bulk mails for gmail
webmitra
Post by webmitra » 2008-04-19 06:36
hello
when i am sending mail to gmail its going in bulk folder.
below is header information.
Delivered-To: webmitra@gmail.com
Received: by 10.114.149.5 with SMTP id w5cs159875wad;
Fri, 18 Apr 2008 21:28:02 -0700 (PDT)
Received: by 10.150.148.7 with SMTP id v7mr4577884ybd.95.1208579279993;
Fri, 18 Apr 2008 21:27:59 -0700 (PDT)
Return-Path: <test@nexus-links.com>
Received: from mail.nexus-links.com ([72.232.181.102])
by mx.google.com with SMTP id 9si1794955yws.6.2008.04.18.21.27.46;
Fri, 18 Apr 2008 21:28:00 -0700 (PDT)
Received-SPF: error (google.com: error in processing during lookup of test@nexus-links.com: DNS timeout) client-ip=72.232.181.102;
Authentication-Results: mx.google.com; spf=temperror (google.com: error in processing during lookup of test@nexus-links.com: DNS timeout) smtp.mail=test@nexus-links.com
by mail.nexus-links.com
with hMailServer ; Fri, 18 Apr 2008 23:27:36 -0500
Received: from 121.247.197.201 ([121.247.197.201])
(SquirrelMail authenticated user test@nexus-links.com)
by mail.nexus-links.com with HTTP;
Fri, 18 Apr 2008 23:27:36 -0500 (Central Daylight Time)
Message-ID: <.121.247.197.201.1208579256.squirrel@mail.nexus-links.com>
Date: Fri, 18 Apr 2008 23:27:36 -0500 (Central Daylight Time)
Subject: test
User-Agent: SquirrelMail/1.4.9a
MIME-Version: 1.0
Content-Type: text/plain;charset=iso-8859-1
Content-Transfer-Encoding: 8bit
X-Priority: 3 (Normal)
Importance: Normal
why its showing
and due to that its going in bulk folder.
pls help
admin
Re: bulk mails for gmail
Post by martin » 2008-04-19 10:29
Have you set up a SPF record for your domain? If so, what is it?
webmitra
Post by webmitra » 2008-04-22 05:43
hello
i have set PTR record for the server.
let me know how to set SPF for the each domain name. is it from hmail server admin or from data center ?
bhavin
redrummy
Post by redrummy » 2008-04-22 07:36
plobby
Post by plobby » 2008-04-24 04:04
How many of you have spf records actually set up for your domains?
Post by ^DooM^ » 2008-04-24 10:40
I have an SPF record.
redrummy
Post by redrummy » 2008-04-25 06:27
I do, and so do ~20 other domains I've set up. I know it's still debated by some, but for the < 5 minutes it takes to configure (in most cases) it seems silly not to when it can easily help identify a forged FROM domain.
