Reject on Spamhaus DBL
Post by palinka » 2019-07-27 12:40
I've been playing around with Spamhaus and found they do domain testing also. I thought I'd give it a whack.
The first test is on the highest level domain found in the helo. I haven't implemented that yet. Still testing. I haven't seen any false positives, but this could be dangerous so I'm going to watch it a while before actually rejecting anything based on this. Regex seems to work ok: https://regex101.com/r/FqiHHX/3
The second test is on the from address of the message. If it contains a spammy domain, then reject. I'm confident enough in this to reject without issue.
This is all recycled code from SorenR and RvdH.
Requirements: RvdH's OnHELO custom build and also his dns resolver component. Both found here: http://hmailserver.com/forum/viewtopic.php?f=10&t=30193
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
      .Pattern = strRegEx
      .Global = bGlobal
      .MultiLine = True
      .IgnoreCase = True
Function IsInSpamHausDBL(strDomain) : IsInSpamHausDBL = False
	Dim strLookup
		strLookup = .DNSLookup(strDomain & ".dbl.spamhaus.org")
	Dim strRegEx : strRegEx = "(127\.0\.1\.(2|4|5|6))"
	IsInSpamHausDBL = Lookup(strRegEx, strLookup)
	Dim strRegEx2 : strRegEx2 = "127\.255\.255\.25(2|4|5)"
	Set Matches = oLookup(strRegEx2, strLookup, False)
	For Each Match In Matches
		If Match.Value = "127.255.255.252" Then
			EventLog.Write("Spamhaus DBL Error: Typing error in DNSBL name: " & strDomain)
		ElseIf Match.Value = "127.255.255.254" Then
			EventLog.Write("Spamhaus DBL Error: Anonymous query through public resolver: " & strDomain)
		ElseIf Match.Value = "127.255.255.255" Then
			EventLog.Write("Spamhaus DBL Error: Excessive number of queries")
		ElseIf Match.Value = "" Then
			EventLog.Write("Spamhaus DBL Error: Unknown Error: " & Match.Value)
Sub OnHELO(oClient)
	'	Exclude local LAN & Backup from test
	If (Left(oClient.IPAddress, 8) = "192.168.") Then Exit Sub
	If (Left(oClient.IPAddress, 12) = "184.105.182.") Then Exit Sub
	'	Test Spamhaus Domain Block List on HELO
	Dim a, shDomain
	Dim Match, Matches
	Dim strRegex : strRegex = "([a-zA-Z0-9-]{1,63}\.)(((net|co|com)\.){0,1})[a-zA-Z]{2,63}$"
		shDomain = Match.Value
	If IsInSpamHausDBL(shDomain) Then
		Result.Value = 2
		Result.Message = ". 15 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
		Exit Sub
	'	Exclude authenticated users test
	If (oClient.Username <> "") Then Exit Sub
	'	Test Spamhaus Domain Block List on From Address
	Dim shDBLdomain
	a = Split( oMessage.Recipients(0).OriginalAddress, "@" )
	shDBLdomain = Trim( CStr( a(1) ) )
	If IsInSpamHausDBL(shDBLdomain) Then
		Result.Value = 2
		Exit Sub
Re: Reject on Spamhaus DBL
Post by SorenR » 2019-07-28 15:59
Well, I have apparently been using it for a long time ;-) It is listed as one of my URIBL servers :mrgreen:
The big challenge is that you need to convert to 2LD (Second-level) domain for dbl.spamhaus.org to check.
Usually a 2LD is like "example.com" but it can also be like "example.rj.gov.br" or "example.fukuchi.fukuoka.jp" (this is real!). Regex will NOT solve this problem :mrgreen:
Here is a somewhat authoritative list of TLD's and ccTLD's.
https://publicsuffix.org/list/public_suffix_list.dat
Here's some inspiration: https://dzone.com/articles/extract-second-and-top-level
Post by palinka » 2019-07-28 20:53
2019-07-28 15:59
Yes, but that's for scoring not reject connection. :wink:
"example.rj.gov.br" and "example.fukuchi.fukuoka.jp" are 3rd and 4th level domains, respectively. The regex I'm using would pick up rj.gov.br (if i added gov to the list of intermediary TLDs - right now i have co|com|net - I'l add gov today :D ) and fukuoka.jp. I'm not really sure if SH DBL looks at 3rd level domains. I could add that to the list of tests. Maybe i should, because I've only had 4 hits in 36 hours of testing on HELO. Maybe adding 3rd level will draw in more hits. I don't really know.
Have a look at this: https://regex101.com/r/FqiHHX/3
Cool. I looked at the public suffix link while making this. In the end, of course, i decided on regex, which should hit 99% of 2LD. Adding gov to the list will make it 99.001%. :mrgreen:
I'l check out the other link too. Thanks.
Post by SorenR » 2019-07-28 21:48
2019-07-28 20:53
According to the list https://publicsuffix.org/list/ both "rj.gov.br" and "fukuchi.fukuoka.jp" are TLD's.
Post by palinka » 2019-07-28 21:55
2019-07-28 21:48
2019-07-28 20:53
erotica.hu
erotika.hu
Also TLDs. :mrgreen:
Looks like I'l have to take a second run at it. :mrgreen:
Post by SorenR » 2019-07-28 22:19
I had a read here: https://docs.spamhaustech.com/70-access ... ery-format
it seems that ...
It must be emphasized that both dbl and zrd are wildcarded zones that do not consider the hostname part of fully qualified domain names. Therefore, fully qualified domain names can be inserted as they are in the DNS queries, without having to strip away the domain part.
So ... waste of time to manipulate URL's :mrgreen:
Post by palinka » 2019-07-29 12:04
Good catch and way easier to fix!
Sub OnHELO(oClient)
	If IsInSpamHausDBL(oClient.HELO) Then
		Result.Value = 2
		Exit Sub
simple! :mrgreen:
Post by SorenR » 2019-07-29 13:35
I got 4 (!) hits in 92 lookups over the past 14 hours ... :roll:
I check PTR (if any) in OnClientConnect() and oClient.HELO in OnHELO() and log the result. All 4 are found using PTR's and they are all 127.0.1.2's.
Function Spamhaus(strDomain)
    Dim strLookup
    Select Case strLookup
        Case "127.0.1.2"
             Spamhaus = "spam domain"
        Case "127.0.1.4"
             Spamhaus = "phish domain"
        Case "127.0.1.5"
             Spamhaus = "malware domain"
        Case "127.0.1.6"
             Spamhaus = "botnet C&C domain"
        Case "127.0.1.102"
             Spamhaus = "abused legit spam"
        Case "127.0.1.103"
             Spamhaus = "abused spammed redirector domain"
        Case "127.0.1.104"
             Spamhaus = "abused legit phish"
        Case "127.0.1.105"
             Spamhaus = "abused legit malware"
        Case "127.0.1.106"
             Spamhaus = "abused legit botnet C&C"
        Case "127.0.1.255"
             Spamhaus = "IP queries prohibited!"
        Case "127.255.255.252"
             Spamhaus = "Typing error in DNSBL name"
        Case "127.255.255.254"
             Spamhaus = "Anonymous query through public resolver"
        Case "127.255.255.255"
             Spamhaus = "Excessive number of queries"
        Case Else
             Spamhaus = strLookup
    End Select
Thread
ID       Date/time                  Action            IP Address        Port  IP/SPAM Info      PTR/HELO/Service
780      "2019-07-29 00:47:38.038"  "--- Connect ---  107.170.240.68    465   - Level 3         zg-0403-22.stretchoid.com"
780      "2019-07-29 00:47:38.226"  "Spamhaus DBL     107.170.240.68          spam domain       zg-0403-22.stretchoid.com"
780      "2019-07-29 00:47:38.413"  "GEOBlock         107.170.240.68                            SMTPS"
780      "2019-07-29 00:47:39.896"  "DISCONNECT       107.170.240.68"
3928     "2019-07-29 03:40:11.454"  "--- Connect ---  162.243.145.33    993   - Level 3         zg-0326a-22.stretchoid.com"
3928     "2019-07-29 03:40:11.718"  "Spamhaus DBL     162.243.145.33          spam domain       zg-0326a-22.stretchoid.com"
3928     "2019-07-29 03:40:11.718"  "GEOBlock         162.243.145.33                            IMAPS"
3928     "2019-07-29 03:40:13.204"  "DISCONNECT       162.243.145.33"
780      "2019-07-29 05:00:06.943"  "--- Connect ---  162.243.143.89    465   - Level 3         zg-0326a-15.stretchoid.com"
780      "2019-07-29 05:00:07.099"  "Spamhaus DBL     162.243.143.89          spam domain       zg-0326a-15.stretchoid.com"
780      "2019-07-29 05:00:07.240"  "GEOBlock         162.243.143.89                            SMTPS"
780      "2019-07-29 05:00:08.724"  "DISCONNECT       162.243.143.89"
3184     "2019-07-29 08:05:03.804"  "--- Connect ---  159.89.52.68      25    - Level 5         nowsmart.info"
3184     "2019-07-29 08:05:03.898"  "Spamhaus DBL     159.89.52.68            spam domain       nowsmart.info"
3184     "2019-07-29 08:05:03.898"  "IDS Add          159.89.52.68"
3184     "2019-07-29 08:05:04.007"  "SnowShoe         159.89.52.68"
3184     "2019-07-29 08:05:05.492"  "DISCONNECT       159.89.52.68"
Post by palinka » 2019-07-29 15:41
37 hits since I started watching. Since I was submitting only the "2LD" parsed via regex, potentially I could have had one or two more hits if I submitted the entire hostname.
All but one of them was picked up by spamhaus zen. That's good! Any variation means that it could be useful for connection rejection. Certainly ANY email address containing a match is worthy of message rejection. I think I'll put it into use today. (I already implemented message rejection). I would put this last in line of OnHELO filters.
Below is my test scoring (only hits on SH DBL). I DO reject on spamhaus zen and UCEProtect, but the others are just to see how they stack up.
7/29/2019 8:40:32 AM - 192.236.192.244 - Netherlands
7/29/2019 8:40:32 AM - 192.236.192.244 - prep.sleepycool.pro
7/29/2019 8:40:32 AM - 192.236.192.244 - Spamhaus: DBL
7/29/2019 8:40:32 AM - 192.236.192.244 - SpamDonkey: Level 5
7/29/2019 8:40:31 AM - 192.236.192.244 - HostKarma: BlackListed
7/29/2019 8:40:31 AM - 192.236.192.244 - Spamhaus: SBL
7/29/2019 7:05:30 AM - 170.0.125.163 - Brazil
7/29/2019 7:05:30 AM - 170.0.125.163 - 163-125-0-170.castelecom.com.br
7/29/2019 7:05:30 AM - 170.0.125.163 - Spamhaus: DBL
7/29/2019 7:05:30 AM - 170.0.125.163 - SpamDonkey: Level 5
7/29/2019 7:05:29 AM - 170.0.125.163 - UCEProtect-Network: Reject
7/29/2019 7:05:29 AM - 170.0.125.163 - SpamCop: Reject
7/29/2019 7:05:29 AM - 170.0.125.163 - HostKarma: YellowListed
7/29/2019 7:05:29 AM - 170.0.125.163 - Spamhaus: XBL
7/29/2019 6:16:04 AM - 142.11.233.26 - United States
7/29/2019 6:16:04 AM - 142.11.233.26 - armoured.dietgodbalance.us
7/29/2019 6:16:04 AM - 142.11.233.26 - Spamhaus DBL:
7/29/2019 6:16:03 AM - 142.11.233.26 - SpamDonkey: Level 5
7/29/2019 6:16:03 AM - 142.11.233.26 - HostKarma: BlackListed
7/29/2019 6:16:03 AM - 142.11.233.26 - Spamhaus: SBL
7/29/2019 6:11:24 AM - 170.0.125.67 - Brazil
7/29/2019 6:11:24 AM - 170.0.125.67 - 67-125-0-170.castelecom.com.br
7/29/2019 6:11:24 AM - 170.0.125.67 - Spamhaus DBL: castelecom.com.br
7/29/2019 6:11:23 AM - 170.0.125.67 - SpamDonkey: Level 5
7/29/2019 6:11:23 AM - 170.0.125.67 - UCEProtect-Network: Reject
7/29/2019 6:11:23 AM - 170.0.125.67 - SpamCop: Reject
7/29/2019 6:11:22 AM - 170.0.125.67 - HostKarma: YellowListed
7/29/2019 6:11:22 AM - 170.0.125.67 - Spamhaus: XBL
7/29/2019 5:31:24 AM - 142.11.218.182 - United States
7/29/2019 5:31:24 AM - 142.11.218.182 - axe.gltusunlock.xyz
7/29/2019 5:31:24 AM - 142.11.218.182 - Spamhaus DBL: gltusunlock.xyz
7/29/2019 5:31:18 AM - 142.11.218.182 - HostKarma: BlackListed
7/29/2019 5:31:18 AM - 142.11.218.182 - Spamhaus: SBL
7/29/2019 5:27:34 AM - 170.0.126.42 - Brazil
7/29/2019 5:27:34 AM - 170.0.126.42 - 42-126-0-170.castelecom.com.br
7/29/2019 5:27:33 AM - 170.0.126.42 - Spamhaus DBL: castelecom.com.br
7/29/2019 5:27:27 AM - 170.0.126.42 - UCEProtect-Network: Reject
7/29/2019 5:27:27 AM - 170.0.126.42 - SpamCop: Reject
7/29/2019 5:27:26 AM - 170.0.126.42 - HostKarma: YellowListed
7/29/2019 5:27:26 AM - 170.0.126.42 - Spamhaus: SBL
7/28/2019 7:50:58 PM - 23.237.22.120 - United States
7/28/2019 7:50:58 PM - 23.237.22.120 - mail.novaemporio.com
7/28/2019 7:50:58 PM - 23.237.22.120 - Spamhaus DBL: novaemporio.com
7/28/2019 7:50:57 PM - 23.237.22.120 - SpamDonkey: Level 5
7/28/2019 7:50:56 PM - 23.237.22.120 - Spamhaus: SBL
7/28/2019 7:35:03 PM - 89.144.49.194 - Germany
7/28/2019 7:35:03 PM - 89.144.49.194 - ada37.com
7/28/2019 7:35:03 PM - 89.144.49.194 - Spamhaus DBL: ada37.com
7/28/2019 7:35:02 PM - 89.144.49.194 - SpamDonkey: Level 5
7/28/2019 7:35:02 PM - 89.144.49.194 - Spamhaus: SBL
7/28/2019 7:01:55 PM - 23.237.22.128 - United States
7/28/2019 7:01:55 PM - 23.237.22.128 - mail.nsglimitedgroup.com
7/28/2019 7:01:54 PM - 23.237.22.128 - Spamhaus DBL: nsglimitedgroup.com
7/28/2019 7:01:54 PM - 23.237.22.128 - SpamDonkey: Level 5
7/28/2019 7:01:53 PM - 23.237.22.128 - Spamhaus: SBL
7/28/2019 6:39:40 PM - 177.73.188.80 - Brazil
7/28/2019 6:39:40 PM - 177.73.188.80 - 80.188.73.177.ivtelecom.net.br
7/28/2019 6:39:40 PM - 177.73.188.80 - Spamhaus DBL: ivtelecom.net.br
7/28/2019 6:39:39 PM - 177.73.188.80 - SpamDonkey: Level 5
7/28/2019 6:39:38 PM - 177.73.188.80 - UCEProtect-Network: Reject
7/28/2019 6:39:38 PM - 177.73.188.80 - SpamCop: Reject
7/28/2019 6:39:38 PM - 177.73.188.80 - HostKarma: BlackListed
7/28/2019 6:39:38 PM - 177.73.188.80 - Spamhaus: SBL
7/28/2019 6:19:39 PM - 63.80.190.58 - United States
7/28/2019 6:19:39 PM - 63.80.190.58 - allspinsgo.com
7/28/2019 6:19:39 PM - 63.80.190.58 - Spamhaus DBL: allspinsgo.com
7/28/2019 6:19:39 PM - 63.80.190.58 - SpamDonkey: Level 2
7/28/2019 6:19:37 PM - 63.80.190.58 - Spamhaus: SBL
7/28/2019 6:13:40 PM - 23.237.22.129 - United States
7/28/2019 6:13:40 PM - 23.237.22.129 - mail.nuenomics.com
7/28/2019 6:13:40 PM - 23.237.22.129 - Spamhaus DBL: nuenomics.com
7/28/2019 6:13:39 PM - 23.237.22.129 - SpamDonkey: Level 5
7/28/2019 6:13:39 PM - 23.237.22.129 - Spamhaus: SBL
7/28/2019 6:09:14 PM - 63.80.190.56 - United States
7/28/2019 6:09:14 PM - 63.80.190.56 - 1tacfl.com
7/28/2019 6:09:13 PM - 63.80.190.56 - Spamhaus DBL: 1tacfl.com
7/28/2019 6:09:13 PM - 63.80.190.56 - SpamDonkey: Level 2
7/28/2019 6:09:11 PM - 63.80.190.56 - SpamCop: Reject
7/28/2019 6:09:11 PM - 63.80.190.56 - Spamhaus: SBL
7/28/2019 5:52:59 PM - 185.55.243.141 - Germany
7/28/2019 5:52:59 PM - 185.55.243.141 - 52lbsin30days.com
7/28/2019 5:52:59 PM - 185.55.243.141 - Spamhaus DBL: 52lbsin30days.com
7/28/2019 5:52:59 PM - 185.55.243.141 - SpamDonkey: Level 5
7/28/2019 5:52:58 PM - 185.55.243.141 - Spamhaus: SBL
7/28/2019 5:41:41 PM - 167.89.24.178 - United States
7/28/2019 5:41:41 PM - 167.89.24.178 - o45.email.Careersearcher.org
7/28/2019 5:41:41 PM - 167.89.24.178 - Spamhaus DBL: Careersearcher.org
7/28/2019 5:41:41 PM - 167.89.24.178 - SpamDonkey: Level 1
7/28/2019 5:41:32 PM - 167.89.24.178 - Spamhaus: SBL
7/28/2019 5:36:04 PM - 23.237.22.126 - United States
7/28/2019 5:36:04 PM - 23.237.22.126 - mail.nrgdrive.com
7/28/2019 5:36:04 PM - 23.237.22.126 - Spamhaus DBL: nrgdrive.com
7/28/2019 5:36:03 PM - 23.237.22.126 - SpamDonkey: Level 5
7/28/2019 5:36:03 PM - 23.237.22.126 - Spamhaus: SBL
7/28/2019 5:23:41 PM - 89.144.63.167 - Germany
7/28/2019 5:23:41 PM - 89.144.63.167 - achrisknows.com
7/28/2019 5:23:41 PM - 89.144.63.167 - Spamhaus DBL: achrisknows.com
7/28/2019 5:23:41 PM - 89.144.63.167 - SpamDonkey: Level 5
7/28/2019 5:23:40 PM - 89.144.63.167 - Spamhaus: SBL
7/28/2019 5:10:50 PM - 69.94.156.234 - United States
7/28/2019 5:10:50 PM - 69.94.156.234 - ada40.com
7/28/2019 5:10:50 PM - 69.94.156.234 - Spamhaus DBL: ada40.com
7/28/2019 5:10:49 PM - 69.94.156.234 - SpamDonkey: Level 2
7/28/2019 5:10:49 PM - 69.94.156.234 - Spamhaus: SBL
7/28/2019 4:52:33 PM - 89.144.49.192 - Germany
7/28/2019 4:52:33 PM - 89.144.49.192 - 0costreading.com
7/28/2019 4:52:33 PM - 89.144.49.192 - Spamhaus DBL: 0costreading.com
7/28/2019 4:52:33 PM - 89.144.49.192 - SpamDonkey: Level 5
7/28/2019 4:52:32 PM - 89.144.49.192 - Spamhaus: SBL
7/28/2019 4:44:24 PM - 63.80.185.218 - United States
7/28/2019 4:44:24 PM - 63.80.185.218 - 1compreading.com
7/28/2019 4:44:24 PM - 63.80.185.218 - Spamhaus DBL: 1compreading.com
7/28/2019 4:44:24 PM - 63.80.185.218 - SpamDonkey: Level 2
7/28/2019 4:44:22 PM - 63.80.185.218 - SpamCop: Reject
7/28/2019 4:44:22 PM - 63.80.185.218 - Spamhaus: SBL
7/28/2019 4:35:32 PM - 23.237.22.136 - United States
7/28/2019 4:35:32 PM - 23.237.22.136 - mail.openyourawareness.com
7/28/2019 4:35:32 PM - 23.237.22.136 - Spamhaus DBL: openyourawareness.com
7/28/2019 4:35:32 PM - 23.237.22.136 - SpamDonkey: Level 5
7/28/2019 4:35:31 PM - 23.237.22.136 - Spamhaus: SBL
7/28/2019 4:31:10 PM - 69.94.156.232 - United States
7/28/2019 4:31:09 PM - 69.94.156.232 - 10daysleep.com
7/28/2019 4:31:09 PM - 69.94.156.232 - Spamhaus DBL: 10daysleep.com
7/28/2019 4:31:09 PM - 69.94.156.232 - SpamDonkey: Level 3
7/28/2019 4:31:07 PM - 69.94.156.232 - SpamCop: Reject
7/28/2019 4:31:07 PM - 69.94.156.232 - Spamhaus: SBL
7/28/2019 4:09:51 PM - 104.218.63.102 - Pakistan
7/28/2019 4:09:51 PM - 104.218.63.102 - todaynews.host
7/28/2019 4:09:50 PM - 104.218.63.102 - Spamhaus DBL: todaynews.host
7/28/2019 4:09:50 PM - 104.218.63.102 - SpamDonkey: Level 5
7/28/2019 4:09:45 PM - 104.218.63.102 - UCEProtect-Network: Reject
7/28/2019 4:09:45 PM - 104.218.63.102 - SpamCop: Reject
7/28/2019 4:09:45 PM - 104.218.63.102 - HostKarma: BlackListed
7/28/2019 4:09:45 PM - 104.218.63.102 - Spamhaus: XBL
7/28/2019 3:01:03 PM - 89.144.63.165 - Germany
7/28/2019 3:01:03 PM - 89.144.63.165 - 0costchris.com
7/28/2019 3:01:03 PM - 89.144.63.165 - Spamhaus DBL: 0costchris.com
7/28/2019 3:01:03 PM - 89.144.63.165 - SpamDonkey: Level 5
7/28/2019 3:01:02 PM - 89.144.63.165 - Spamhaus: SBL
7/28/2019 2:37:40 PM - 69.94.156.234 - United States
7/28/2019 2:37:40 PM - 69.94.156.234 - ada40.com
7/28/2019 2:37:40 PM - 69.94.156.234 - Spamhaus DBL: ada40.com
7/28/2019 2:37:40 PM - 69.94.156.234 - SpamDonkey: Level 2
7/28/2019 1:39:36 PM - 185.55.243.139 - Germany
7/28/2019 1:39:36 PM - 185.55.243.139 - 0722july.com
7/28/2019 1:39:36 PM - 185.55.243.139 - Spamhaus DBL: 0722july.com
7/28/2019 1:39:35 PM - 185.55.243.139 - SpamDonkey: Level 5
7/28/2019 1:39:34 PM - 185.55.243.139 - Spamhaus: SBL
7/28/2019 1:39:21 PM - 89.207.169.93 - Poland
7/28/2019 1:39:21 PM - 89.207.169.93 - 023cd68f.carwarranty.racing
7/28/2019 1:39:21 PM - 89.207.169.93 - Spamhaus DBL: carwarranty.racing
7/28/2019 1:39:21 PM - 89.207.169.93 - SpamDonkey: Level 5
7/28/2019 1:39:20 PM - 89.207.169.93 - Spamhaus: SBL
7/28/2019 9:51:47 AM - 175.29.179.106 - Bangladesh
7/28/2019 9:51:47 AM - 175.29.179.106 - lipplus.it
7/28/2019 9:51:47 AM - 175.29.179.106 - Spamhaus DBL: lipplus.it
7/28/2019 9:51:46 AM - 175.29.179.106 - SpamDonkey: Level 5
7/28/2019 9:51:46 AM - 175.29.179.106 - UCEProtect-Network: Reject
7/28/2019 9:51:46 AM - 175.29.179.106 - SpamCop: Reject
7/28/2019 9:51:45 AM - 175.29.179.106 - HostKarma: BlackListed
7/28/2019 9:51:45 AM - 175.29.179.106 - Spamhaus: SBL
7/28/2019 9:50:50 AM - 170.0.126.202 - Brazil
7/28/2019 9:50:50 AM - 170.0.126.202 - 202-126-0-170.castelecom.com.br
7/28/2019 9:50:50 AM - 170.0.126.202 - Spamhaus DBL: castelecom.com.br
7/28/2019 9:50:49 AM - 170.0.126.202 - SpamDonkey: Level 5
7/28/2019 9:50:49 AM - 170.0.126.202 - UCEProtect-Network: Reject
7/28/2019 9:50:49 AM - 170.0.126.202 - SpamCop: Reject
7/28/2019 9:50:49 AM - 170.0.126.202 - HostKarma: YellowListed
7/28/2019 9:50:48 AM - 170.0.126.202 - Spamhaus: XBL
7/28/2019 9:26:16 AM - 170.0.125.140 - Brazil
7/28/2019 9:26:16 AM - 170.0.125.140 - 140-125-0-170.castelecom.com.br
7/28/2019 9:26:16 AM - 170.0.125.140 - Spamhaus DBL: castelecom.com.br
7/28/2019 9:26:15 AM - 170.0.125.140 - SpamDonkey: Level 5
7/28/2019 9:26:15 AM - 170.0.125.140 - UCEProtect-Network: Reject
7/28/2019 9:26:15 AM - 170.0.125.140 - SpamCop: Reject
7/28/2019 9:26:14 AM - 170.0.125.140 - Spamhaus: SBL
7/28/2019 8:16:36 AM - 192.236.192.21 - Netherlands
7/28/2019 8:16:36 AM - 192.236.192.21 - 0590148d.sleptwid.bid
7/28/2019 8:16:36 AM - 192.236.192.21 - Spamhaus DBL: sleptwid.bid
7/28/2019 8:16:36 AM - 192.236.192.21 - SpamDonkey: Level 5
7/28/2019 8:16:35 AM - 192.236.192.21 - Spamhaus: SBL
7/28/2019 6:28:30 AM - 192.236.192.14 - Netherlands
7/28/2019 6:28:30 AM - 192.236.192.14 - 05901489.plnefly.bid
7/28/2019 6:28:30 AM - 192.236.192.14 - Spamhaus DBL: plnefly.bid
7/28/2019 6:28:30 AM - 192.236.192.14 - SpamDonkey: Level 5
7/28/2019 6:28:29 AM - 192.236.192.14 - Spamhaus: SBL
7/28/2019 3:25:37 AM - 170.0.126.53 - Brazil
7/28/2019 3:25:37 AM - 170.0.126.53 - 53-126-0-170.castelecom.com.br
7/28/2019 3:25:37 AM - 170.0.126.53 - Spamhaus DBL: castelecom.com.br
7/28/2019 3:25:37 AM - 170.0.126.53 - SpamDonkey: Level 5
7/28/2019 3:25:36 AM - 170.0.126.53 - UCEProtect-Network: Reject
7/28/2019 3:25:36 AM - 170.0.126.53 - SpamCop: Reject
7/28/2019 3:25:36 AM - 170.0.126.53 - HostKarma: YellowListed
7/28/2019 3:25:36 AM - 170.0.126.53 - Spamhaus: SBL
7/27/2019 6:29:51 PM - 170.0.125.123 - Brazil
7/27/2019 6:29:51 PM - 170.0.125.123 - 123-125-0-170.castelecom.com.br
7/27/2019 6:29:50 PM - 170.0.125.123 - Spamhaus DBL: castelecom.com.br
7/27/2019 6:29:50 PM - 170.0.125.123 - SpamDonkey: Level 5
7/27/2019 6:29:49 PM - 170.0.125.123 - UCEProtect-Network: Reject
7/27/2019 6:29:49 PM - 170.0.125.123 - SpamCop: Reject
7/27/2019 6:29:49 PM - 170.0.125.123 - Spamhaus: XBL
7/27/2019 12:16:14 PM - 142.11.211.51 - United States
7/27/2019 12:16:14 PM - 142.11.211.51 - 023cd67d.neverpainagain.bid
7/27/2019 12:16:14 PM - 142.11.211.51 - Spamhaus DBL: neverpainagain.bid
7/27/2019 12:16:13 PM - 142.11.211.51 - SpamDonkey: Level 5
7/27/2019 12:16:13 PM - 142.11.211.51 - Spamhaus: SBL
7/27/2019 10:41:59 AM - 197.254.108.110 - Kenya
7/27/2019 10:41:59 AM - 197.254.108.110 - 197.254.108.110.acesskenya.net
7/27/2019 10:41:59 AM - 197.254.108.110.acesskenya.net - Spamhaus DBL: acesskenya.net
7/27/2019 10:41:54 AM - 197.254.108.110 - SpamDonkey: Level 5
7/27/2019 10:41:54 AM - 197.254.108.110 - UCEProtect-Network: Reject
7/27/2019 10:41:53 AM - 197.254.108.110 - SpamCop: Reject
7/27/2019 10:41:53 AM - 197.254.108.110 - HostKarma: BlackListed
7/27/2019 10:41:53 AM - 197.254.108.110 - Spamhaus: SBL
7/27/2019 10:39:07 AM - 195.201.133.156 - Germany
7/27/2019 10:39:07 AM - 195.201.133.156 - user0.jugar.xyz
7/27/2019 10:39:07 AM - user0.jugar.xyz - Spamhaus DBL: jugar.xyz
7/27/2019 10:39:07 AM - 195.201.133.156 - SpamDonkey: Level 5
7/27/2019 10:39:06 AM - 195.201.133.156 - Spamhaus: SBL
Post by palinka » 2019-07-31 16:02
Uce-protect hit on a few Amazon ses IPs, which then were rejected. I later found out Amazon ses is perennially blacklisted by uce protect. The are plenty of spammers on Amazon ses, but plenty of non spammers too. Unfortunately i can't know if these were spam or ham since i did not receive the message.
Looks like only spamhaus is good for rejection. I've been monitoring that a long time and never to my knowledge have had a false positive.
avidity
Post by avidity » 2020-01-20 19:12
I'm looking into using Spamhaus DBL, but if I'm reading correctly, it requires a modified hMailServer plus some scripts. I'm not sure I'm up to building a "custom" hMailServer.
Post by SorenR » 2020-01-20 19:53
2019-07-31 16:02
You need those rejected emails to train your SpamAssassin :!:
I only reject banned servers, snowshoe and lashback SPAM senders. The rest goes to my SPAM account for processing.
Post by palinka » 2020-01-20 20:06
2020-01-20 19:53
Nah.... I prefer a spam free lifestyle. :lol:
And who is so worthily credentialed as to decide which servers get banned? :mrgreen:
Anyway, I made changes recently that ensure all messages go to SA. That was a byproduct of obtaining a unique identifier for my connection db project.
Post by mattg » 2020-01-21 00:31
avidity wrote:
2020-01-20 19:12
I simply use dbl.spamhaus.org as a SURBL server in hMailserver and score accordingly
This is the logged output
"DEBUG"	20152	"2020-01-16 05:53:30.345"	"SURBL: 7 unique addresses found."
"DEBUG"	20152	"2020-01-16 05:53:30.364"	"SURBL: Lookup: facebook.com.dbl.spamhaus.org"
"DEBUG"	20152	"2020-01-16 05:53:30.391"	"SURBL: Lookup: googleapis.com.dbl.spamhaus.org"
"DEBUG"	20152	"2020-01-16 05:53:30.423"	"SURBL: Lookup: linkedin.com.dbl.spamhaus.org"
"DEBUG"	20152	"2020-01-16 05:53:30.438"	"SURBL: Lookup: pinterest.com.dbl.spamhaus.org"
"DEBUG"	16972	"2020-01-16 05:53:30.454"	"SURBL: Match found"
"DEBUG"	16972	"2020-01-16 05:53:30.454"	"SURBL: Execute"
"DEBUG"	16972	"2020-01-16 05:53:30.454"	"SURBL: Found URL: outpieter.vip"
"DEBUG"	16972	"2020-01-16 05:53:30.454"	"SURBL: 1 unique addresses found."
"DEBUG"	16972	"2020-01-16 05:53:30.454"	"SURBL: Lookup: outpieter.vip.dbl.spamhaus.org"
"DEBUG"	20152	"2020-01-16 05:53:30.470"	"SURBL: Lookup: smartdraw.com.dbl.spamhaus.org"
"DEBUG"	16972	"2020-01-16 05:53:30.485"	"SURBL: Match not found"
"DEBUG"	16972	"2020-01-16 05:53:30.485"	"SURBL: Execute"
"DEBUG"	16972	"2020-01-16 05:53:30.485"	"SURBL: Found URL: outpieter.vip"
