Modify the script as you like, I have not added any filters to get the total overview.-------------------------------------------------
Account: name@domain.com
Total used space: 52,457 MB
Folders:
INBOX: 1632 (49,17 MB)
-Sent: 3 (0,00 MB)
--ASubDir: 0 (0,00 MB)
-Trash: 2 (0,01 MB)
-Drafts: 0 (0,00 MB)
Trash: 0 (0,00 MB)
Sent: 1 (0,00 MB)
Spam: 81 (2,29 MB)
Archive: 0 (0,00 MB)
' Size report of all users for each directory
' Created by: Lars Werner
' Date: 18.06.2020
' Warranty: Out of the door...
Option Explicit
' #### CONFIG START
Const HMSADMINUSER = "Administrator" ' Admin username
Const HMSADMINPWD = "yourpassword" ' Admin password
Const HMSSERVER = "localhost" ' hMailServer Server (host / DCOM)
' #### CONFIG END
Dim oApp, oDomain, oAccount, oFolders
Dim x, y
' On Error Resume Next
Set oApp = CreateObject("hMailServer.Application", HMSSERVER)
'Loop through all domains, accounts and then recursive count all the mails
For x = 0 To oApp.Domains.Count - 1
Set oDomain = oApp.Domains.Item(x)
'If oDomain.Active Then
For y = 0 To oDomain.Accounts.Count - 1
Set oAccount = oDomain.Accounts.Item(y)
Wscript.Echo "--------------------------------------------------"
wscript.echo "Account: " & oAccount.Address
wscript.echo "Total used space: " & oAccount.Size & " MB"
wscript.echo ""
WScript.echo "Folders:"
Set oFolders = oAccount.IMAPFolders
'Start recursive listing for this user
call RecursiveFolder(oFolders, 0)
'Space up for the next user
wscript.echo ""
'End If
'Recursize function that will be called again and again until no more subfolders exists
Function RecursiveFolder(oFld, nLevel)
Dim nIntCount, oFolder, oMessages, oMessage, nSize, nCount, z
For nIntCount = 0 to oFld.Count - 1
nSize = 0
set oFolder = oFld.Item(nIntCount)
set oMessages = oFolder.Messages
nCount = oMessages.Count 'Number of messages
'Loop through each message and sum up the sizes
for z = 0 to oMessages.Count - 1
set oMessage = oMessages.Item(z)
nSize = nSize + oMessage.Size
'Print out the folder, message count and size
WScript.echo replace(space(nLevel), " ", "-") & oFolder.Name & ": " & nCount & " (" & FormatNumber(nSize / 1024, 2) & " MB)" '& " ---> " & nIntCount & "/" & oFld.Count - 1
'If there are subfolders, do the next one
if Not IsNull(oFolder.SubFolders) then
if oFolder.SubFolders.Count > 0 then
call RecursiveFolder(oFolder.SubFolders, nLevel + 1)
end if
end if
