How build a mail interface
mael94420
Post by mael94420 » 2007-11-04 17:07
Hi
To begin, sorry for my english,
I try to make an user interface to get mail and send them.
HmailServer is operating. I am using a client mail to recieve them but now I wanted to know how can i do to create my web mail.
I am a developper and i need to do this interface with asp.net language because i am using the web server IIS.
Can you say me how to get mail i recieve, I am using the SQL Server database wich was creating with the installation of hmailserver.
I know how to make an interface wich will send mail with my mail server but i don't know how to do a list of my recieved emails.
I hope you understand me.
Thanks for your answer.
Mael.
Post by martin » 2007-11-04 18:11
If you want t build a web mail interface, you should use POP3 or IMAP components created for .NET. You should not connect directly to the hMailServer database for this. I'm not sure which POP3/IMAP components exists for .NET though. Google. :)
Kaan1983
Post by Kaan1983 » 2007-11-04 21:02
martin wrote:If you want t build a web mail interface, you should use POP3 or IMAP components created for .NET. You should not connect directly to the hMailServer database for this. I'm not sure which POP3/IMAP components exists for .NET though. Google. :)
I'm using COM API of hMail am I doing something wrong? :D If not mael94420 can use that too.
Post by martin » 2007-11-04 21:29
If you're using the COM API of hMailServer, your web mail client will only work with hMailServer. If you use a .NET IMAP-client, your web mail will work with any IMAP compatible email server..
mael94420
Post by mael94420 » 2007-11-05 10:54
Thanks for your awnser,
Kaan, can you say me more about "COM API of hMail" I don't know that, is it availaible with IIS?
At the moment,
it's not a real problem. I don't think having to do this thing again.
Thanks martin, i know now where i have to search to do that.
Kaan1983
Post by Kaan1983 » 2007-11-05 16:21
mael94420 wrote:Thanks for your awnser,
Sure; check the documents out online. You can also find OSAN webmail in the forum, download it and check the codes.
Kaan1983
Post by Kaan1983 » 2007-11-05 16:24
Thanks but I'm fine with the COM API and hMailServer, forget about the others :D I'm using the best ;)
