"SMTPD" 3608 34012 "2008-02-25 10:44:50.887" "221.5.17.252" "SENT: 220 Welcome to MilesTec AG"
"SMTPD" 3608 34012 "2008-02-25 10:44:51.528" "221.5.17.252" "RECEIVED: EHLO UATIM-49CCCC0DC"
"SMTPD" 3608 34012 "2008-02-25 10:44:51.528" "221.5.17.252" "SENT: 250-hmailserver[nl]250-SIZE[nl]250 AUTH LOGIN"
"SMTPD" 3608 34012 "2008-02-25 10:44:53.340" "221.5.17.252" "RECEIVED: AUTH LOGIN"
"SMTPD" 3608 34012 "2008-02-25 10:44:53.871" "221.5.17.252" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 3608 34012 "2008-02-25 10:44:54.418" "221.5.17.252" "RECEIVED: aW5uYQ=="
"SMTPD" 3608 34012 "2008-02-25 10:44:54.418" "221.5.17.252" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 3608 34012 "2008-02-25 10:44:55.090" "221.5.17.252" "RECEIVED: ***"
"SMTPD" 3608 34012 "2008-02-25 10:44:55.090" "221.5.17.252" "SENT: 535 Authentication failed. Restarting authentication process."
"SMTPD" 3608 34012 "2008-02-25 10:44:55.731" "221.5.17.252" "RECEIVED: AUTH LOGIN"
"SMTPD" 3608 34012 "2008-02-25 10:44:55.731" "221.5.17.252" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 3608 34012 "2008-02-25 10:44:56.293" "221.5.17.252" "RECEIVED: aW5uYQ=="
"SMTPD" 3608 34012 "2008-02-25 10:44:56.293" "221.5.17.252" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 3608 34012 "2008-02-25 10:44:56.903" "221.5.17.252" "RECEIVED: ***"
"SMTPD" 3608 34012 "2008-02-25 10:44:56.903" "221.5.17.252" "SENT: 535 Authentication failed. Restarting authentication process."
"SMTPD" 3608 34012 "2008-02-25 10:44:59.918" "221.5.17.252" "RECEIVED: AUTH LOGIN"
"SMTPD" 3608 34012 "2008-02-25 10:44:59.918" "221.5.17.252" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 3608 34012 "2008-02-25 10:45:00.762" "221.5.17.252" "RECEIVED: aW5uYQ=="
"SMTPD" 3608 34012 "2008-02-25 10:45:00.762" "221.5.17.252" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 3608 34012 "2008-02-25 10:45:01.512" "221.5.17.252" "RECEIVED: ***"
"SMTPD" 3608 34012 "2008-02-25 10:45:01.528" "221.5.17.252" "SENT: 535 Authentication failed. Restarting authentication process."
"SMTPD" 3608 34012 "2008-02-25 10:45:02.043" "221.5.17.252" "RECEIVED: AUTH LOGIN"
"SMTPD" 3608 34012 "2008-02-25 10:45:02.043" "221.5.17.252" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 3608 34012 "2008-02-25 10:45:02.606" "221.5.17.252" "RECEIVED: aW5uYQ=="
"SMTPD" 3608 34012 "2008-02-25 10:45:02.606" "221.5.17.252" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 3608 34012 "2008-02-25 10:45:03.356" "221.5.17.252" "RECEIVED: ***"
"SMTPD" 3608 34012 "2008-02-25 10:45:03.356" "221.5.17.252" "SENT: 535 Authentication failed. Restarting authentication process."
"SMTPD" 3608 34012 "2008-02-25 10:45:04.106" "221.5.17.252" "RECEIVED: AUTH LOGIN"
"SMTPD" 3608 34012 "2008-02-25 10:45:04.106" "221.5.17.252" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 3608 34012 "2008-02-25 10:45:04.684" "221.5.17.252" "RECEIVED: aW5uYQ=="
"SMTPD" 3608 34012 "2008-02-25 10:45:04.684" "221.5.17.252" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 3608 34012 "2008-02-25 10:45:05.231" "221.5.17.252" "RECEIVED: ***"
"SMTPD" 3608 34012 "2008-02-25 10:45:05.762" "221.5.17.252" "SENT: 535 Authentication failed. Restarting authentication process."
"SMTPD" 3608 34012 "2008-02-25 10:45:12.512" "221.5.17.252" "RECEIVED: AUTH LOGIN"
"SMTPD" 3608 34012 "2008-02-25 10:45:12.512" "221.5.17.252" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 3608 34012 "2008-02-25 10:45:13.215" "221.5.17.252" "RECEIVED: aW5uYQ=="
"SMTPD" 3608 34012 "2008-02-25 10:45:13.215" "221.5.17.252" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 3608 34012 "2008-02-25 10:45:13.996" "221.5.17.252" "RECEIVED: ***"
"SMTPD" 3608 34012 "2008-02-25 10:45:13.996" "221.5.17.252" "SENT: 535 Authentication failed. Restarting authentication process."
"SMTPD" 3608 34012 "2008-02-25 10:45:14.825" "221.5.17.252" "RECEIVED: AUTH LOGIN"
"SMTPD" 3608 34012 "2008-02-25 10:45:14.825" "221.5.17.252" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 3608 34012 "2008-02-25 10:45:15.496" "221.5.17.252" "RECEIVED: aW5uYQ=="
"SMTPD" 3608 34012 "2008-02-25 10:45:15.496" "221.5.17.252" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 3608 34012 "2008-02-25 10:45:16.184" "221.5.17.252" "RECEIVED: ***"
"SMTPD" 3608 34012 "2008-02-25 10:45:16.184" "221.5.17.252" "SENT: 535 Authentication failed. Restarting authentication process."
221.5.17.252 is not a allowed IP; its from China
How to determine this brute-force-attack?
Sorry POP3 log is deactivated!
