auto forward from localhost to pop server
jvanwalleghen1
Post by jvanwalleghen1 » 2020-02-21 06:03
I have an application that can send out emails to alert users but it cannot support ssl/tls. I thought I could use hMailServer to act as a relay between the app and my regular pop mail server. I put a host entry for 127.0.0.1 MyMail.org. In HMS I added a domain MyMail.org and an account MetaTrader@MyMail.org. In MetaTrader I enabled forwarding to myuser@cox.net. What else do I need to do?
jvanwalleghen1
Re: auto forward from localhost to pop server
Post by jvanwalleghen1 » 2020-02-21 06:38
I forgot to mention that I filled out SMTP:Delivery of e-mail with SMTP Relayer of pop.cox.net port 995, checked server requires auth and entered my username and password. Connection security set to SSL/TLS.
Post by mattg » 2020-02-21 13:16
that should work
Does it?
Post by RvdH » 2020-02-21 14:21
User-submitted tutorials :?: :!:
jvanwalleghen1
Post by jvanwalleghen1 » 2020-02-21 17:43
My Meta Trader app says that the test message was successfully queued and then reports Test Message failed. I had most logging turned on.
"APPLICATION" 2108 "2020-02-21 09:21:50.069" "Servers started."
"DEBUG" 2888 "2020-02-21 09:36:00.542" "Creating session 5"
"DEBUG" 2888 "2020-02-21 09:36:00.542" "TCP connection started for session 1"
"SMTPD" 2888 1 "2020-02-21 09:36:00.542" "127.0.0.1" "SENT: 220 MyMail.org ESMTP"
"DEBUG" 2924 "2020-02-21 09:36:00.558" "The read operation failed. Bytes transferred: 0 Remote IP: 127.0.0.1, Session: 1, Code: 2, Message: End of file"
"DEBUG" 2924 "2020-02-21 09:36:00.558" "Ending session 1"
"DEBUG" 2888 "2020-02-21 09:36:00.558" "Creating session 6"
"DEBUG" 2888 "2020-02-21 09:36:00.558" "TCP connection started for session 5"
"SMTPD" 2888 5 "2020-02-21 09:36:00.558" "127.0.0.1" "SENT: 220 MyMail.org ESMTP"
"SMTPD" 2908 5 "2020-02-21 09:36:00.558" "127.0.0.1" "RECEIVED: HELO Johns-workpc"
"SMTPD" 2908 5 "2020-02-21 09:36:00.558" "127.0.0.1" "SENT: 250 Hello."
"SMTPD" 2888 5 "2020-02-21 09:36:00.558" "127.0.0.1" "RECEIVED: MAIL FROM: <vanwall@southwind.net>"
"DEBUG" 2888 "2020-02-21 09:36:00.604" "Total spam score: 0"
"SMTPD" 2888 5 "2020-02-21 09:36:00.620" "127.0.0.1" "SENT: 250 OK"
"SMTPD" 2924 5 "2020-02-21 09:36:00.620" "127.0.0.1" "RECEIVED: RCPT TO: <jvanwalleghen1@cox.net>"
"SMTPD" 2924 5 "2020-02-21 09:36:00.620" "127.0.0.1" "SENT: 530 SMTP authentication is required."
"SMTPD" 2924 5 "2020-02-21 09:36:00.620" "127.0.0.1" "RECEIVED: QUIT"
"DEBUG" 2924 "2020-02-21 09:36:00.636" "Deleting message file."
"SMTPD" 2924 5 "2020-02-21 09:36:00.636" "127.0.0.1" "SENT: 221 goodbye"
"DEBUG" 2900 "2020-02-21 09:36:00.636" "Ending session 5"
My Cox account did not show a test message.
Post by jimimaseye » 2020-02-21 20:37
It wasn't received in the first place.
