SSL with hMailServer can be a bit frustrating.
If you just want a self signed certificate to enable SSL/TLS encryption, u can use this SSL CA and it's generated SSL Wildcard Certificate
Hint:
File: hmail_ca.pem is the Root CA Certificate which the Wildcard SSL-Certificated is based on.
It is valid for any DNS-Name *.hmail-cert.net Domain name (if you can configure your local DNS-Server, this is the CName it should point to)
You can install it by using Windows Certificate Manager (as Admin) or by open a Windows Command prompt and running the command
certutil -addstore root hmail_ca.pem (required by MS-Outlook, Windows Mail or other Email Clients using the Windows Trust store.
For Thunderbird you need to add it inside Thunderbird to the list of Root certificates to avoid SSL-Warnings in Thunderbird.
Usage
1) Download the attached certs.zip file and unzip it
2) Copy the folder "certs" to C:\Program Files (x86)\hMailServer\certs (or where you installed hMailServer)
3) Open hMailAdmin and under SSL add the file hmail-cerr.crt and hmail-cert.key
SSL-Selfcert bundle
SSL-Selfcert bundle
- Attachments
- certs.zip
- (4.68 KiB) Downloaded 241 times
- New user
Re: SSL-Selfcert bundle
Dravion, thanks for your guide.
if i use this solution, is it possible to use any mobile mail clients that connect directly from the outside to the hMailServer?
Thanks.
Alessio.
Thanks.
Alessio.
Hi,alessionet wrote: ↑2022-05-09 18:50Dravion, thanks for your guide.
Thanks.
Alessio.
It should be possible but you will get a warning and you have skip everytime or allow a permanent exception if the Warning Dialog comes
up on your Email App (this is bc the SSL certs are not signed by a known Certification Authority like Verisign.
Encryption will work never the less 100%
