Hardening hMailServer - The ongoing saga!
udgesbou
Re: Hardening hMailServer - The ongoing saga!
Post by udgesbou » 2022-04-29 17:32
Hey palinka,
perhaps you can help me by another question.
Can i exclude IPs from beeing checked from the script? Like whitelisting or so?
If it's possible, how can i do this?
Thank you!
Post by palinka » 2022-04-29 21:10
udgesbou wrote:
2022-04-29 17:32
Hey palinka,
Thank you!
Sure. There's a couple of ways.
First, always exclude local mail and backup from tests that should be for incoming mail, or tests for untrusted IPs.
Sub OnClientConnect(oClient)
	REM - Exclude Backup-MX & local LAN from test
	If (Left(oClient.IPAddress, 12) = "184.105.182.") Then Exit Sub ' junkemailfilter.com backup mx
	If (Left(oClient.IPAddress, 11) = "192.168.22.") Then Exit Sub  ' local LAN
	If oClient.IPAddress = "127.0.0.1" Then Exit Sub                ' localhost
	' Continue processing incoming connections
Secondly, I made a whitelisting function to check IPs against WL-RBLs. This requires RvdH's DNS Resolver: https://d-fault.nl/files
Function IsWhitelisted(strIP) : IsWhitelisted = False
	Dim a : a = Split(strIP, ".")
	Dim strLookup, strRegEx
	Dim IsWLMailSpike, IsWLHostKarma, IsWLNSZones, IsWLSPFBL, IsWLSpamDonkey, IsWLIPSWhitelisted
		strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".rep.mailspike.net")
	strRegEx = "^127\.0\.0\.(19|20)$" '18=Good, 19=Very Good, 20=Excellent Reputation
	IsWLMailSpike = Lookup(strRegEx, strLookup)
		strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".hostkarma.junkemailfilter.com")
	strRegEx = "^127\.0\.0\.(1|5)$" '1=Good, 5=NoBL
	IsWLHostKarma = Lookup(strRegEx, strLookup)
		strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".wl.nszones.com")
	strRegEx = "^127\.0\.0\.5$" '5=whitelisted
	IsWLNSZones = Lookup(strRegEx, strLookup)
		strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".dnswl.spfbl.net")
	strRegEx = "^127\.0\.0\.(2|3|4|5)$" '2=excellent rep, 3=indispensable public service, 4=corp email (no marketing), 5=safe bulk mail
	IsWLSPFBL = Lookup(strRegEx, strLookup)
		strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".dnsbl.spamdonkey.com")
	strRegEx = "^126\.0\.0\.0$" '126.0.0.0=whitelisted
	IsWLSpamDonkey = Lookup(strRegEx, strLookup)
		strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".ips.whitelisted.org")
	strRegEx = "^127\.0\.0\.2$" '2=whitelisted
	IsWLIPSWhitelisted = Lookup(strRegEx, strLookup)
	If (IsWLMailSpike OR IsWLHostKarma OR IsWLNSZones OR IsWLSPFBL OR IsWLSpamDonkey OR IsWLIPSWhitelisted) Then ISWhitelisted = True
If NOT(IsWhitelisted(strIP)) Then
	' do stuff here to non-whitelisted IPs
-- or - like above --
	If IsWhitelisted(strIP) Then Exit Sub
I use the IsWhitelisted function to exclude from geoip testing with the idea that I can ban many countries with geoip, but still allow whitelisted IPs from banned countries through.
udgesbou
Post by udgesbou » 2022-04-30 16:11
2022-04-29 21:10
Yeah this is what i am looking for.
Do i have to put this in "Eventhandler.vbs" or "Handler.vbs"?
And where can i define the whitelisted IPs, for example 94.105.266.80?
Post by palinka » 2022-04-30 19:18
udgesbou wrote:
2022-04-30 16:11
2022-04-29 21:10
It goes in eventhandlers.vbs.
YOU don't define anything. These are public RBLs doing the checking for you. They define their own whitelists.
udgesbou
Post by udgesbou » 2022-04-30 20:37
2022-04-30 19:18
Okay, but i one IP i want to exclude from checking.
udgesbou wrote:
2022-04-30 16:11
Is this what i have to do?
	If (Left(oClient.IPAddress, 12) = "94.105.266.80") Then Exit Sub ' MY IP THAT I WANT TO EXLUDE
Greetings
Post by palinka » 2022-05-01 00:22
udgesbou wrote:
2022-04-30 20:37
2022-04-30 19:18
udgesbou wrote:
2022-04-30 16:11
Greetings
Yes.
tunis
Post by tunis » 2022-05-03 11:56
udgesbou wrote:
2022-04-30 20:37
Greetings
For specific IP use
If oClient.IPAddress = "94.105.266.80" Then Exit Sub ' MY IP THAT I WANT TO EXLUDE
Left are only used for ranges (length of charts to compare from left)
HMS 5.6.9 B2602.53 on Windows Server 2016 Core VM.
udgesbou
Post by udgesbou » 2022-12-06 13:00
Hey,
since two days i can't connect to my hMailServer via Outlook, Android Mail or so.
I think one reason could be my geoblocking. I only allowed ip addresses from germany.
But in my "hmailserver_events.log" i only get these results:
12260	"2022-12-06 11:14:24.036"	"- GeoLookup(60.217.75.70) = zz"
4252	"2022-12-06 11:43:14.268"	"- GeoLookup(91.15.34.229) = zz"
4252	"2022-12-06 11:43:34.471"	"- GeoLookup(80.187.102.198) = zz"
The hmailserver.log looks like this at 11:43:14:
"DEBUG"	4252	"2022-12-06 11:43:14.236"	"Creating session 38"
"TCPIP"	4252	"2022-12-06 11:43:14.252"	"TCP - 91.15.34.229 connected to MYIPADDRESS:465."
"DEBUG"	4252	"2022-12-06 11:43:14.252"	"Executing event OnClientConnect"
"DEBUG"	4252	"2022-12-06 11:43:14.268"	"Event completed"
"DEBUG"	4252	"2022-12-06 11:43:14.268"	"Ending session 37"
I only got "zz". I tried it from differet IPs from Germany, but i only got "zz" and not "de". It is since the 04.12.2022.
Can anyone help me, how i can fix that?
Thanks in advance :D
Post by RvdH » 2022-12-06 13:15
Looks like countries.nerd.dk has some issue, might be temporary or maybe it is permanently gone (don't think it was maintained actively anyway)
; <<>> DiG 9.16.34 <<>> 100.232.204.81.zz.countries.nerd.dk TXT
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 47380
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
; COOKIE: 98c1cb9aed04b11101000000638f23d8396910e6ca9806ce (good)
;; QUESTION SECTION:
;100.232.204.81.zz.countries.nerd.dk. IN TXT
;; Query time: 15 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Tue Dec 06 12:13:28 W. Europe Standard Time 2022
;; MSG SIZE rcvd: 92
Maybe you could substitute it with country.junkemailfilter.com?
; <<>> DiG 9.16.34 <<>> 100.232.204.81.country.junkemailfilter.com TXT
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 16008
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
; COOKIE: ebb327ea90df677401000000638f2515af071c78656b0bd3 (good)
;100.232.204.81.country.junkemailfilter.com. IN TXT
;; ANSWER SECTION:
100.232.204.81.country.junkemailfilter.com. 21600 IN TXT "nl"
;; Query time: 1633 msec
;; WHEN: Tue Dec 06 12:18:45 W. Europe Standard Time 2022
;; MSG SIZE rcvd: 114
udgesbou
Post by udgesbou » 2022-12-06 13:18
2022-12-06 13:15
;; Got answer:
Oh okay, thanks for your very fast research and reply.
Is there any alternatie known which could possibly use? :(
EDIT:
2022-12-06 13:15
;; Got answer:
;; ANSWER SECTION:
Oh this could be an option, so i have to change "zz.countries.nerd.dk" to "country.junkemailfilter.com"?
Post by RvdH » 2022-12-06 13:22
I think there is a slight difference between them for England, if i remember right is discovered by countries.nerd.dk as "uk" whereas country.junkemailfilter.com returns "gb" (might be more irregularities)
Post by RvdH » 2022-12-06 13:23
udgesbou wrote:
2022-12-06 13:18
Yep, that should be enough
udgesbou
Post by udgesbou » 2022-12-06 13:32
2022-12-06 13:22
Okay, but i would only allow connections from germany anyway, so i would only need the return for germany. Is it possible to research this somewhere? Or is it "de"?
2022-12-06 13:23
Okay so it should look like this?:
EventHandlers.vbs
Function GetDatabaseObject()
   Set GetDatabaseObject = oApp.Database
Function GeoLookup(strIP) : GeoLookup = "zz"
   Dim a, element, group, strLookup
      strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & "country.junkemailfilter.com")
   If Trim(strLookup) = "" Then
      EventLog.Write( "- GeoLookup(" & strIP & ") = " & GeoLookup )
      Exit Function
   group = Split(strLookup, vbCrLf)
   If UBound(group) > 0 Then
      For Each element In group
         If (Trim(element) <> "") Then EventLog.Write( "- GeoLookup(" & strIP & ") = " & element )
      GeoLookup = group(0)
   '   Exclude local LAN from test
   If (Left(oClient.IPAddress, 12) = "MYIPADDRESS") Then Exit Sub ' MEDIUM Cloud
   If (Left(oClient.IPAddress, 10) = "192.168.0.") Then Exit Sub ' Local
   '   Only allow non-SMTP connect from "Rigsfællesskabet"/"Naalagaaffeqatigiit"/"Ríkisfelagsskapurin" = The Danish Realm.
   '   zz = N/A, dk = Denmark, gl = Greenland, fo = Faroe Islands
   If (oClient.Port <> 25) Then
      If (InStr("de", GeoLookup(oClient.IPAddress)) = 0) Then
         '   Add unauthorized access to IDS registry
         Call idsAddIP(oClient.IPAddress, oClient.Port)
         Result.Value = 1
         Exit Sub
   '   Only test SMTP traffic on defined ports 25, 587 and 465.
   '   Register IP address in IDS registry.
   If (InStr("|25|587|465|", oClient.Port) > 0) Then Call idsAddIP(oClient.IPAddress, 0)
'* Sub OnHELO(oClient)
'* End Sub
Or should it be called something else? ".zz.country.junkemailfilter.com"?
This is the actuall EventHandlers.vbs:
      strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".zz.countries.nerd.dk")
      Exit Function
         Result.Value = 1
         Exit Sub
'* End Sub
Post by RvdH » 2022-12-06 13:35
it is "de"
; <<>> DiG 9.16.34 <<>> 229.34.15.91.country.junkemailfilter.com TXT
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 37014
; COOKIE: 7129c829559b875901000000638f28e333e400f7fa7c13bd (good)
;229.34.15.91.country.junkemailfilter.com. IN TXT
;; ANSWER SECTION:
229.34.15.91.country.junkemailfilter.com. 21600 IN TXT "de"
;; Query time: 281 msec
;; WHEN: Tue Dec 06 12:34:59 W. Europe Standard Time 2022
;; MSG SIZE rcvd: 112
Post by RvdH » 2022-12-06 13:43
Country Code List
Junk Email Filter now provides a country code IP lookup. Just used the standard IP lookup (reversed) and read the TXT record and it returns a 2 character country code.
4.3.2.1.country.junkemailfilter.com TXT
Return code of "zz" means the country is unknown.
https://wiki.junkemailfilter.com/index. ... _DNS_Lists
udgesbou
Post by udgesbou » 2022-12-06 13:44
2022-12-06 13:35
it is "de"
Thank you!
I tried this EventHandlers.vbs Config, but the result is still "zz" :(
      strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".zz.country.junkemailfilter.com")
      Exit Function
         Result.Value = 1
         Exit Sub
'* End Sub
I tried it with different german-IPs :(
Or it ".zz.country.junkemailfilter.com" the wrong address?
Post by RvdH » 2022-12-06 13:54
Yes, read above
udgesbou
Post by udgesbou » 2022-12-06 14:04
2022-12-06 13:43
So i have to use this "4.3.2.1.country.junkemailfilter.com TXT" or "4.3.2.1.country.junkemailfilter.com"?
I read also in Wiki, but i am a big noob in such things :(
Post by RvdH » 2022-12-06 14:09
      strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".country.junkemailfilter.com")
udgesbou
Post by udgesbou » 2022-12-06 14:18
2022-12-06 14:09
OMG, now it works, i can connect to my hMailServer :idea: :idea: :!: :!:
Thank you very very much for for help and your patience.
In hmailserver_events.log i got still the result "zz", but i can connects and receive and send mails. I dont know why i got no "de" as result?
Post by RvdH » 2022-12-06 15:39
udgesbou wrote:
2022-12-06 14:18
2022-12-06 14:09
That sounds weird, did you reload scripts?
Post by RvdH » 2022-12-06 15:53
Ah, i see... EventLog.Write is only called when none or multiple entries are returned.... not for successful lookups
Not even sure if multiple is possible here, the lookup against nerds.dk had the odd behavior to sometimes return multiple results, example: "nl" and "eu"
udgesbou
Post by udgesbou » 2022-12-06 15:55
2022-12-06 14:09
Yeah, I reload Scripts and restart hmailserver, but still result "zz" :(
2022-12-06 15:53
Oh dear, I don't know what that mean :(
Post by RvdH » 2022-12-06 15:58
It only logs failures as said before, if you like to log successful lookups change the function like:
      Exit Function
      EventLog.Write( "- GeoLookup(" & strIP & ") = " & group(0))
udgesbou
Post by udgesbou » 2022-12-06 17:07
2022-12-06 15:58
      Exit Function
That works pretty well, thank you very very much my friend :wink: :idea:
Post by RvdH » 2022-12-06 20:29
Post by mattg » 2022-12-09 02:55
2019-01-28 17:09
ActiveX object DNSLibrary can be obtained from https://d-fault.nl/files/DNSResolverCom ... .3.exe.zip
Link is broken
I see that RvdH has listed newer versions
Post by RvdH » 2022-12-09 13:08
2022-12-09 02:55
2019-01-28 17:09
Link is broken
I created a redirect DNSResolverComponent_1.3.exe.zip to DNSResolverComponent_1.3.1.2.exe.zip
DNSResolverComponent_1.3.1.2 uses UDP and requires .NET 3.5 (using HeijdenDNS)
DNSResolverComponent_1.4.1.2 uses TCP and requires .NET 4.5 (using HeijdenDNS)
DNSResolverComponent_1.4.5.0 is a complete rewrite with more options, eg: you can choose bewteen UDP and TCP, TCP fallback, set UDP packet size and requires .NET 4.5 (using DnsClient.NET)
(i think :) )
1.4.5.0
This object has 28 public functions:
-- SetTimeout(<int [1-10]>) * default 1
-- SetRetries(<int [1-10]>) * default 3
-- SetRecursion(<bool>) * default true
-- SetServer(<string IPv4 or IPv6>) * default none
-- SetEdnsPacketSize(<int [512-4096]>) * default 4096
-- SetTcpFallback(<bool>) * default true
-- SetTcpOnly(<bool>) * default false
-- GetTimeout() * returns Timeout value
-- GetRetries() * returns Retries value
-- GetRecursion() * returns Recursion value
-- GetServer() * returns Server value (if any)
-- GetEdnsPacketSize() * returns edns packet size value
-- GetTcpFallback() * returns TCPFallback value
-- GetTcpOnly() * returns TCPOnly value
-- Version() * returns the version number
-- Help() * shows this help
-- IPv4A(<Domain name>) * query IPv4 A-Record(s)
-- A(<Domain name>) * same as IPv4A (deprecated)
-- DNSLookup(<Domain name>) * same as IPv4A (deprecated)
-- IPv6A(<Domain name>) * query IPv6 A-Record(s)
-- AAAA(<Domain name>) * same as IPv6A (deprecated)
-- CAA(<Domain name>) * query CAA-Record
-- CNAME(<Domain name>) * query CNAME-Record(s)
-- MX(<Domain name>) * query MX-Record(s)
-- NS(<Domain name>) * query NS-Record(s)
-- PTR(<IP address>) * query PTR-Record
-- SOA(<Domain name>) * query SOA-Record
-- TXT(<Domain name>) * query TXT-Record(s)
Example:
Private Const DnsServer = "127.0.0.1"
Private Const DnsExtendedDnsBufferSize = 1232
Private Const DnsTimeOut = 5
Private Const DnsRetries = 2
    .SetServer(DnsServer)
    .SetEdnsPacketSize(DnsExtendedDnsBufferSize)
    .SetTimeout(DnsTimeOut)
    .SetRetries(DnsRetries)
Jorgo
Post by Jorgo » 2022-12-17 23:11
Too sad about countries.nerd.dk, but there seems to be an alternative for country blocking with country.junkemailfilter.com
Unfortunately, I am not as sophisticated as many here so I have to take little baby steps in how I change my setup. I'm gathering that I cannot simply swap out my country-based DNS blacklists in hmailserver by replacing, say "cn.countries.nerd.dk" by "country.junkemailfilter.com". One is testing for a country and if the result is "yes" then the message is rejected whereas with country.junkemailfilter.com there are no predefined IP blocks so the answer to the query is not "yes" nor "no" but "country".
Hm. So what you are doing now is letting a script do the lifting of getting the country first and then checking the result against white- or black-listed countries in your own config? That would be the way for me, unfortunately I cannot simply allow connections from country but need a few more as well as to not shut out Goggle, Hootmail, etc. Perferably, white-listing should be used and all other countries rejected. However, I have no idea how to use external programs for this, like the "resolver". Could someone give me a pointer where I can read up on this? I'm not running hmailserver on Windows server though, just a workstation.
Jorgo
Post by Jorgo » 2022-12-17 23:26
The inbuilt DNS blacklist thing is really great, though, as it let's you use finegrained reactions via scoring. Too bad country.junkemailfilter.com can't be used with that directly!
Edit: Hang on, hang on... I feel a tingle in my toes...
Is this supposed to work?
Imagehttps://imgur.com/a/siuEk9s
Post by palinka » 2022-12-18 00:39
Jorgo wrote:
2022-12-17 23:26
No, that won't work because the answer will be an IP address like 127.0.0.2. The reply will be NX domain always.
If you can make a query work using nslookup, then it will work as a custom dnsbl like you tried to do with it.
Your best bet is to try to make the script above work, or if you prefer using local query with mysql, then you can check this one out: viewtopic.php?f=9&t=34496
Jorgo
Post by Jorgo » 2022-12-18 00:56
Thanks, you seem to be on top of it. Although I'm running MySQL in MariaDB flavour, the thread you referenced unfortunately is very long, still seems to be ongoing and I can't make out which post contains the complete final script. Probably should be in .sql format so it could be imported into the database but all that is a bit over my head.
Jorgo
Post by Jorgo » 2022-12-18 16:28
OK, I've got logging working, same as @udgesbou above. Now I would like to immediately disconnect any country not in my whitelist. In his script I see
         Result.Value = 1
         Exit Sub
that "Only allow Danish Realm" is commented but then it seems to target only "de". I guess I would expand the country list like
    If (InStr("de|us|fr"", GeoLookup(oClient.IPAddress)) = 0) Then
Also, for the Call to idsAddIP I guess I have to backtrack to @SorenR 's original concept from 2019 and start experimenting...
Jorgo
Post by Jorgo » 2022-12-18 17:35
Alright, does anyone spot syntax errors or call nonsense?
      Exit Function
   '   Autoban unwanted countries for 1 day
   '   1. Exclude local LAN from test
   If (Left(oClient.IPAddress, 10) = "192.168.1.") Then Exit Sub
   '   2. Only allow non-SMTP connections from some countries (remember where you might be in your holidays + VPN!)
   '   Examples: zz = N/A, de = Germany, us = USA, nl = Holland, be = Belgium, fr = France, at = Austria, ch = Switzerland
      If (InStr("de|us|at", GeoLookup(oClient.IPAddress)) = 0) Then
         Result.Value = 1
         EventLog.Write(oClient.IPAddress & vbTab & oClient.Port)
         Call AutoBan(oClient.IPAddress, "InStr" & oClient.Port, 1, "d")
         Exit Sub
   '   3. Only allow SMTP connections from some countries (breaking RFC)
   If (oClient.Port = (25|587|465)) Then
      If (InStr("de|us|be|nl|fr|at|ch)", GeoLookup(oClient.IPAddress)) = 0) Then
         Result.Value = 1
         Exit Sub
    Call oApp.Authenticate(ADMINISTRATOR, MYPASSWORD)
    With LockFile(oApp.Settings.Directories.TempDirectory & "\autoban.lck")
       On Error Resume Next
       If (oApp.Settings.SecurityRanges.ItemByName("Auto-ban: (" & sReason & ") " & sIPAddress) Is Nothing) Then
             .Name = "Auto-ban: (" & sReason & ") " & IPAddress
             .LowerIP = sIPAddress
             .UpperIP = sIPAddress
             .Priority = 20
             .Expires = True
             .Save
       On Error Goto 0
       .Close
Post by RvdH » 2022-12-18 21:34
my experience, country.junkemailfilter.com is not that accurate, i had several NL based IP's being blocked
https://github.com/RvdHout/GeoLite2SQL (basically the same as https://github.com/palinkas-jo-reggelt/GeoLite2SQL, but with original database format/column names and MySQL.Data.dll embedded)
https://www.hmailserver.com/forum/viewt ... 67#p244167
Post by palinka » 2022-12-19 09:49
I had a peek at your code and noticed something. I was going to post an issue on your github but issues don't seem to be available on this repository. Anyway:
https://github.com/RvdHout/GeoLite2SQL/ ... L.ps1#L210
You should change the url to your own github address because if you make changes, no one that has downloaded it will know. And if I make changes, your downloaders will think there was an update when there wasn't. :D
Post by RvdH » 2022-12-19 10:46
2022-12-19 09:49
Good one, better now?
Post by palinka » 2022-12-19 14:59
2022-12-19 10:46
2022-12-19 09:49
Yeah, looks good. Address resolves properly. Don't forget to update version.txt when you make updates.
I wonder if there's some github api function that can do this automatically. :?:
