HOW TO: Ready-To-Go Backup and Cleardown script
Re: HOW TO: Ready-To-Go Backup and Cleardown script
Post by palinka » 2019-02-19 01:14
I found a simple service notification powershell script. I commented out the bit with attempting to restart the service. Email bits are commented out too as I'm using http get to trigger the sms message. It works. Run at startup from windows scheduler.
Reason: code removed as per poster's request. Modified code below.
Post by mattg » 2019-02-19 01:19
I get these shutdown issues almost every time I try and 'Pause' hmailserver or stop the service
That the main reason that I don't shutdown or pause to run backups, I just run backups live.
I suspect that it is because some SMTP connections are not closed properly.
RvdH shared some code saved as disconnect.exe >> viewtopic.php?f=20&t=32739&p=206184#p206167
I've used it a bit in my eventhandlers.vbs but I haven't been logging the use.
I'll do that for a while and see if that helps me...
Post by mattg » 2019-02-19 01:26
2019-02-18 01:22
2019-02-18 01:15
2019-02-17 19:25
... is set up a SMS gateway, which I did last night using a spare SIM I have with my mobile plan and gammu/kalkun as the gateway.
What hardware did you use to achieve this??
I bought the cheapest usb modem i could find on Amazon. $10 huawei e352. Getting gammu to work was kind of a pain since the project is kind of old and windows was a side thought. You'll have many more options on linux. Or you can jump through hoops like me. :mrgreen:
You can use an old mobile phone too. I considered that too (free) but i tried it with an android app a long time ago and it didn't work well and caused the phone to crash after a day or 2. I think it's better to have computer hardware.
My issue is that I run hMailserver in a HyperV VM, and HyperV doesn't allow access the USB ports of the bare metal server. I do have a network device with a SIM card, a Netgear LTE Modem LB2120, but I am yet to work out how to send SMS from a network attached device via a script. I can do it from the GUI of the device, so I'm sure it will be possible...
Post by palinka » 2019-02-19 01:40
2019-02-19 01:26
2019-02-18 01:22
2019-02-18 01:15
Http get
https: //yoursmsgateway.tld/index.php/plugin/rest_api/send_sms?phoneNumber=1234567890&message=whatever message you want. Including punctuation and spaces! Yay!
I put a space after https: so it wouldn't break up the url that has spaces in it in the message section.
I'm using kalkun as the front end for gammu. Gammu has a service ans kalkun is a php web app. But like i said, they're both old and there are better options for linux, but they do basically the same thing.
Post by palinka » 2019-02-19 12:58
I worked out a way easier powershell script for checking service status. This is notify only. The other one i posted doesn't work. I jumped the gun on that one. This one is thoroughly tested. Maybe a mod can delete the other one.
Run from task scheduler. I set mine to run every hour so i don't get spammed if something breaks while I'm sleeping.
Also, this only works on one service, so i made one for each of the services i want to monitor and put them all into a single task in scheduler.
Delete the sms bit if you don't use it or use the api url from your own gateway. By the way, this throws an error because even though it works to post the message, it's a get command that is looking for a response but my gateway gives a 404 as response. Still working that out. Doesn't affect operation, but the run status in scheduler is 0x1 because of the 404 error. Need to figure out either straight post or ignore error in powershell.
if((get-service hMailServer).Status -eq 'Running'){exit 1}
else {
# Send the problem services via email
	$EmailFrom = "notify@domain.net"
	$EmailTo = "admin@domain.com"
	$Subject = "Windows Service Failure"
	$Body = "ATTENTION! Server reporting that the hMailServer service is not running. Check status NOW."
	$SMTPServer = "localhost"
	$SMTPClient = New-Object Net.Mail.SmtpClient($SmtpServer, 587)
	$SMTPClient.EnableSsl = $false
	$SMTPClient.Credentials = New-Object System.Net.NetworkCredential("notify@domain.net", "SecretPassword");
	$SMTPClient.Send($EmailFrom, $EmailTo, $Subject, $Body)
# Send the problem services via SMS
	$uri = "https://mysmsgateway/sms/index.php/plugin/rest_api/send_sms?phoneNumber=1234567890&message=ATTENTION! Server reporting that the hMailServer service is not running. Check status NOW."
	$response = Invoke-RestMethod -Uri $uri
It took me a while to figure this one out. I don't know why, but "exit" in the if statement didn't work. Finally i ran across something on the web and changed it to "exit 1" and it worked straight off. Weird.
Post by palinka » 2019-02-19 13:20
2019-02-19 01:26
I reread your post and looked up the device. That's a hotspot modem, correct? Yeah I'm not sure if that could work. All the gateway software I've seen use at commands which require the device be connected by cable. Mine is usb and the driver fakes the serial port for access. But the usb ones are cheap if you want to go that route. Or you could try using an old phone connected by usb.
Post by mattg » 2019-02-20 02:56
2019-02-19 13:20
Some of us have NBN in Australia, which stands for National Broadband Network.
I have FTTP = Fibre to the premises
I have a fibre optic cable running to a NBN router at my premises, which offers a LAN type connector to my own router/modem commonly supplied by ISPs. This is much like cable in many regards.
Problem is that it can drop out for what ever reason.
My LTE modem fits between my router/firewall/modem and the NBN router, and offers failover to 4G via a SIM Card when the NBN connection is down. I can't get static IP on 4G, so this is only for outgoing internet traffic, not incoming traffic.
And yeah, I haven't found much on how I can achieve a message via http get, but that would be the plan
Post by palinka » 2019-02-20 03:19
2019-02-20 02:56
2019-02-19 13:20
If you just want to test, there are a bunch of android gateway apps that connect via wifi. The ones i tried were not very stable. Or it could have been my phone.
For your backup internet, you could assign a backup mx record to a dynamic domain that the lte router updates. Most of these devices come with a few ddns providers built in. Shoot, you could leave it running all the time like that and never skip a beat.
I have fibre too. It's always worked even when the power goes out. I have a ups attached to the fibre hardware, all my networking gear and my server. I get about 40 minutes which is usually enough time for the power to come back on. I only remember the fibre going down once and that was very early on a Sunday morning. I think they may have been upgrading hardware.
Post by palinka » 2019-02-20 14:04
We're waaaay off topic here but i just had to share this. I run apcupsd to monitor my ups. I had it set up to email me via my cell carrier's sms gateway so i would get text messages for power events. I already changed the scripts to use my personal sms gateway. After writing the last post and thinking about the power situation, i looked to see if the utility here accepts text messages to report outages and they do. So i registered my gateway's cell number with the utility and now when the power goes out, my server will automatically send the utility an outage text. I set it up with a 2 minute delay so it wouldn't fire on momentary outages, which are common here. Hehe.. i don't even have to be home to know about it, or if it happens while I'm sleeping they still get notified. I know my neighbors will appreciate that too. :mrgreen:
Also, one of the reasons i wanted an sms gateway is because sometimes my email > carrier gateway messages would get trapped in the carrier's sms spam filter. No matter how i experimented with "unspammy" messages, some still got trapped and i couldn't figure out why. It was random. So this solves that problem.
Post by jimimaseye » 2019-02-20 15:27
2019-02-20 14:04
We're waaaay off topic here.....
Aren't we just.
Post by palinka » 2019-02-24 14:45
2019-02-20 15:27
2019-02-20 14:04
Aren't we just.
:mrgreen:
Anyway, back on topic. It happened again last night. This time I paid a little closer attention before rebooting.
Service status was "running". My notification script didn't work because it tests "not running".
Log shows the same shutdown errors:
"DEBUG"	2760	"2019-02-23 23:58:11.869"	"Still 1 remaining threads in queue Server queue. First task: IOService"
"DEBUG"	9524	"2019-02-23 23:58:11.900"	"Still 1 remaining threads in queue IOCPQueue. First task: IOCPQueueWorkerTask"
"DEBUG"	2760	"2019-02-23 23:58:12.135"	"Given up waiting for threads to join in queue Server queue."
"DEBUG"	2760	"2019-02-23 23:58:12.135"	"WorkQueueManager::RemoveQueue - Stopped Server queue"
"DEBUG"	2760	"2019-02-23 23:58:12.135"	"WorkQueueManager::RemoveQueue - Erased Server queue"
"DEBUG"	2760	"2019-02-23 23:58:12.135"	"Destructing work queue Server queue"
"DEBUG"	9524	"2019-02-23 23:58:12.166"	"Given up waiting for threads to join in queue IOCPQueue."
"DEBUG"	9524	"2019-02-23 23:58:12.166"	"WorkQueueManager::RemoveQueue - Stopped IOCPQueue"
"DEBUG"	9524	"2019-02-23 23:58:12.166"	"WorkQueueManager::RemoveQueue - Erased IOCPQueue"
"DEBUG"	9524	"2019-02-23 23:58:12.166"	"IOService::Stop() - Complete"
"DEBUG"	9524	"2019-02-23 23:58:12.166"	"Destructing work queue IOCPQueue"
Notice the last two lines. The service DID NOT stop.
Something else - maybe just a coincidence, but this seems to always happen on a Saturday night. At first I thought maybe it had something to do with me fooling around with the system on Saturdays (the time I usually do), but yesterday I did not install anything, reboot or anything like that. Weird.
Post by palinka » 2019-02-24 17:42
The issue seems to be oapp.stop insofar as it pauses hmailserver, not stop hmailserver service. Therefore, the way I tried to detect problems didn't work as I was using service status. So I figured I would need another method - telnet would tell me if things are not working. After some goolaging and experimentation, I came up with this powershell script.
To be safe that there's not some temporary issue, it checks a full 3 times before attempting to restart hmailserver service. The script is run on the same machine as hmailserver and there's no chance for temporary network issues, but I'm playing it safe for circumstances I can't even think of at the moment.
If powershell cannot connect by telnet after 3 tries, it will restart the service and send me a text letting me know. Then it will wait 60 seconds and check service status again. If the service is not running, I'll get another message telling me.
If powershell can't connect either once or twice, but does successfully connect on the second or third try, it will finish and exit without attempting to restart hmailserver.
$ErrorActionPreference = 'silentlycontinue'
$remotehost = "localhost"
$port = 25
$ServiceName = 'hMailServer'
$socket = new-object System.Net.Sockets.TcpClient($remoteHost, $port)
if($socket -eq $null) {
	Start-Sleep -seconds 300
			Restart-Service $ServiceName
			$uri = "https://smsgateway/index.php/plugin/rest_api/send_sms?phoneNumber=1234567890&message=ATTENTION! hMailServer service is being RESTARTED due to a fault. Check status NOW."
			Start-Sleep -seconds 60
			(get-service $ServiceName).Refresh()
			if ((get-service $ServiceName).Status -ne 'Running')
			$uri = "https://smsgateway/index.php/plugin/rest_api/send_sms?phoneNumber=1234567890&message=ATTENTION! BrianServer reporting that the hMailServer service is not running. Check status NOW."
Post by palinka » 2019-03-07 12:15
Hot damn! It worked. Not only that, but the backup script, which got hung up on oapp.stop, picked up when hmailserver service actually stopped and completed without errors.
I have my backup script set to run at 11:58pm. My telnet check script runs at 12:15. Note: it's supposed to wait 5 minutes between tries but i had it set to 10 seconds when i was testing it and forgot to change it back. Just fixed that. You'll see that in the log timestamps. The reason for the two 5 minute waits is just in case hmailserver is still running the backup, or other momentary communication errors.
Checking communication turned out to be a good idea because when it hangs like this, the service status is still "running" so checking service status won't do anything.
Real life test: PASS
Backup Start: Wed 03/06/2019 23:58:01.18
HMS Server Start Time: 2019-03-05 23:58:36
HMS Daily Spam Reject count: 16
HMS Daily Viruses Removed count: 10
 0:15:29.94 Stopping Hmailserver service...
The hMailServer service was stopped successfully.
Ok!
 0:15:30.75 Stopping Spamassassin service...
The spamassassin service was stopped successfully.
~~~~SNIP~~~~
Post by jimimaseye » 2019-03-07 15:08
Effectively your oapp.stop process is erroring/ freezing. By restarting the service your backup script then got control of the service (which is now running again) to stop it and continue. This is effectively the same as not having the oAp.stop in the first place.
Post by palinka » 2019-03-07 17:07
2019-03-07 15:08
The main reason its there is because the number of "hangs" was worse before I put it in. But it certainly can't hurt removing it, which I'll do tonight and see how it goes.
Post by palinka » 2019-03-08 02:26
I looked back in this thread and found the reason i added oapp.stop.
https://hmailserver.com/forum/viewtopic ... 60#p206367
In retrospect, it appears better to leave it in. Without it, the backup script fails. With it included, plus with my telnet monitor script, the service gets restarted and the backup continues successfully. :mrgreen:
Post by jimimaseye » 2019-03-08 10:08
So attempting to stop the service times out at 30000 milliseconds. Probably for the same reason the oApp.stop doesnt work (whatever that is). So you issue another NET STOP and net start (to then go on and issue a net stop).
OR....
Try removing the oApp.stop and changing the initial script to:
:1st
:maildata
echo %time% Stopping Hmailserver service...>> %BackLog%&net stop hmailserver >> %BackLog%
set FailedHmailservice=Ok
set bold=%noBold%&set fontcolor=%fontBlack%
if errorlevel 1 echo %time% Stopping Hmailserver service (2nd try)...>> %BackLog%&net stop hmailserver >> %BackLog%
if errorlevel 1 echo %time% Stopping Hmailserver service (3rd try)...>> %BackLog%&net stop hmailserver >> %BackLog%
if errorlevel 1 set Failed=true&set FailedHmailservice=Failed to stop. Backup of emails not performed!&set bold=b&set fontcolor=%colorfill%
echo %FailedHmailservice%! >> %BackLog%
echo ^<tr^>^<td^>^<%fontcolor%^>^<%bold%^>Hmailserver service shutdown:^</td^>^<td^>^<%fontcolor%^>^<%bold%^>%FailedHmailservice%^</td^>^</tr^> >>%outf%
As you have seen that a 2nd attempt to stop seems to work then the above should more than suffice.
Post by palinka » 2019-03-08 12:38
2019-03-08 10:08
OR....
:1st
:maildata
I was actually thinking about that but i wasn't sure if the error checking resolves back to the first net stop command or if it would work sequentially the way you did it. I guess that answers my question and also simplifies things greatly. Thanks!
Maybe you should add this to the OP.
