LetsEncrypt + Wilcard + cloudflare
bagu
Post by bagu » 2019-09-27 14:21
Here is a small tutorial to get Letsencrypt wildcard easily with Posh-Acme and Cloudflare (thanks to palinka)
It auto-create Cloudflare DNS TXT.
  1. Launch powershell as an admin
  2. Remove restrictions with :
    set-executionpolicy unrestricted
  3. Install Posh-ACME with this command :
    Install-Module -Name Posh-ACME
  4. Set the server as a production server (to use a staging server, replace LE_PROD by LE_STAGE) :
    Set-PAServer LE_STAGE
  5. Set cloudflare param with :
    $pArgs = @{ CFAuthEmail=cloudflareemail@email.com'; CFAuthKey='cloudflarepassword' }
  6. Ask a new certificate with :
    New-PACertificate '*.domain1oncloudflare.com','*.domain2oncloudflare.org' -AcceptTOS -Contact my@email.com -DnsPlugin Cloudflare -PluginArgs $pArgs -Verbose
  7. Follow screen instructions on powershell
  8. Then, search your certificate with :
    Get-PACertificate | fl
  9. Get cert.key as key and fullchain.cer as public certificate and insert them in Hmailserver
Then, you can make a planned task to renew the certificate every 85days with a script witch contain :
Submit-Renewal -PluginArgs @{CFAuthEmail='cloudflareemail@email.com'; CFAuthKey='cloudflarepassword'}
Don't forget to get the renewed certificate and copy them to the folder where hmailserver is set to get them.
And, don't forget to restart hmailserver
I will put here an example of script wich renew, copy and restart hmailserver later.
If you have any tips to improve or modify this tutorial, do not hesitate to propose your modifications.
Re: LetsEncrypt + Wilcard + cloudflare
Post by palinka » 2019-09-27 15:07
đź‘Ť
