How can i prevent emails to Internet?
emarioh
Post by emarioh » 2008-03-24 18:18
Hello all,
Please i am new to email servers and hMail. I recently setup hMail for our intranet. But the problem is that mails sent from our domain e.g emarioh.local to an inernet address like email@gmail.com delivers. I want to prevent mails from delivering outside the intranet. my smtp and pop are for my local server: 10.0.1.1. Pls can anyone help me out?
Thanks.
.Emmanuel
Carl
Re: How can i prevent emails to Internet?
Post by Carl » 2008-03-24 18:22
I think you can change that in the IP settings. Only allow connections from 10.0.1.0 to 10.0.1.154. Ooops, nope that won't work...
Carl
98% of computer users know just enough to be dangerous, but not enough to be useful. I'm afraid I don't fall in the top 2%.
redrummy
Post by redrummy » 2008-03-24 18:42
Add global rule: To; Not contains: @localdomain -> Reply (form); Delete
emarioh
Post by emarioh » 2008-03-27 15:17
redrummy wrote:Add global rule: To; Not contains: @localdomain -> Reply (form); Delete
Hello Redrummy, i tried the rule stuff but my local mails were not deliverying until i deleted the rule. Maybe i did not do it right, but i did follow the procedure u laid out. Would you kindly elaborate on this? Thanks.
redrummy
Post by redrummy » 2008-03-27 17:13
Actually, on re-reading the rule I realize that it will only reliably work for a single address in the "To" field. Maybe I wasn't awake when I replied. ;) To do this right you'd need to script it. I'm sure it can be done, but I can't tell you quickly how to do it. Maybe someone else wants to take a stab at it. Sorry for the false solution. :oops:
Post by SorenR » 2008-03-27 21:27
Whatif... you point the setting for smtp relayer to a non-existing IP address. I presume e-mail will come back to sender as undeliverable. This will apply for the whole server though.
Just a brain fart, correct me if I'm wrong.. :|
Post by ^DooM^ » 2008-03-27 21:50
That's a good idea Soren. Local email should be unaffected by this.
redrummy
Post by redrummy » 2008-03-27 21:51
Good idea. Gotta love simple solutions... Just set low retry count and timeout values and anything trying to leave the server gets bounced within a few minutes.
Kaan1983
Post by Kaan1983 » 2008-03-27 22:34
There is an option under Advanced->IP Ranges->
Why not go there and set "Allow deliveries"!
Post by SorenR » 2008-03-27 23:14
Even simpler.. Why didn't I think of that :roll:
Kaan1983
Post by Kaan1983 » 2008-03-27 23:23
Because you know coding and stuff and I don't :) believe or not that's the reason.
redrummy
Post by redrummy » 2008-03-28 03:10
And I've been very sick *cough*... That's my excuse, and I'm sticking with it. ;)
Mind you, aliases are treated as external, so all addresses would have to be real accounts if external delivery is not enabled.
emarioh
Post by emarioh » 2008-03-29 15:51
Thanks alot SorenR, Kaan1983 and redrummy. I did stumble on the 'Allow deliveries', and thats what i'm using now. I am also not using aliases yet; but i will try out the 'smtp relayer' later on. i want to try setting up the webadmin and also see how users can access their mails via http or web. Wont mind some help on this too.
