HOW TO: Accessing the INTERNAL Database tables
Post by jimimaseye » 2022-03-25 15:42
The internal Database does not come with any tools that allows view/interogation or update of the tables within. Access to the internal database would require extra 3rd party software. I have used DatabaseBrowserPortable (original found here).
To access the internal database using DatabaseBrowserPortable you wll need the database password:
  • a, open your HMAILSERVER.INI file and select the 'password' string under
    Password=a2bd344fc6608264d2d6b3ca2f89303
    b, Run hmailsever/Addons/Utilities/DecryptBlowfish.vbs and where prompted enter the string copied. This will create and display a short string of characters (this is the password). Copy this string of characters.
    c, Run DatabaseBrowserPortable, and choose 'Connections - Add' and point to your internal Data directory database (remember to choose MSSQL CE as database type). Enter "Hmailserver" as the User name and the above decrypted string as the password.
Done.
(If you want the benefit of easy access to Administration of the database in the future, you might also consider upgrading to an external database - see here for a guide)
Re: HOW TO: Accessing the INTERNAL Database tables
Post by Dravion » 2022-03-25 18:38
Good Job!
glenluo
Post by glenluo » 2022-03-27 07:39
Thanks,it is really a good software.
Post by Dravion » 2022-03-28 16:16
glenluo wrote:
2022-03-27 07:39
I want add this Program, it servers me well in working with SQL CE Databases and is still somewhat up to date
https://github.com/christianhelle/sqlcequery/releases
PS: If you want to open the hmailServer SDF file, please make sure you start your tool as Admin and hMailServer Service is stopped
or the file is locked :)
glenluo
Post by glenluo » 2022-03-30 15:02
Dravion wrote:
2022-03-28 16:16
glenluo wrote:
2022-03-27 07:39
TKS
