Hmail Server & YAF Forum
ewhitmor
Post by ewhitmor » 2008-04-23 21:53
Hey all,
I am having a bit of a problem getting hmail and YAF (Yet Another Forum) to interact. The YAF guys say its hmail but when i check the hmail logs im not seeing how it could be hmail. Here is the situation.
I am using YAF for a small local government. They have uses that are "watching" certain boards and when someone posts to that board it should be email everyone who is watching. Currently there are around 25+ people watching the forum. The problem is when someone posts it only sends out 1 to 3 emails instead of the 25+ like it should. Using other parts of the forum i am able to email all members (65 people) without problem which leads me to think its YAF's problem not hmail. YAF people seem to think otherwise and thus i am posting my log here for you guys to review and give me your thoughts.
"SMTPD"	5712	238947	"2008-04-23 15:41:16.989"	"xxx.xxx.xxx.xxx"	"SENT: 220 www.xxx.com ESMTP"
"SMTPD"	5712	238947	"2008-04-23 15:41:17.005"	"xxx.xxx.xxx.xxx"	"RECEIVED: EHLO tmst"
"SMTPD"	5712	238947	"2008-04-23 15:41:17.005"	"xxx.xxx.xxx.xxx"	"SENT: 250-hmailserver[nl]250-SIZE[nl]250 AUTH LOGIN"
"SMTPD"	5712	238947	"2008-04-23 15:41:17.005"	"xxx.xxx.xxx.xxx"	"RECEIVED: AUTH login Z3JhdGlvdEBteWdyYXRpb3Qub3Jn"
"SMTPD"	5712	238947	"2008-04-23 15:41:17.005"	"xxx.xxx.xxx.xxx"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	5712	238947	"2008-04-23 15:41:17.005"	"xxx.xxx.xxx.xxx"	"RECEIVED: ***"
"SMTPD"	5712	238947	"2008-04-23 15:41:17.021"	"xxx.xxx.xxx.xxx"	"SENT: 235 authenticated."
"SMTPD"	5712	238947	"2008-04-23 15:41:17.021"	"xxx.xxx.xxx.xxx"	"RECEIVED: MAIL FROM:<xxx@xxx.org>"
"SMTPD"	5712	238947	"2008-04-23 15:41:17.021"	"xxx.xxx.xxx.xxx"	"SENT: 250 OK"
"SMTPD"	5712	238947	"2008-04-23 15:41:17.021"	"xxx.xxx.xxx.xxx"	"RECEIVED: RCPT TO:<xxx@hotmail.com>"
"SMTPD"	5712	238947	"2008-04-23 15:41:17.021"	"xxx.xxx.xxx.xxx"	"RECEIVED: DATA"
"SMTPD"	5712	238947	"2008-04-23 15:41:17.021"	"xxx.xxx.xxx.xxx"	"SENT: 354 OK, send."
"SMTPD"	5712	238947	"2008-04-23 15:41:17.067"	"xxx.xxx.xxx.xxx"	"SENT: 250 Queued (0.015 seconds)"
"APPLICATION"	5612	"2008-04-23 15:41:17.114"	"SMTPDeliverer - Message 17584: Delivering message from xxx@xxx.org to xxx@hotmail.com. File: C:\Program Files\hMailServer\Data\{35DA0C80-FC71-47B8-8F55-569BFA415C3C}.eml"
"SMTPC"	3196	238949	"2008-04-23 15:41:18.317"	"xxx.xxx.xxx.xxx"	"RECEIVED: 220 bay0-mc11-f21.bay0.hotmail.com Sending unsolicited commercial or bulk e-mail to Microsoft's computer network is prohibited. Other restrictions are found at http://privacy.msn.com/Anti-spam/. Violations will result in use of equipment located in California and other states. Wed, 23 Apr 2008 12:41:48 -0700 "
"SMTPC"	3196	238949	"2008-04-23 15:41:18.317"	"xxx.xxx.xxx.xxx"	"SENT: HELO www.xxx.com"
"SMTPC"	3196	238949	"2008-04-23 15:41:18.380"	"xxx.xxx.xxx.xxx"	"RECEIVED: 250 bay0-mc11-f21.bay0.hotmail.com (3.5.0.22) Hello [xxx.xxx.xxx.xxx]"
"SMTPC"	3196	238949	"2008-04-23 15:41:18.380"	"xxx.xxx.xxx.xxx"	"SENT: MAIL FROM:<xxx@xxx.org>"
"SMTPC"	3196	238949	"2008-04-23 15:41:18.442"	"xxx.xxx.xxx.xxx"	"RECEIVED: 250 xxx@xxx.org....Sender OK"
"SMTPC"	3196	238949	"2008-04-23 15:41:18.442"	"xxx.xxx.xxx.xxx"	"SENT: RCPT TO:<xxx@hotmail.com>"
"SMTPC"	3196	238949	"2008-04-23 15:41:18.521"	"xxx.xxx.xxx.xxx"	"RECEIVED: 250 xxx@hotmail.com "
"SMTPC"	3196	238949	"2008-04-23 15:41:18.521"	"xxx.xxx.xxx.xxx"	"SENT: DATA"
"SMTPC"	3196	238949	"2008-04-23 15:41:18.583"	"xxx.xxx.xxx.xxx"	"RECEIVED: 354 Start mail input; end with <CRLF>.<CRLF>"
"SMTPC"	3196	238949	"2008-04-23 15:41:18.583"	"xxx.xxx.xxx.xxx"	"SENT: [nl]."
"SMTPC"	3196	238949	"2008-04-23 15:41:18.849"	"xxx.xxx.xxx.xxx"	"RECEIVED: 250  <36A7FBCA-7F2B-476B-AB7A-25E055BAEAE2@www.xxx.com> Queued mail for delivery"
"SMTPC"	3196	238949	"2008-04-23 15:41:18.849"	"xxx.xxx.xxx.xxx"	"SENT: QUIT"
"SMTPC"	3196	238949	"2008-04-23 15:41:18.911"	"xxx.xxx.xxx.xxx"	"RECEIVED: 221 bay0-mc11-f21.bay0.hotmail.com Service closing transmission channel"
"APPLICATION"	5612	"2008-04-23 15:41:18.911"	"SMTPDeliverer - Message 17584: Message delivery thread completed."
"SMTPD"	5712	238950	"2008-04-23 15:41:33.771"	"xxx.xxx.xxx.xxx"	"SENT: 220 www.xxx.com ESMTP"
Any help or direction you guys can provide would be awesome
Re: Hmail Server & YAF Forum
Post by martin » 2008-04-23 22:05
That log shows that YAF tells hMailServer to deliver an email from xxx@xxx.org to xxx@hotmail.com and that hMailServer then does this. If it was supposed to be sent to more people, it looks like a YAF issue to me...
ewhitmor
Post by ewhitmor » 2008-05-05 17:27
Martin - That is the conclusion i am going up with as well. Thanks for confirming it.
On a side note:
If under IP ranges i have my webserver's IP(private & public & which happens to be the same box as my hamil server) and i have the forwarding relay checked but not spam protection would there be ANY reason why hmail would drop the correction from my forum after 2 or 3 emails?
Post by mattg » 2008-05-06 01:43
In settings >> Protocols >> SMTP >> RFC compliance >>
What do you have the maximum number of invalid commands set to?
Kaan1983
Post by Kaan1983 » 2008-05-06 14:01
I'm dealing with YAF as well nowadays. I'd say it should be a YAF problem, without any doubt :)
