For reference: https://www.hmailserver.com/forum/viewt ... =7&t=34245
WHAT IT DOES
It loops through all enabled external accounts in all active accounts of all active domains, starts the donwload and adds a configurable delay between each fetch.
HOW TO USE
Adjust the CONFIG part for your needs (Admin username, Admin Password, verbose mode, delay)
verbose=1 shows some more information for debugging when started in a cmd box
delay=1000 means setting a delay of 1 sec between every fetch
HOW TO IMPLEMENT
Either start it in a cmd prompt by hand or create a task scheduler task like this:
Program/Script: C:\Windows\System32\cscript.exe - Arguments: "<pathto>\Automatic_POP3_fetch.vbs"
Trigger for task: every x minutes
THE CODE (click 'SELECT ALL' and copy/paste):
Automatic_POP3_fetch.vbs:
' Script forces download of all enabled external accounts for all active accounts of every active domain
' Use in task scheduler: Program/Script: C:\Windows\System32\cscript.exe - Arguments: "<pathto>\Automatic_POP3_fetch.vbs"
Option Explicit
' #### CONFIG START ####
Const HMSADMINUSER = "Administrator" ' Admin username
Const HMSADMINPWD = "" ' Admin password
verbose = 0 ' set to 1 for some debugging output
delay = 1000 ' delay between fetches in ms
' #### CONFIG END ####
' Objects
Dim oApp, oDomain, oAccount, oExtAccount
' Numeric
Dim x, y, z, i, verbose, delay
i=1
If verbose = 1 then wscript.echo(" Domain.Count: " & oApp.Domains.Count)
For x = 1 To oApp.Domains.Count
Set oDomain = oApp.Domains.Item(x-1)
If oDomain.Active Then
If verbose = 1 then wscript.echo(" - Domain " & x & ": " & oDomain.Name)
If verbose = 1 then wscript.echo(" - Accounts.Count: " & oDomain.Accounts.Count)
For y = 1 to oDomain.Accounts.Count
Set oAccount = oDomain.Accounts.Item(y-1)
If oAccount.active Then
If verbose = 1 then wscript.echo(" - Address " & y & ": " & oAccount.Address)
If verbose = 1 then wscript.echo(" - FetchAccounts.Count: " & oAccount.FetchAccounts.Count)
For z = 1 To oAccount.FetchAccounts.Count
Set oExtAccount = oAccount.FetchAccounts.Item(z-1)
If oExtAccount.Enabled Then
If verbose = 1 then wscript.echo(" - FetchAccount " & z & ": " & oExtAccount.Name)
oExtAccount.DownloadNow()
wscript.echo(" Download " & i & " - Account: " & oExtAccount.Name & " --> Ext. Account: " & oAccount.address)
wscript.sleep delay 'wait for x sec until fetching next account
i = i + 1
End if
End if
End if
