Perfect.
Thank you.
HOW TO: Ready-To-Go Backup and Cleardown script
- jimimaseye
- Moderator
Re: HOW TO: Ready-To-Go Backup and Cleardown script
Looking at my logs. All is being copied as expected. HMailserver stops and starts fine and zip is present and all correct.
Top job.
Top job.
I've also change I bit of my code to read
So when restoring it will save me time I can just unzip all strait into directory and overwrite the existing files.
Now the hmaildata folder is just called Data.:3rd
set section=3rd
if "%FailedHmailservice:~0,14%" == "Failed to stop" goto 5th
robocopy "%MAILDATAdir%" "%BACKUPTEMPdir%"\Data /mir /ndl /r:43200 /np /w:1 >> %BackLog%
goto ROBOerrorcheck
:4th
if "%DBtype%" == "mysql" (
erase /Q "%BACKUPTEMPdir%"\Data\*.mysql >> %BackLog%
"%MYSQLBINdir%"\mysqldump -u"%MYSQLDBuser%" -p"%MYSQLDBpass%" -q -A -l --add-drop-table -PMYSQLDBport >"%BACKUPTEMPdir%\Data\MYSQLDump_%inDate%.mysql"
) ELSE (
xcopy /f /I /Y "%HMAILSERVERprogdir%"\Bin\hmailserver.ini "%BACKUPTEMPdir%"\Bin\ >> %BackLog%
robocopy "%InternalDATABASEdir%" "%BACKUPTEMPdir%"\Database /mir /ndl /r:43200 /np /w:1 >> %BackLog%
goto ROBOerrorcheck
Hi I have tweeked your code so the following just happens.
hmailserver stops
copies files to temp folder
hmailserver starts
Removed files older than 5 days
creates zip
completes log
Im not needing to use BLAT or Emailclearup.vbs. As I can Check Log for problems on our network system at anytime.
Is it correct to you?
Thank you in advance
hmailserver stops
hmailserver starts
creates zip
completes log
rem #### CONFIG START ####
rem ******* FILL OUT VARIABLES BELOW ***************************
rem --- SET LOCATIONS (without trailing '\') ----
Set BACKUPdir=D:\Email_Backups\Backup Files
Set BACKUPTEMPdir=C:\EmailBackupTemp
set MAILDATAdir=C:\Program Files (x86)\hMailServer\data
set HMAILSERVERprogdir=C:\Program Files (x86)\hMailServer
rem Spamassassin installed and in use: enter "yes" or "no" (lowercase!). Also set program directory if 'yes'.
set SA_In_Use=no
set SPAMASSASSINdir=C:\Program Files (x86)\JAM Software\SpamAssassin for Windows
rem enter "internal" or "mysql" (lowercase!) as the database type in use
set DBtype=internal
rem ** IF DBtype = 'internal' set the following variables
set InternalDATABASEdir=C:\Program Files (x86)\hMailServer\Database
rem ** IF DBtype = MySQL set the following variables
set MYSQLBINdir=C:\Program Files\MySQL\MySQL Server 5.5\bin
set MYSQLDBuser=root
set MYSQLDBpass=yoursqlpassword
set MYSQLDBport=3306
rem --- HOW MANY recent backup Zips do you want to retain? ----
set DAYSZIPTOKEEP=5
rem **** FILL OUT VARIABLES ABOVE *******************************
rem #### CONFIG END ####
Set SCRIPTdir=%~dp0
for /F "usebackq tokens=1,2 delims==" %%i in (`wmic os get LocalDateTime /VALUE 2^>NUL`) do if '.%%i.'=='.LocalDateTime.' set ldt=%%j
set inDate=%ldt:~0,4%-%ldt:~4,2%-%ldt:~6,2%-%ldt:~8,6%
set BackLog="%BACKUPdir%\Backup_%inDate%.log"
set Failed=false
set FailedScript=Not performed
set FailedZip=Not performed
set FailedSAUpdate=Not performed
set FailedSAService=Not performed
set FailedDNSService=Not performed
set FailedHmailservice=Not performed
set outf="%SCRIPTdir%\body.html"
echo ^<table border='0'^> > %outf%
set colorfill=font color="red"
set fontBlack=!--
set noBold=!--
echo Backup Start: %date% %time% > %BackLog%
REM :: Perform backup to temporary directory
set section=1st
:1st
:maildata
echo %time% Stopping Hmailserver service...>> %BackLog%&net stop hmailserver >> %BackLog%
set FailedHmailservice=Ok
set bold=%noBold%&set fontcolor=%fontBlack%
if errorlevel 1 set Failed=true&set FailedHmailservice=Failed to stop. Backup of emails not performed!&set bold=b&set fontcolor=%colorfill%
echo %FailedHmailservice%! >> %BackLog%
echo ^<tr^>^<td^>^<%fontcolor%^>^<%bold%^>Hmailserver service shutdown:^</td^>^<td^>^<%fontcolor%^>^<%bold%^>%FailedHmailservice%^</td^>^</tr^> >>%outf%
:2nd
if not "%SA_In_Use%" == "yes" goto 3rd
echo %time% Stopping Spamassassin service...>> %BackLog%&net stop spamassassin >> %BackLog%
set FailedSAService=Ok
if errorlevel 1 set Failed=true&set FailedSAService=Failed to stop&set bold=b&set fontcolor=%colorfill%
echo %FailedSAService%! >> %BackLog%
echo ^<tr^>^<td^>^<%fontcolor%^>^<%bold%^>Spamassassin service shutdown:^</td^>^<td^>^<%fontcolor%^>^<%bold%^>%FailedSAService%^</td^>^</tr^> >>%outf%
@rem Update Spamassassin before restarting service
if "%FailedSAService%" == "Failed to stop" goto 3rd
echo %time% Performing Spamassassin Update check...>> %BackLog%
set FailedSAUpdate=Ok
cd /D "%SPAMASSASSINdir%"
sa-update.exe -v --nogpg --channelfile UpdateChannels.txt >> %BackLog%
if errorlevel 1 set Failed=true&set FailedSAUpdate=Failed&set bold=b&set fontcolor=%colorfill%
echo ^<tr^>^<td^>^<%fontcolor%^>^<%bold%^>Spam Assassin Def Update:^</td^>^<td^>^<%fontcolor%^>^<%bold%^>%FailedSAUpdate%^</td^>^</tr^> >>%outf%
:3rd
set section=3rd
goto ROBOerrorcheck
:4th
) ELSE (
goto ROBOerrorcheck
:5th
@rem Restart Spamassassin and Hmailserver services
if not "%FailedSAService%" == "Ok" goto 6th
echo %time% Starting Spamassassin service...>> %BackLog%&net start spamassassin >> %BackLog%
if errorlevel 1 set Failed=true&set FailedSAService=Failed to restart&set bold=b&set fontcolor=%colorfill%
echo ^<tr^>^<td^>^<%fontcolor%^>^<%bold%^>Spam Assassin Service startup: ^</td^>^<td^>^<%fontcolor%^>^<%bold%^>%FailedSAService%^</td^>^</tr^> >>%outf%
:6th
if not "%FailedHmailservice%" == "Ok" set section=7th & goto 7th
echo %time% Starting Hmailserver service... >> %BackLog%&net start hmailserver >> %BackLog%
if errorlevel 1 set Failed=true&set FailedHmailservice=Failed to restart&set bold=b&set fontcolor=%colorfill%
echo %FailedHmailservice%! Errorlevel=%errorlevel% >> %BackLog%
echo ^<tr^>^<td^>^<%fontcolor%^>^<%bold%^>Hmailserver service startup:^</td^>^<td^>^<%fontcolor%^>^<%bold%^>%FailedHmailservice%^</td^>^</tr^> >>%outf%
REM --- Use the following sections 7th to 9th as example of adding other Data directories in the backup (remove the REM's) ---
:7th
:Sagedata
rem robocopy "D:\SageAccountData" "%BACKUPTEMPdir%"\SageAccountData /mir /ndl /r:43200 /np /w:1 >> %BackLog%
rem goto ROBOerrorcheck
:8th
:Miscdata
rem robocopy "D:\Miscdata" "%BACKUPTEMPdir%"\Miscdata /mir /ndl /r:43200 /np /w:1 >> %BackLog%
:9th
rem robocopy "D:\anotherdir" "%BACKUPTEMPdir%"\anotherdir /mir /ndl /r:43200 /np /w:1 >> %BackLog%
REM --- End of Example sections ---
:10th
REM:: Clear down existing backup Zips over DAYSZIPTOKEEP
echo. & echo Clearing old archives
forfiles.exe /s /p "%BACKUPdir%" /m *.* /d -%DAYSZIPTOKEEP% /c "cmd /c echo Deleting over %DAYSZIPTOKEEP% days....@path & del /q @path" >> %BackLog%
REM :: Zip temporary directory and email log file
cd /D "%HMAILSERVERprogdir%"\Bin >> %BackLog%
echo %date% %time% 7Zip Creating archive %BACKUPdir%\Serverdata_%inDate%.zip >> %BackLog%
set FailedZip=Ok
7za a -tzip "%BACKUPdir%\Serverdata_%inDate%" "%BACKUPTEMPdir%\*"
if errorlevel 1 set Failed=true&set FailedZip=Failed&set bold=b&set fontcolor=%colorfill%
echo ^<tr^>^<td^>^<%fontcolor%^>^<%bold%^>Zip:^</td^>^<td^>^<%fontcolor%^>^<%bold%^>%FailedZip%^</td^>^</tr^> >>%outf%
:test
set result=%date% %time% Backup procedure FAILED!!! Zip: %FailedZip%, Script: %FailedScript%, SA Update: %FailedSAUpdate%, SA Service: %FailedSAService%, Hmailserver service: %FailedHmailservice%.
set resulttext="!!! Backup completed WITH ERRORS. CHECK LOG FILE FOR DETAILS!!!"
if not %Failed%==false goto Testend
:success
set result=%date% %time% Backup 7Zip Archive created - no errors encountered.
set resulttext="Backup completed. See attachment log file."
goto Testend
:ROBOerrorcheck
if errorlevel 16 echo ***FATAL ERROR*** >> %BackLog% & goto end
if errorlevel 15 echo OKCOPY + FAIL + MISMATCHES + XTRA >> %BackLog% & goto end
if errorlevel 14 echo FAIL + MISMATCHES + XTRA >> %BackLog% & goto end
if errorlevel 13 echo OKCOPY + FAIL + MISMATCHES >> %BackLog% & goto end
if errorlevel 12 echo FAIL + MISMATCHES>> %BackLog% & goto end
if errorlevel 11 echo OKCOPY + FAIL + XTRA >> %BackLog% & goto end
if errorlevel 10 echo FAIL + XTRA >> %BackLog% & goto end
if errorlevel 9 echo OKCOPY + FAIL >> %BackLog% & goto end
if errorlevel 8 echo FAIL >> %BackLog% & goto end
if errorlevel 7 echo OKCOPY + MISMATCHES + XTRA >> %BackLog% & goto end
if errorlevel 6 echo MISMATCHES + XTRA >> %BackLog% & goto end
if errorlevel 5 echo OKCOPY + MISMATCHES >> %BackLog% & goto end
if errorlevel 4 echo MISMATCHES >> %BackLog% & goto end
if errorlevel 3 echo OKCOPY + XTRA >> %BackLog% & goto end
if errorlevel 2 echo XTRA >> %BackLog% & goto end
if errorlevel 1 echo OKCOPY >> %BackLog% & goto end
if errorlevel 0 echo No Change >> %BackLog% & goto end
:end
if errorlevel 8 set Failed=true
if %section%==9th set section=10th
if %section%==8th set section=9th
if %section%==7th set section=8th
if %section%==6th set section=7th
if %section%==5th set section=6th
if %section%==4th set section=5th
if %section%==3rd set section=4th
if %section%==2nd set section=3rd
if %section%==1st set section=2nd
goto %section%
:Testend
if not %FailedZip%==Failed forfiles /p "%BACKUPdir%" /m Serverdata_%inDate%.zip /d +0 /c "cmd /c echo Created: @path @fsize" >> %BackLog%
echo ^<tr^>^<td^>^<br^>^</td^>^</tr^>^</table^>See attached log file below for details. >>%outf%
echo %result% >> %BackLog%
:Finish
- jimimaseye
- Moderator
Think so (on a quick read).
