Before:
- hmail server with public ip address and IIS6 with webmail.
- I addedd 2 ip ranges (127.0.0.1 and the public ip address) avoiding SPAM and authentication (for users using webmail)
After:
- hmail server after a nat with private ip address and IIS6 with webmail.
- I addedd 1 ip ranges (private ip address) avoiding SPAM and authentication (for users using webmail)
Form a certain version of Hmail (I dont remember from when...3 o 4 months) started some problems with firewall/nat (a Zywall 35 utm): CPU 100%.
I have searched for month (yes, I am not a big detective) and finally I discovered that every 10 or 15 seconds, hmail sends a big amount of traffic to/from port 25 between old public ip address to new ip address (passing inside firewall/nat and stoning him).
Other tracks:
- the host name in hmail points to public ip address
- I have only one ip address in the server
- local users use IMAP
- I use clamDscan
- I use dns blacklist (with local dns server)
- I use graylist
- I use one surbl server
- If I detach hamilserver from the firewall, it waits about 30min before start to send/receive data again
After deleting unnecessary ip ranges it is returned all ok but my question is: why hmail send/receive data between its private and public ip address only if these address are in the ip ranges ?
thanks
hiper-strange routing
Hmailserver [lastversion] + MSSQL
Re: hiper-strange routing
What priority are your IP ranges? 127.0.0.1 should be highest. Also, since you have a local DNS server you should mirror your public records with your server(s) IP addresses so LAN clients don't hit the firewall.
127.0.0.1 have the highest priority
Then I have added an ip for the public address of the hamail server and an ip for the private address.
The DNS is in the same server as hmail.
Tons of traffic occours in port 25 between private and public ip address of hmailserver.
After removing this ip ranges, the traffic stops.
Have you enabled logging in hMailServer to see what's going on..?
