Installed but not working Please help.
frink
Post by frink » 2008-03-12 06:24
I have just installed and configured hMail onto my windows 2003 server. but somthing is wrong and i cannot figure out what.
When i try to connect to the account i created using outlook it fails. Also when i send an email to that address i recive an undeliverable error.
The MX record is set to the correct address, SMTP, IMAP and POP3 ports are forwarded to the server and the hMail server is configured as per the setup guide.
Does anyone have any ideas or know what ive missed. Thanks
plobby
Post by plobby » 2008-03-12 06:38
Can you post some logs to start. Enable smtp, pop, imap, etc..
frink
Post by frink » 2008-03-12 06:54
ERROR_hmailserver_2008-02-12.log
"ERROR" 4588 "2008-03-12 15:49:35.656" "Source: IOCPServer::_CreateListenSocket, Code: HM4316, Description: Call to bind() failed. Error: 10048. Is another server is already using this port (25)?"
"ERROR" 4588 "2008-03-12 15:49:35.656" "Source: IOCPServer::DoWork(), Code: HM4323, Description: _CreateListeningSockets() failed. Error: 183"
"DEBUG" 5636 "2008-03-12 15:49:35.656" "Application::StartServers()"
"DEBUG" 5636 "2008-03-12 15:49:35.656" "Application::~StartServers()"
"APPLICATION" 4588 "2008-03-12 15:49:35.656" "Source: IOCPServer::_CreateListenSocket, Code: HM4316, Description: Call to bind() failed. Error: 10048. Is another server is already using this port (25)?"
"DEBUG" 2428 "2008-03-12 15:49:35.656" "ExternalFetchManager::Start()"
"DEBUG" 5728 "2008-03-12 15:49:35.656" "SMTPDeliveryManager::Start()"
"APPLICATION" 4588 "2008-03-12 15:49:35.656" "Source: IOCPServer::DoWork(), Code: HM4323, Description: _CreateListeningSockets() failed. Error: 183"
"DEBUG" 5484 "2008-03-12 15:54:35.656" "TimedoutConnectionRemoverTask::DoWork()"
Its says i have another server using port 25 but if so i have no idea what it is.
Post by mattg » 2008-03-12 07:33
do you IIS POP3 running on your win 2003 server?
Check in Add / remove programs >> windows components
Matt
frink
Post by frink » 2008-03-12 07:51
Thanks guys its all workin now.
It was a mail component of my web server package which i didnt know was installed.
