Hardening hMailServer - The ongoing saga!
CraigT
Re: Hardening hMailServer - The ongoing saga!
Post by CraigT » 2020-05-02 08:37
SorenR(or other guru) are there any rules around the ODBC driver that has to be installed for either the 64/32-bit driver in Part 3 or doesn't it matter. If everything is 64-bit obviously use the 64-bit driver, but if hMail is 32-bit using 32-bit mysql.dll and MySQL is V8.x(64-bit) should I stick with the 32-bit driver or we don't care.
Post by SorenR » 2020-05-02 12:33
CraigT wrote:
2020-05-02 08:37
I'm still running 32-bit on my old server but as far as I can read, your driver need to follow your database, however there are other issues with the latest versions of MySQL. Perhaps MariaDB is worth looking into :wink:
There are only two difficult problems in computer science: naming things, cache invalidation and off-by-one errors.
Post by palinka » 2020-05-03 17:58
2020-05-02 12:33
+1
32bit ODBC required for 32bit hmailserver. Its a pain in the rear to sort out. MariaDB has (I think) only one connector (32/64).
CraigT
Post by CraigT » 2020-05-04 08:09
Got it. Thanks guys. Waiting on the 64-bit hMailserver for a production server to do the update so everything is 64-bit, but Soren's scripts are too good to pass up, as the server seems to have an attraction to "sheskyhigh" and "blueskyhotel" plus a few others just connecting and dropping out. Plus it will make the log file much shorter. :D
Post by RvdH » 2020-05-10 15:38
Just an idea, might prevent genuine user to be listed in IDS which experience unexpected timeouts or the alike
Sub OnClientLogon(oClient)
	If oClient.Authenticated then
		REM Unregister IP address from IDS registry
		Call idsDelIP(oClient.IPAddress)
	End if
Post by SorenR » 2020-05-10 17:33
2020-05-10 15:38
	End if
Have you checked how many times IMAP authenticate during a session ?
The idea is to check SMTP traffic only and the IP is registered in OnClientConnect and unregistered in OnAcceptMessage. I have not had one false positive since I introduced it in my script over 1 years ago.
Post by RvdH » 2020-05-10 17:37
2020-05-10 17:33
2020-05-10 15:38
	End if
Quite often, but that check will take maybe 000.1 second, especially when it doesn't exist....but you also could specify ports or just ignore the suggestion
I know i will utilize it ;)
udgesbou
Post by udgesbou » 2021-04-05 19:40
Heyho,
i'm running a hMailServer on a Window-Server and i want to use this scripts:
#2 How to only allow client access from specific GEO locations. --> viewtopic.php?p=209543#p209543
#3 How to stop the annoying half-connections from BOT's and misconfigured spammers. --> viewtopic.php?p=209545#p209545
I found the "Scripts"-Button in "Advanced"-Settings, but i'm new in hMailServer and i don't know how to implement the scripts to my Server :(
I hope you can help me or show me a tutorial for that.
Thanks in advance.
Greetings
Colin
Post by mattg » 2021-04-06 01:31
udgesbou
Post by udgesbou » 2021-04-06 21:11
Thanks for your reply!
So if i want to implement this Script "#2 How to only allow client access from specific GEO locations." my "EventHandlers.vbs" should look like this?
Option Explicit
'   COM authentication
Private Const PASSWORD = "########"
Function GeoLookup(strIP) : GeoLookup = "zz"
   Dim a, element, group, strLookup
   a = Split(strIP, ".")
      strLookup = .TXT(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".zz.countries.nerd.dk")
   If Trim(strLookup) = "" Then
      EventLog.Write( "- GeoLookup(" & strIP & ") = " & GeoLookup )
      Exit Function
   group = Split(strLookup, vbCrLf)
   If UBound(group) > 0 Then
      For Each element In group
         If (Trim(element) <> "") Then EventLog.Write( "- GeoLookup(" & strIP & ") = " & element )
      GeoLookup = group(0)
Sub OnClientConnect(oClient)
   '   Exclude local LAN from test
   '   Only allow non-SMTP connect from "Rigsfællesskabet"/"Naalagaaffeqatigiit"/"Ríkisfelagsskapurin" = The Danish Realm.
   '   zz = N/A, dk = Denmark, gl = Greenland, fo = Faroe Islands
   If (oClient.Port <> 25) Then
      If (InStr("|dk|gl|fo|", GeoLookup(oClient.IPAddress)) = 0) Then
         Result.Value = 1
         Exit Sub
'   Sub OnSMTPData(oClient, oMessage)
'   End Sub
'   Sub OnAcceptMessage(oClient, oMessage)
'   End Sub
'   End Sub
'   End Sub
'   End Sub
'   Sub OnBackupCompleted()
'   End Sub
'   Sub OnError(iSeverity, iCode, sSource, sDescription)
'   End Sub
'   Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
'   End Sub
'   Sub OnExternalAccountDownload(oFetchAccount, oMessage, sRemoteUID)
'   End Sub
Which data must i enter here?
And where can i get the "codes" for germany, so that i can only connect from german country / ip?
Thanks in advance! :)
Greetings
Post by mattg » 2021-04-07 00:33
udgesbou wrote:
2021-04-06 21:11
The admin user MUST be = 'Administrator"
The PASSWORD is your hMailserver admin GUI password
udgesbou wrote:
2021-04-06 21:11
Germany is 127.0.1.20
udgesbou
Post by udgesbou » 2021-04-07 13:23
2021-04-07 00:33
udgesbou wrote:
2021-04-06 21:11
Okay, and where do I have to put that into the script? :(
Greetings
Post by RvdH » 2021-04-07 15:32
udgesbou wrote:
2021-04-07 13:23
Greetings
Maybe simply look at the examples given/quoted?
ashtec014
Post by ashtec014 » 2021-06-06 09:32
2019-10-31 10:58
nitro wrote:
2019-10-31 10:28
You have to be careful with the lords of Microsoft.
It can be a false positive in, FQDN as HELO.
AM5EUR02FT035.mail.protection.outlook.com
EUR04-DB3-obe.outbound.protection.outlook.com
EUR03-VE1-obe.outbound.protection.outlook.com
I discovered that yesterday too. I added outbound.protection.outlook.com$ to the list of "known false positives" so they skip the test.
I've notice that emails from "protection.outlook.com" mark as spam or "known false positives" though it isn't, which list do I add these so it could skip the test?
Post by palinka » 2021-06-06 16:23
ashtec014 wrote:
2021-06-06 09:32
2019-10-31 10:58
nitro wrote:
2019-10-31 10:28
viewtopic.php?f=20&t=33602
Have a look at this thread.
gotspatel
Post by gotspatel » 2021-11-27 06:25
Hello All, Hope everyone fine.
I am trying to extend the functionality of IDS to make a threatfeed (text file) for my Hardware firewall to block the IP from Firewall itself.
- take the IP which the IDS is blocking
- Check if threatfeed text file exists if not create it
- check if IP is already listed in file and if not write it to new line in the test file.
IS the below code perfect? as I am not able to get IP's blocked by IDS in the file.
the FULL IDSADDIP Function
Function idsAddIP(sIPAddress, iPort)
    Include(oApp.Settings.Directories.EventDirectory & "\VbsJson.vbs") '<---- It Points to Event Directory
	Dim ReturnCode, Json, oGeoip, oXML
	Set Json = New VbsJson
	'new GEOIPLOOKUP
    Dim m_CountryCode, m_CountryName
    Call GeoIPLookup(sIPAddress, m_CountryCode, m_CountryName)
	On Error Resume Next
	Dim idsTable
	idsTable = DBIDSTBL
	If IsMySQL Then
		strSQL = "INSERT INTO hm_ids (timestamp,ipaddress,port,hits,country) VALUES (" & DBGetCurrentDateTime() & ",'" & sIPAddress & "','" & iPort & "',1,'" & m_CountryName & "') ON DUPLICATE KEY UPDATE hits=(hits+1),TIMESTAMP=" & DBGetCurrentDateTime() & ";"
	ElseIf IsMSSQL Then
		strSQL = "IF NOT EXISTS (SELECT 1 FROM " & idsTable & " WHERE ipaddress = '" & sIPAddress & "') INSERT INTO " & idsTable & " (timestamp,ipaddress,port,hits,country) VALUES (" & DBGetCurrentDateTime() & ",'" & sIPAddress & "'," & iPort &",'1','" & m_CountryName & "') ELSE UPDATE " & idsTable & " SET hits=(hits+1), timestamp=" & DBGetCurrentDateTime() & " WHERE ipaddress= '" & sIPAddress & "';"
		Set objFSO = Wscript.CreateObject("Scripting.FileSystemObject")
		Set objShell = Wscript.CreateObject("Wscript.Shell")
		Const FORREADING = 1
		Const FORWRITING = 2
		Const FORAPPENDING = 8
		Dim sToSearch: sToSearch = "sIPAddress"
		Dim sFileName: sFileName = "C:\inetpub\wwwroot\Threatfeed\ids_iplist.txt"
		Dim sContent, Found
		If Not objFSO.FileExists(sFileName) Then
			EventLog.Write( "Function IDSADDIP - ERROR: ids_iplist.txt doesnot exist" )
			Set TxtFile = objFSO.OpenTextFile(sFileName, ForWriting, True)
			TxtFile.WriteLine sToSearch
			WScript.Quit 0
		Set TxtFile = objFSO.OpenTextFile(sFileName,FORREADING)
		sContent = TxtFile.ReadAll
		If InStr(sContent,sToSearch) Then Found = True End If
		Set TxtFile = Nothing
		If Not Found Then
			Set TxtFile = objFSO.OpenTextFile(sFileName,FORAPPENDING)
	Set sFileName = Nothing
	Call oDB.ExecuteSQL(strSQL)
	Set oDB = Nothing
Post by palinka » 2021-11-27 15:22
First, are you using MySQL or MSSQL? You don't need both.
Secondly, you're probably better off running a handler script that adds ips from the database to the text file. In that case, you may want to add a new column that let's you know if the ip has been picked up by the handler script already, so you don't have any duplication. Then nothing would change from the original script in your eventhandlers.vbs and you would run the handler from task scheduler every hour or whatever.
gotspatel
Post by gotspatel » 2021-11-28 06:46
I am using MYSQL (MSSQL I just kept don't know why?) :D
2nd, I want to use the code to write/delete the ip for both function IDSAPPIP and IDSDELIP in eventhandlers so as if the ip is removed by IDS then it is also removed from the text file.
very bad at coding just use the snippets from the internet and transform them to my use.
Post by palinka » 2021-11-28 14:20
There's a flaw in your logic / sequence of events. There's a reason there is a 3 strike rule. Some connections that get added to ids are false positives caused by network errors and such. You don't want to firewall ban those IPs until you're sure that they're actually malicious. Therefore, you don't want to add them to the text file every time IDSADD is called. You will only want to add them when they reach the strike limit, at which point you're more sure that the IP is malicious and not the result of a temporary error.
Try this. Revert the code back to the original. Then run this powershell from task scheduler every 5 minutes. I pulled this out of my firewall ban code. Its not tested!
###   MYSQL VARIABLES   ###
$DatabaseType     = 'MYSQL'
$SQLAdminUserName = 'hmailserver'
$SQLAdminPassword = 'supersecretpassword'
$SQLDatabase      = 'hmailserver'
$SQLHost          = '127.0.0.1'
$SQLPort          = 3306
$SQLSSL           = 'none'
###   SQL SSL OPTIONS   ###
#   Set to 'none' if Powershell and MySQL on same machine
#	None       - Do not use SSL.
#	Preferred  - Use SSL if the server supports it, but allow connection in all cases.
#	Required   - Always use SSL. Deny connection if server does not support SSL.
#	VerifyCA   - Always use SSL. Validate the CA but tolerate name mismatch.
#	VerifyFull - Always use SSL. Fail if the host name is not correct.
###   IDS OPTIONS   ###
$IDSIPList       = 'C:\inetpub\wwwroot\Threatfeed\IDSIPList.txt'
$IDSNew          = 5 # New Entries interval in minutes
$IDSExpire       = 3 # Interval in days
Function MySQLQuery($Query) {
	$Today = (Get-Date).ToString("yyyyMMdd")
	$DBErrorLog = "$PSScriptRoot\$Today-DBError.log"
	$ConnectionString = "server=" + $SQLHost + ";port=" + $SQLPort + ";uid=" + $SQLAdminUserName + ";pwd=" + $SQLAdminPassword + ";database=" + $SQLDatabase + ";SslMode=" + $SQLSSL + ";"
	Try {
		[void][System.Reflection.Assembly]::LoadWithPartialName("MySql.Data")
		$Connection = New-Object MySql.Data.MySqlClient.MySqlConnection
		$Connection.ConnectionString = $ConnectionString
		$Connection.Open()
		$Command = New-Object MySql.Data.MySqlClient.MySqlCommand($Query, $Connection)
		$DataAdapter = New-Object MySql.Data.MySqlClient.MySqlDataAdapter($Command)
		$DataSet = New-Object System.Data.DataSet
		$RecordCount = $dataAdapter.Fill($dataSet, "data")
		$DataSet.Tables[0]
	Catch {
		Write-Output "$(Get-Date -f G) : ERROR : Unable to run query : $query `n$($Error[0])" | Out-File $DBErrorLog -Append -Encoding ASCII
	Finally {
		$Connection.Close()
<#                IDS                  #>
<#    (Intrusion Detection System)     #>
<#	Pickup entries from IDS  #>
$Query = "SELECT ipaddress FROM hm_ids WHERE hits > 2 AND timestamp > (NOW() - INTERVAL $IDSNew MINUTE);"
MySQLQuery $Query | foreach {
	<#  Add to IDSIPList  #>
	$_ | Out-File $IDSIPList -Append -Encoding ASCII
<#	Expire old IDS entries  #>
$Query = "SELECT ipaddress FROM hm_ids WHERE timestamp < (NOW() - INTERVAL $IDSExpire DAY);"
MySQLQuery $Query | ForEach {
	Set-Content -Path $IDSIPList -Value (Get-Content -Path $IDSIPList | Select-String -Pattern '$($_)' -NotMatch)
$Query = "DELETE FROM hm_ids WHERE timestamp < (NOW() - INTERVAL $IDSExpire DAY);"
MySQLQuery $Query
gotspatel
Post by gotspatel » 2021-12-10 14:47
Atlast Got some hits :D
Any help how to remove the column headers
OUTPUT OF "IDSIPList.txt"
ipaddress   <<<< REMOVE THIS
---------   <<<< AND THIS
51.81.155.71
ipaddress
103.150.8.116
ipaddress
185.167.97.31
ipaddress
185.180.143.77
ipaddress
112.132.123.233
Post by palinka » 2021-12-10 16:17
gotspatel wrote:
2021-12-10 14:47
51.81.155.71
ipaddress
103.150.8.116
ipaddress
185.167.97.31
ipaddress
185.180.143.77
ipaddress
112.132.123.233
Change this line:
To this:
	$_.ipaddress | Out-File $IDSIPList -Append -Encoding ASCII
gotspatel
Post by gotspatel » 2021-12-13 11:41
2021-12-10 16:17
This Worked and Also I have integrated it in your Firewall ban Script
