounts on the second server from the first, but how do I move the mail over?
Thanks,
Heeter
Re: adding email from hmail server to another hmail server
Post by mattg » 2008-05-13 06:54
A few different ways.
Easiest is to backup and restore I reckon.
You could connect to both from an IMAP e-mail client and move or copy the e-mails from within your client
Use something IMAPCopy
send from one to the other as normal e-mail
Matt
Heeter
Post by Heeter » 2008-05-14 04:09
Sorry,
I forgot to mention that these two servers use squirrelmail as php client for each.
Heeter.
Post by mattg » 2008-05-14 04:30
Doesn't matter, but you can't open two accounts at once with Squirrelmail that I am aware of.
You can open two IMAP accounts with Thunderbird, or Outlook Express or Outlook, or ...
You could also try IMAPSize, it has a command line feature for automated backups...
Matt
Kaan1983
Post by Kaan1983 » 2008-05-14 14:39
Just as an idea:
Backup and restore the DB, copy the data directory and synchronize. You will have e-mails and accounts as well.
Heeter
Post by Heeter » 2008-05-14 21:50
Hi guys,
I was gonna ask if I can do this with the existing data folder that I copied over.
Heeter
