Clean Install of hMailServer v5.7
Re: Clean Install of hMailServer v7
Post by mattg » 2024-02-02 01:58
ScalpWithMe wrote:
2024-02-01 06:58
I downloaded hMailServer-5.7.0-B2643-x64.exe and double-clicked it to run the Setup program - knowing in advance that it would install into Program Files instead of Program Files (x86).
hMailserver should install where it was installed previously.
I have my hmailserver 5.7 installed to C:\hmailserver
Post by mattg » 2024-02-02 09:55
still shouldn't matter because there are some registry entries made.
Uninstalling in itself is not a 'clean' un-install
Accuphaze
Post by Accuphaze » 2024-06-12 07:53
Hello!
Where do you download version hms 5.7?
I don't see a download link anywhere!
If it's not difficult, please share the link.
gotspatel
Post by gotspatel » 2024-06-12 08:45
Accuphaze wrote:
2024-06-12 07:53
Hello!
https://www.hmailserver.com/state
Best Option now HERE
Post by katip » 2024-06-12 11:09
gotspatel wrote:
2024-06-12 08:45
BTW, build.hmailserver.com don't work since a few days.
JFYI
HMS 5.7, MariaDB 10.4.10, SA 4.0.0, ClamAV 0.103.8
Post by RvdH » 2024-06-12 22:42
Accuphaze wrote:
2024-06-12 07:53
Hello!
Latest builds (and mods) can be found here (i placed the official installers there recently when i noticed the buildserver was offline)
https://d-fault.nl/files/hMailServer-Builds
Mod instructions, as katip already posted, can be found HERE
katip wrote:
2024-06-12 11:09
gotspatel wrote:
2024-06-12 08:45
JFYI
Make that weeks
gotspatel
Post by gotspatel » 2024-06-13 06:14
2024-06-12 22:42
Accuphaze wrote:
2024-06-12 07:53
Hello!
katip wrote:
2024-06-12 11:09
gotspatel wrote:
2024-06-12 08:45
JFYI
Make that weeks
@RvdH
upon clicking 5.6.9-B2641.68-OpenSSL-3.0.14.7z link it gives file 5.6.9-B2641.68.7z
please check
Regards
Post by RvdH » 2024-06-13 08:25
:oops:
I have some IIS Rewrite redirection in place that redirects previous/old 5.6.x versions, should be fixed now
<rule name="hMailServer Latest Build" stopProcessing="true" enabled="true">
   <match url="5\.6\.[6789]\-B\d{4}\.\d+.*\.7z" />
   <conditions trackAllCaptures="true">
      <add input="{REQUEST_FILENAME}" matchType="IsFile" />
      <add input="{REQUEST_FILENAME}" pattern="5.6.9-B2641.68.7z" negate="true" />
      <add input="{REQUEST_FILENAME}" pattern="5.6.9-B2641.68-OpenSSL-3.0.14.7z" negate="true" />
   </conditions>
   <action type="Redirect" url="5.6.9-B2641.68.7z" appendQueryString="false" redirectType="Found" />
</rule>
