Whitelist Clarification
Infodine
Post by Infodine » 2007-09-05 22:30
I have added:
*@domain_to_let_through.com
low: 0.0.0.0
high: 255.255.255.255
to the whitelist.
The user@domain_to_let_through.com are still receiving this:
X-hMailServer-Spam: YES
X-hMailServer-Reason: The host name specified in HELO does not match IP address.
Does the Whitelist not bypass the enabled
Check Host in the Helo Command also?
Warren
Post by martin » 2007-09-05 22:36
I'm a bit confused. You should white list the sender of an email, not the recipient.
Infodine
Whitelist
Post by Infodine » 2007-09-05 22:55
Thats all I need to know because it doesn't seem to be working
if White Listing bypasses all spam checks.
The person's emails are getting through, are marked as spam because I am not deleting them and I am getting this as the reason:
So if "Check Host in the Helo Command" is enabled, is it still checked if the person is in the Whitelist.
*@thedomain.com - I'm assuming stars are usable in the Whitelist.
Warren
Post by martin » 2007-09-05 23:13
The white listing affects the "Check host in the helo command" spam test as well. An email from a white listed sender will not be treated as spam, even if the host in the helo command does not match the IP address.
Of some reason I doubt that. That's why I gave a hint in my previous response..
