libmysql.dll (32-Bit)
Post by Dravion » 2022-08-17 19:00
To support hMailServer Users wishing to install hMailServer with MySQL (64-Bit or 32-Bit) i add the required libmysql.dll file which is required to
install hMailServer successfully. Because of historic reasons, hMailServer went a while to a closed source model but the license libmysql.dll is redistributed demanded it can only redistributed as part of a OpenSource application. However: Since hMailServer5.x is OpenSource again, it is allowed to redistribute libmysql.dll again
libmysql.dll.zip
(1.94 MiB) Downloaded 65 times
Zip contains:
*The License file
*libmysql.dll (MySQL 5.37 32-Bit) which can be used for 32-Bit and 64-MySQL versions also for MySQL v8 to let hMailServer connect.
Just copy the libmysql.dll file into your hMailServer\bin folder at the Database creation step if you get the Error message "libmysql.dll"
is required but cannot be found. Stay in the Installer, copy the libmysql in the hMailServer\bin folder, switch back to setup, press
"previous" button and the "next" button again - the Error will be gone and the installation will successfully finish.
Quote from the License:
1. You may copy and distribute verbatim copies of the Program's
source code as you receive it, in any medium, provided that you
conspicuously and appropriately publish on each copy an appropriate
copyright notice and disclaimer of warranty; keep intact all the
notices that refer to this License and to the absence of any warranty;
and give any other recipients of the Program a copy of this License
along with the Program.
2. You may modify your copy or copies of the Program or any portion
of it, thus forming a work based on the Program, and copy and
distribute such modifications or work under the terms of Section 1
above, provided that you also meet all of these conditions:
Virustotal Scan results:
https://www.virustotal.com/gui/url/968f ... ?nocache=1
