Can not send Email Outside and inside from Hmailserver
Deira
Post by Deira » 2021-06-11 04:07
Hi
I have installed hmailserver in may PC Server windows Server 2012, all configuration was green
but I can not send email form hmailserver,
Test: Collect server details
Database type: MSSQL Compact
Test: Test IPv6
Test: Test outbound port
SMTP relayer is in use.
Local address is 192.168.3.10.
Trying to connect to host 192.168.3.10...
Trying to connect to TCP/IP address 192.168.3.10 on port 25.
Received: 220 192.168.3.10 ESMTP.
Connected successfully.
Test: Test backup directory
Backup directory C:\Users\Administrator\Desktop\EmailBackups is writable.
Test: Test MX records
Trying to resolve MX records for chega.tl...
Host name found: chega.tl
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain chega.tl...
Trying to connect to host chega.tl...
Trying to connect to TCP/IP address 103.102.0.28 on port 25.
Received: 220-lavender.ardetamedia.net ESMTP Exim 4.94.2 #2 Fri, 11 Jun 2021 08:45:39 +0700 .
Re: Can not send Email Outside and inside from Hmailserver
Post by mattg » 2021-06-11 04:22
You set your own IP address as the SMTP relayer
Remove that and leave it blank, unless you are using an external relay
Post the new internal diagnostics, and also run this and post the results
viewtopic.php?f=20&t=30914
Deira
Post by Deira » 2021-06-21 03:57
Hi Matt
I have remove the Local IP but it still can not send email from h mail server here is the diagnosis test
Test: Test IPv6
Received: 220-lavender.ardetamedia.net ESMTP Exim 4.94.2 #2 Mon, 21 Jun 2021 08:52:22 +0700 .
Post by mattg » 2021-06-21 05:53
2021-06-11 04:22
Deira wrote:
2021-06-21 03:57
That seems to be an EXIM server, not a hMailserver
Deira
Post by Deira » 2021-06-21 07:49
Hi Mattg
What is EXIM for? is there other way to fix the issues?
johang
Post by johang » 2021-06-21 08:38
2021-06-21 05:53
2021-06-11 04:22
Deira wrote:
2021-06-21 03:57
Deira wrote:
2021-06-21 07:49
Hi Mattg
Please help Mattg to be able to help you by doing what he asked:
FOLLOW the instructions on viewtopic.php?f=20&t=30914
post THAT result here...
regarding EXIM
Mattg noticed that it is an EXIM email server administered by Ardetamedia that responds to chega.tl and it is not your hmailserver that is in charge of chega.tl; this may very well be thought out and considered by you.. but that test do NOT test YOUR hmailserver but rather the EXIM server... ( so if you get a green ok, it is not green ok for YOUR hmaiulserver it is a green OK for Ardermedias installed EXIM-emailserver )
lets cheat darwin out of his legacy, find a cure for cancer...
