I've been reading previous posts, but unable to solve this problem.
host A: hmail 511-b341 on w3k(32)-sp2, av mcafee enterprise, 512 mb, 1cpu, hosted on vmware-server 2 64b (latest build, clean build)
host B: MySQL 5.0.45 on Centos 5.3 64b , 2048 mb, 2cpu, hosted on vmware-server 2 64b (latest build, clean build)
problem scenario:
after install Myslq admin tools on host A (5.0.45) connecting to mysql instance on host B is ok and error free.
during hmail init db selection/init, installer reports libmysql.dll not found, cp into :
c:\program files\hmailserver\bin
c:\windows\system32
no joy.
error log
"ERROR" 1212 "2009-05-18 20:17:24.738" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3292 "2009-05-18 20:17:32.702" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3232 "2009-05-18 20:20:45.312" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3232 "2009-05-18 20:34:41.894" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3232 "2009-05-18 20:42:42.265" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3232 "2009-05-18 20:42:54.690" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3292 "2009-05-18 20:42:56.346" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 1212 "2009-05-18 20:42:58.315" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3232 "2009-05-18 20:42:58.769" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3292 "2009-05-18 20:42:59.066" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 1212 "2009-05-18 20:42:59.222" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3232 "2009-05-18 20:42:59.409" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3292 "2009-05-18 20:42:59.613" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 1212 "2009-05-18 20:43:00.738" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3232 "2009-05-18 20:52:03.633" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3232 "2009-05-18 20:52:14.522" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 3232 "2009-05-18 21:18:49.261" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
"ERROR" 2544 "2009-05-18 21:19:03.059" "Severity: 1 (Critical), Code: HM5094, Source: MySQLInterface::Load, Description: Error:[nl]The MySQL client (libmysql.dll, 32 bit) could not be loaded.[nl]hMailServer needs this file to be able to connect to MySQL.[nl]The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.[nl]Path: C:\Program Files\hMailServer\Bin\libmysql.dll"
mysql error log on host B is showing:
090517 20:31:41 mysqld started
090517 20:31:42 InnoDB: Started; log sequence number 0 43655
090517 20:31:42 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.0.45' socket: '/var/lib/mysql/mysql.sock' port: 3306 Source distribution
during the attempt to init the db
anyone some ideas?
kind regards,
sysbt
Hmail db init problem against external mysql instance linux.
Re: Hmail db init problem against external mysql instance linux.
You need to download libmysql.dll it does not come with hMail V5 as V5 is not open source.
Dear,
as stated initially, I've installed MySql admin tools for version 5.0 (latest) on the hmail host, and copied the corresponding file to the hmailserver\bin directory and in a second try equally c:\windows\system32 (suspecting a search path issue).
No joy.
Or am I just too quick and should regress to earlier version of the mysql edition (on linux).
kind regards,
sysbt
No joy.
kind regards,
sysbt
I was unaware libmysql came with MySQL Admin Tools and you did not mention that it did either
Try the one attached, it is the one I am using.
Hi Doom,
It seem that the libmysql from 5.0 is not yet fitted into the install scripts/calls for hmail.
The file you've send me is half the size of the 5.0 one, but it worked like a blink.
Thanks very much.
What version of mysql for crime-o-soft is this coming from?
Possibly this should be posted, as other users could run into the same sh*t. Or is the forum enough (newbe to forums)
Anyway thanks.
ps libmysql.dll is always installed with adm mysql tools.
sysbt
Thanks very much.
Anyway thanks.
sysbt
I use PHPMyAdmin and always have
libmysql.dll is not allowed to be distributed with hMail so the forums will have to do
The version i attached is the one that came with V4.
Dear Doom,
Maybe to prevent other people some loooong nights, some info for the community?
Is there a way to post this issue, in clear text, to the community?
I can/will provide the docu, but I've no idea on how to publish this (on public forums).
kind regards,
sysbt
kind regards,
sysbt
Don't worry about it. If people post in the future i'll just point them here
