This VBScript will set the needed Registry settings on your hMailServer Computer which is required for accessing
hMailServer via DCOM Remotely (Grants access for hMailAdmin, VB.NET, C#, native C++ Apps ect)
1) Open Windows Command prompt as Administrator
2) run: "wscript EnableDCOM_for_HMS.vbs"
Additionally you may need a special Windows Useraccount on both machines, same name, same password.
DCOM_RemoteEnabler
DCOM_RemoteEnabler
- Attachments
- EnableDCOM_for_HMS.7z
- (390 Bytes) Downloaded 425 times
Re: DCOM_RemoteEnabler
Nice, have been waiting for something like this...
Not that I need it myself as I have been using DCOM since 2007 on my headless W2K2003 Server.
I'm still waiting for someone to make a complete set of HMS-plugins for RoundCube on UNIX using either a port of DCOM or a gateway of some sorts.
My plugin for roundcube on UNIX using api that use php on mail server. https://plugins.roundcube.net/users/tunis78/packages/SorenR wrote: I'm still waiting for someone to make a complete set of HMS-plugins for RoundCube on UNIX using either a port of DCOM or a gateway of some sorts.![]()
I self run hmailserver on 2016-core with nginx and php for the api (and phpwebadmin) and centos with apache and php with roundecube.
The thing is i don't want a webserver on my mailserver.
I have make a gateway test with the small REST server Grapevine, combined with Dravion example viewtopic.php?f=21&t=31507.SorenR wrote:The thing is i don't want a webserver on my mailserver.
It can only get and set users forwarding and show version of hmailserver for now.
Run hmailRESTServer.exe.
Connect to and show version: localhost:1234/version
Get forwarding: localhost:1234/user/forwarding?email=email&password=password
Save forwarding: localhost:1234/user/forwarding/save?email=email&password=password&enable=1&address=test@test.local&keeporiginal=1
This is just a test.
- Attachments
- hmailRESTServer.7z
- (175.12 KiB) Downloaded 192 times
Nice work tunistunis wrote:I have make a gateway test with the small REST server Grapevine, combined with Dravion example viewtopic.php?f=21&t=31507.SorenR wrote:The thing is i don't want a webserver on my mailserver.
I think the more ways of accessing hMailServer the better.
IMHO:
REST is nice and back in time i made a QT5 Client which accessed Apach2+PHP via Rest (server rest part was done in PHP) but then i realized this requires a Webserver, PHP5 and even SSL and anything needs to configured properly...
Here is my old posting about it, maybe its a help in someway for your Project
viewtopic.php?f=8&t=29979&p=187419&hilit=rest#p187419
Long story short: I decided to start a new Windows TCP/IP-Server Project which runs as Windows Service
(side by side with hMailServer.exe) which is permanently connected via DCOM to it while at the same time has a TCP/IP based SSL/TLS Remote API for Internet and Local Area Network access (plain and simple).
Declan, a diffrent User made the request for this project because he wants to access hMailServer from its own Android .x (or higher) Smartphone App (with Java +SSL). Its planned that C/C++ and Java will be supported first,
but as time goes by other languages will be added as well. However: The more API's for hMailServer and utilities the better
Your project looking nice!
I have also think making it a windows service. (I tried but it failed to install, so I must read how it work with installer and stuff)
I noticed you both call oApp.Connect() before every call to specific hmailserver settings, are you sure that is needed?
I made some smaller projects using C# and I never call oApp.Connect() as the server should have connection(s) to the database already. I just tested it once more and I successfully can get and set values from within C# without calling oApp.Connect()
Yeah its unescessary
