Check incoming connections with AbuseIPDB
Po-In
Post by Po-In » 2018-05-14 15:09
Hi all,
I use the website www.AbuseIPDB.com quite a lot for looking up malicious IP addresses.
I've also created some code that will query the AbuseIPDB API and evaluate the response to reject the connection if reported more than 10 times in the last 30 days.
Please note that you need register at AbuseIPDB to obtain an API key.
Use at your own discretion...
Good luck!
EDIT: UPDATED WORKING VERSION FOLLOWS IN THE SECOND POST. (mod.)
Sub OnClientConnect(oClient)
'Variables
   ClientIp       = oClient.IpAddress                 'Connecting remote IP address
   ClientPort     = oClient.Port                      'Port it is connecting to
   DetectPort     = 25                                'Variable port to check
   LocalHost      = "127.0.0.1"                       'Variable for LocalHost IP address
   APIkey         = "GetYourOwn"                      'API key (get your own at AbuseIPDB.Com)
   APIDays        = 30                                'Variable AbuseIPDB history in days
   APICount       = 10                                'Variable threshold to use for rejecting connections
'Check IP Address with AbuseIPDB API
   If ClientPort = DetectPort and ClientIp <> LocalHost Then
      Set objXMLHTTP = CreateObject("msxml2.xmlhttp.6.0")
      objXMLHTTP.Open "GET", "https://www.abuseipdb.com/check/" & ClientIp & "/json", False
      objXMLHTTP.setRequestHeader "Content-Type", "application/json"
      objXMLHTTP.Send "key=" & APIKey & "&days=" & APIDays
      ResponseText = objXMLHTTP.responseText
'Evaluate response (quick & dirty JSON 'parsing')
      If ResponseText <> "[]" and InStr(Replace(ResponseText, chr(34),""),"isWhitelisted:true") = 0 then
         RecordCount = CountString(ResponseText, ClientIp)
'Reject connection and write eventlog
         If RecordCount > APICount Then
            Result.Value = 1
            EventLog.Write ("AbuseIPDB: IP Address " & ClientIp & " rejected (reported " & RecordCount & " times)")
'Accept connection and write warning in eventlog
            Result.Value = 0
            EventLog.Write ("AbuseIPDB: IP Address " & ClientIp & " warning  (reported " & RecordCount & " times)")
'Accept connection because IP address is reported but whitelisted at AbuseIPDB
      If ResponseText <> "[]" and InStr(Replace(ResponseText, chr(34),""),"isWhitelisted:true") <> 0 then
         Result.Value = 0
         EventLog.Write ("AbuseIPDB: IP Address " & ClientIp & " whitelisted (reported " & RecordCount & " times)")
      Set objXMLHTTP = Nothing
Public Function CountString(VariableString, SearchString)
   CountString = 0
      For x = 1 to len(VariableString) - len(SearchString)
         If Mid(VariableString,x,len(SearchString)) = SearchString then
            CountString = CountString +1
Po-In
Re: Check incoming connections with AbuseIPDB
Post by Po-In » 2018-05-16 10:13
Version 2: :roll:
'Variables
      objXMLHTTP.Open "GET", "https://www.abuseipdb.com/check/" & ClientIp & "/json?key=" & APIKey & "&days=" &APIDays, False
      objXMLHTTP.Send ""
            Result.Value = 1
            Result.Value = 0
         Result.Value = 0
   CountString = 0
Post by jimimaseye » 2018-05-17 09:03
If it does what you say it does and it is effective (I havent tried it) then it looks good. Thanks for posting.
Po-In
Post by Po-In » 2018-05-24 09:45
I wish I could keep editting or delete the original post(s), because the code is evolving :)
Post by jimimaseye » 2018-05-24 10:08
Post your updates - I or mod Mattg can edit the thread and remove old posts/code if you want. Just make it clear about what is what.
Po-In
UPDATE: Check incoming connections with AbuseIPDB
Post by Po-In » 2018-05-24 13:46
Here's one that doesn't need registration (even though I think you should register anyway and show some support to AbuseIPDB).
The function 'CheckAbuseIPDBConfidence' returns the 'Confidence of Abuse' percentage for the given IP address, as calculated by AbuseIPDB.
It parses the page data until it finds the section that represents the value. This will work as long as AbuseIPDB doesn't change the design :)
As shown below, I refuse connections from IP addresses that score higher than 40%, which works pretty well for me.
About 75% of the connecting IP addresses score 40 or above, so it helps a lot.
'Variables
	WhiteList				= "#127.0.0.1#a.b.c.d#1.2.3.4#"		'Variable array for whitelisted IP addresses to exclude, localhost, maybe your servers IP address, your WebClient IP address whatever
	Percentage 				= "0"					'Default value
'Check if connecting client isn't whitelisted
	If Instr(WhiteList, "#" & ClientIp & "#") = 0 Then
		Percentage			= CheckAbuseIPDBConfidence(ClientIP)
'Process reported percentage
		If Percentage > 40 then
			Result.Value 		= 1
			EventLog.Write ("AbuseIPDB: IP Address " & ClientIp & " rejected: Confidence of Abuse: " & Percentage & "%.")
		ElseIf Percentage > 10 then
			Result.Value 		= 0
			EventLog.Write ("AbuseIPDB: IP Address " & ClientIp & " warning: Confidence of Abuse: " & Percentage & "%.")
		ElseIf Percentage > 0 then
			Result.Value 		= 0
			EventLog.Write ("AbuseIPDB: IP Address " & ClientIp & " notification: Confidence of Abuse: " & Percentage & "%.")
Public Function CheckAbuseIPDBConfidence(IPAddress)
	CheckAbuseIPDBConfidence		= "0"
		objXMLHTTP.Open "GET", "https://www.abuseipdb.com/check/" & IPAddress, False
		objXMLHTTP.Send ""
		ResponseArray			= Split(ResponseText, VbLf)
		For Each ResponseLine in ResponseArray
			If Left(ResponseLine, 6) = "<span>" And Right(ResponseLine, 8) = "%</span>" Then
				CheckAbuseIPDBConfidence 	= Mid(ResponseLine,7, Len(ResponseLine)-14)
				Exit For
insomniac2k2
Post by insomniac2k2 » 2018-08-26 16:28
I'm actually surprised that this script has not seen more interest. With something like this combined to an autoban or even better, firewall ban inclusion, some wonderful things could happen.
For example:
Using Sorren's AutoBan logic and Cports, you would reject, ban the ip address, and forcefully close the connection. Never to hear from them again:
'Variables
	WhiteList				= "#127.0.0.1#A.B.C.D#1.2.3.4#"		'Variable array for whitelisted IP addresses to exclude, localhost, maybe your servers IP address, your WebClient IP address whatever
			Result.Value 		= 1
			Call AutoBan(oClient.IPAddress, "IP Address Spamlisted", 2, "d")
			Result.Value 		= 0
			Result.Value 		= 0
'     sType can be one of the following;
'     "yyyy" Year, "m" Month, "d" Day, "h" Hour, "n" Minute, "s" Second
'     Cports can be obtained here -> http://www.nirsoft.net/utils/cports.html
  Call oApp.Authenticate("*****", "*******")
	 On Error Resume Next
		   .LowerIP = sIPAddress
		   .UpperIP = sIPAddress
		   .Priority = 20
		   .Expires = True
		   .Save
	 On Error Goto 0
	 .Close
	 .Run "CPorts /close * * " & sIPAddress & " *", 0, True
I'm testing it now. Seems to be pretty effective:
3892	"2018-08-26 07:16:15.898"	"AbuseIPDB: IP Address 103.207.39.104 rejected: Confidence of Abuse: 50%."
3696	"2018-08-26 07:16:17.083"	"AbuseIPDB: IP Address 103.207.39.104 rejected: Confidence of Abuse: 50%."
3844	"2018-08-26 07:16:17.083"	"AbuseIPDB: IP Address 103.207.39.104 rejected: Confidence of Abuse: 50%."
3740	"2018-08-26 07:16:17.995"	"AbuseIPDB: IP Address 103.207.39.104 rejected: Confidence of Abuse: 50%."
3848	"2018-08-26 07:16:17.995"	"AbuseIPDB: IP Address 103.207.39.104 rejected: Confidence of Abuse: 50%."
3828	"2018-08-26 07:17:52.496"	"AbuseIPDB: IP Address 113.190.213.119 notification: Confidence of Abuse: 6%."
3768	"2018-08-26 07:17:52.496"	"AbuseIPDB: IP Address 107.158.203.61 notification: Confidence of Abuse: 5%."
3688	"2018-08-26 07:19:47.023"	"AbuseIPDB: IP Address 104.129.21.184 notification: Confidence of Abuse: 5%."
3816	"2018-08-26 07:19:47.023"	"AbuseIPDB: IP Address 104.129.21.184 notification: Confidence of Abuse: 5%."
3760	"2018-08-26 07:20:09.296"	"AbuseIPDB: IP Address 104.254.212.65 warning: Confidence of Abuse: 14%."
3740	"2018-08-26 07:20:10.185"	"AbuseIPDB: IP Address 107.158.203.61 notification: Confidence of Abuse: 5%."
3828	"2018-08-26 07:22:36.930"	"AbuseIPDB: IP Address 45.225.4.91 warning: Confidence of Abuse: 39%."
3688	"2018-08-26 07:22:37.301"	"AbuseIPDB: IP Address 104.129.21.184 notification: Confidence of Abuse: 5%."
3848	"2018-08-26 07:22:38.388"	"AbuseIPDB: IP Address 104.129.21.184 notification: Confidence of Abuse: 5%."
3816	"2018-08-26 07:23:19.955"	"AbuseIPDB: IP Address 182.75.206.218 notification: Confidence of Abuse: 3%."
3740	"2018-08-26 07:23:45.691"	"AbuseIPDB: IP Address 168.205.38.100 warning: Confidence of Abuse: 11%."
3696	"2018-08-26 07:25:28.365"	"AbuseIPDB: IP Address 104.129.21.184 notification: Confidence of Abuse: 5%."
3768	"2018-08-26 07:25:29.198"	"AbuseIPDB: IP Address 203.55.21.251 notification: Confidence of Abuse: 9%."
3816	"2018-08-26 07:25:29.198"	"AbuseIPDB: IP Address 95.31.2.199 notification: Confidence of Abuse: 7%."
3928	"2018-08-26 07:25:50.028"	"AbuseIPDB: IP Address 104.129.21.184 notification: Confidence of Abuse: 5%."
Thank you for your contribution.
Post by SorenR » 2018-08-27 17:54
Site is using TLS 1.2 so they are ruling out anything older than Windows Server 2008 R2 and you still need to manually enable TLS 1.2 on 2008 R2 for scripting.
insomniac2k2
Post by insomniac2k2 » 2018-08-28 17:27
I have banned near 3000 ip addresses in 24 hours using this. I am doing spot lookups on these IP addresses and so far, they are definitely IP addresses that need to be banned!
Hey SorenR,
I take it that you are on an older OS. Have you had any issues using cports to close connections? I cant seem to get it to work with 2016 server. Granted I have not put much debug time into it, but i was forced to change your logic from this:
To this:
	Set objShell2 = CreateObject("WScript.Shell")
	objShell2.Run "CPorts /close * * " & sIPAddress & " *", 0, True
	objShell2.Close
While i no longer get null errors, I don't particularly see it working either. I may have to figure out how to output some feedback to figure it out.
Post by SorenR » 2018-08-28 18:21
Yeah, I'm on Server 2003 R2 :roll:
Your change in logic should not change anything, I have no idea why you get different results.
Perhaps you could try ...
   .Run "runas /savecred /user:administrator CPorts /close * * " & sIPAddress & " *", 0, True
I don't know if it works but it's a thought ;-)
Re. banning servers. I only ban servers from my IDS routine, SPAM, snowshoe and other detections I only deny access when contacted. It's faster this way when you reach 500+ banned servers.
insomniac2k2 wrote:
2018-08-28 17:27
Hey SorenR,
To this:
	objShell2.Close
insomniac2k2
Post by insomniac2k2 » 2018-08-28 18:54
I'll give that a try. Running as admin makes sense.
I've been worried about the ban list getting a little heavy but have not seen performance issues yet. My biggest issues is having remote servers keeping sessions open. I imagine if i get cports working, this issue would become moot.
Thanks for the idea. I'll give it a try now.
2018-08-28 18:21
insomniac2k2 wrote:
2018-08-28 17:27
Hey SorenR,
To this:
	objShell2.Close
Post by RvdH » 2018-08-28 22:34
insomniac2k2 wrote:
2018-08-28 18:54
Well, how big a issue is that actually? The connection will time-out sooner or later... is it really necessary to forcefully close an auto-banned ipaddress ?
insomniac2k2
Post by insomniac2k2 » 2018-08-28 22:39
It's been a real issue several times in the recent past. Even after modifying the allowed amount of threads on the server, I have had hmail stop passing emails due to every thread being used/reserved. Once forcefully releasing these sessions, mail resumes immediately.
I should note that I have very heavy volume servers, so i'm sure that this would not be an issue for most people.
2018-08-28 22:34
insomniac2k2 wrote:
2018-08-28 18:54
Post by RvdH » 2018-08-28 22:42
I can hardly believe that....what are we talking about here? Thousands and thousands of simultaneous connections and all being auto-banned?
You are aware this Cports is only triggered when an ipaddress is auto-banned, not whenever it tries to connect later on
Post by SorenR » 2018-08-28 22:56
2018-08-28 22:34
insomniac2k2 wrote:
2018-08-28 18:54
I use it primarely for my IDS code to kick the server completely, otherwise it will remain connected and continue to "talk". I've seen servers open 5-6 sessions simultaneously which results in my code trying to re-ban the same server multiple times. With CPort killing all sessions with the same IP Address, that problem goes away.
Post by RvdH » 2018-08-28 23:47
In that case... 10kb :wink:
Source: stackoverflow.com
using System;
using System.Collections;
using System.Runtime.InteropServices;
namespace ConnectionManager
    class Disconnector
    public class Starter
        public static void Main(string[] args)
            if (args.Length == 0)
                Console.WriteLine("Disconnect IP1 [IP2 [IP3 [IPn]]]");
                Console.WriteLine("");
                Console.WriteLine("Connections up now:");
                string[] cons = Disconnecter.Connections(Disconnecter.State.Established);
                foreach (string s in cons)
                    Console.WriteLine(s);
            else
                foreach (string s in args)
                    Disconnecter.CloseRemoteIP(s);
#if DEBUG
            Console.ReadKey();
#endif
    public class Disconnecter
        /// <summary>
        /// Enumeration of the states
        /// </summary>
        public enum State
            /// <summary> All </summary>
            All = 0,
            /// <summary> Closed </summary>
            Closed = 1,
            /// <summary> Listen </summary>
            Listen = 2,
            /// <summary> Syn_Sent </summary>
            Syn_Sent = 3,
            /// <summary> Syn_Rcvd </summary>
            Syn_Rcvd = 4,
            /// <summary> Established </summary>
            Established = 5,
            /// <summary> Fin_Wait1 </summary>
            Fin_Wait1 = 6,
            /// <summary> Fin_Wait2 </summary>
            Fin_Wait2 = 7,
            /// <summary> Close_Wait </summary>
            Close_Wait = 8,
            /// <summary> Closing </summary>
            Closing = 9,
            /// <summary> Last_Ack </summary>
            Last_Ack = 10,
            /// <summary> Time_Wait </summary>
            Time_Wait = 11,
            /// <summary> Delete_TCB </summary>
            Delete_TCB = 12
        /// <summary>
        /// Connection info
        /// </summary>
        private struct MIB_TCPROW
            public int dwState;
            public int dwLocalAddr;
            public int dwLocalPort;
            public int dwRemoteAddr;
            public int dwRemotePort;
        //API to get list of connections
        [DllImport("iphlpapi.dll")]
        private static extern int GetTcpTable(IntPtr pTcpTable, ref int pdwSize, bool bOrder);
        //API to change status of connection
        //private static extern int SetTcpEntry(MIB_TCPROW tcprow);
        private static extern int SetTcpEntry(IntPtr pTcprow);
        //Convert 16-bit value from network to host byte order
        [DllImport("wsock32.dll")]
        private static extern int ntohs(int netshort);
        //Convert 16-bit value back again
        private static extern int htons(int netshort);
        /// <summary>
        /// Testexample
        /// </summary>
        public static void TEST()
            Console.WriteLine("Not Working Yet!!!");
            //string[] ret = Connections(State.All);
            //foreach (string con in ret) if (con.IndexOf("192.168.0.101") > -1) System.Diagnostics.Debug.WriteLine(con);
            //System.Diagnostics.Debug.WriteLine("----------------------------");
            //CloseRemotePort(1863);
            //CloseRemotePort(80);
            //ret = Connections(State.All);
        /// <summary>
        /// Close all connection to the remote IP
        /// </summary>
        /// <param name="IP">IPen på remote PC</param>
        public static void CloseRemoteIP(string IP)
            MIB_TCPROW[] rows = getTcpTable();
            for (int i = 0; i < rows.Length; i++)
                if (rows[i].dwRemoteAddr == IPStringToInt(IP))
                    rows[i].dwState = (int)State.Delete_TCB;
                    IntPtr ptr = GetPtrToNewObject(rows[i]);
                    int ret = SetTcpEntry(ptr);
#if DEBUG
            Console.WriteLine(string.Format("RemoteIP {0} Closed", IP));
#endif
        /// <summary>
        /// Close all connections at current local IP
        /// </summary>
        /// <param name="IP"></param>
        public static void CloseLocalIP(string IP)
                if (rows[i].dwLocalAddr == IPStringToInt(IP))
        /// <summary>
        /// Closes all connections to the remote port
        /// </summary>
        /// <param name="port"></param>
        public static void CloseRemotePort(int port)
                if (port == ntohs(rows[i].dwRemotePort))
        /// <summary>
        /// Closes all connections to the local port
        /// </summary>
        public static void CloseLocalPort(int port)
                if (port == ntohs(rows[i].dwLocalPort))
        /// <summary>
        /// Close a connection by returning the connectionstring
        /// </summary>
        /// <param name="connectionstring"></param>
        public static void CloseConnection(string connectionstring)
            try
                //Split the string to its subparts
                string[] parts = connectionstring.Split('-');
                if (parts.Length != 4) throw new Exception("Invalid connectionstring - use the one provided by Connections.");
                string[] loc = parts[0].Split(':');
                string[] rem = parts[1].Split(':');
                string[] locaddr = loc[0].Split('.');
                string[] remaddr = rem[0].Split('.');
                //Fill structure with data
                MIB_TCPROW row = new MIB_TCPROW();
                row.dwState = 12;
                byte[] bLocAddr = new byte[] { byte.Parse(locaddr[0]), byte.Parse(locaddr[1]), byte.Parse(locaddr[2]), byte.Parse(locaddr[3]) };
                byte[] bRemAddr = new byte[] { byte.Parse(remaddr[0]), byte.Parse(remaddr[1]), byte.Parse(remaddr[2]), byte.Parse(remaddr[3]) };
                row.dwLocalAddr = BitConverter.ToInt32(bLocAddr, 0);
                row.dwRemoteAddr = BitConverter.ToInt32(bRemAddr, 0);
                row.dwLocalPort = htons(int.Parse(loc[1]));
                row.dwRemotePort = htons(int.Parse(rem[1]));
                //Make copy of the structure into memory and use the pointer to call SetTcpEntry
                IntPtr ptr = GetPtrToNewObject(row);
                if (ret == -1) throw new Exception("Unsuccessful");
                if (ret == 65) throw new Exception("User has no sufficient privilege to execute this API successfully");
                if (ret == 87) throw new Exception("Specified port is not in state to be closed down");
                if (ret != 0) throw new Exception("Unknown error (" + ret + ")");
            catch (Exception ex)
                throw new Exception("CloseConnection failed (" + connectionstring + ")! [" + ex.GetType().ToString() + "," + ex.Message + "]");
        /// <summary>
        /// Gets all connections
        /// </summary>
        /// <returns></returns>
        public static string[] Connections()
            return Connections(State.All);
        /// <summary>
        /// Gets a connection list of connections with a defined state
        /// </summary>
        /// <param name="state"></param>
        public static string[] Connections(State state)
            ArrayList arr = new ArrayList();
            foreach (MIB_TCPROW row in rows)
                if (state == State.All || state == (State)row.dwState)
                    string localaddress = IPIntToString(row.dwLocalAddr) + ":" + ntohs(row.dwLocalPort);
                    string remoteaddress = IPIntToString(row.dwRemoteAddr) + ":" + ntohs(row.dwRemotePort);
                    arr.Add(localaddress + " - " + remoteaddress + " - " + ((State)row.dwState).ToString());
            return (string[])arr.ToArray(typeof(System.String));
        //The function that fills the MIB_TCPROW array with connectioninfos
        private static MIB_TCPROW[] getTcpTable()
            IntPtr buffer = IntPtr.Zero; bool allocated = false;
            try
                int iBytes = 0;
                GetTcpTable(IntPtr.Zero, ref iBytes, false); //Getting size of return data
                buffer = Marshal.AllocCoTaskMem(iBytes); //allocating the datasize
                allocated = true;
                GetTcpTable(buffer, ref iBytes, false); //Run it again to fill the memory with the data
                int structCount = Marshal.ReadInt32(buffer); // Get the number of structures
                IntPtr buffSubPointer = buffer; //Making a pointer that will point into the buffer
                buffSubPointer = (IntPtr)((int)buffer + 4); //Move to the first data (ignoring dwNumEntries from the original MIB_TCPTABLE struct)
                MIB_TCPROW[] tcpRows = new MIB_TCPROW[structCount]; //Declaring the array
                //Get the struct size
                MIB_TCPROW tmp = new MIB_TCPROW();
                int sizeOfTCPROW = Marshal.SizeOf(tmp);
                //Fill the array 1 by 1
                for (int i = 0; i < structCount; i++)
                    tcpRows[i] = (MIB_TCPROW)Marshal.PtrToStructure(buffSubPointer, typeof(MIB_TCPROW)); //copy struct data
                    buffSubPointer = (IntPtr)((int)buffSubPointer + sizeOfTCPROW); //move to next structdata
                return tcpRows;
                throw new Exception("getTcpTable failed! [" + ex.GetType().ToString() + "," + ex.Message + "]");
            finally
                if (allocated) Marshal.FreeCoTaskMem(buffer); //Free the allocated memory
        private static IntPtr GetPtrToNewObject(object obj)
            IntPtr ptr = Marshal.AllocCoTaskMem(Marshal.SizeOf(obj));
            Marshal.StructureToPtr(obj, ptr, false);
            return ptr;
        //Convert an IP string to the INT value
        private static int IPStringToInt(string IP)
            if (IP.IndexOf(".") < 0) throw new Exception("Invalid IP address");
            string[] addr = IP.Split('.');
            if (addr.Length != 4) throw new Exception("Invalid IP address");
            byte[] bytes = new byte[] { byte.Parse(addr[0]), byte.Parse(addr[1]), byte.Parse(addr[2]), byte.Parse(addr[3]) };
            return BitConverter.ToInt32(bytes, 0);
        //Convert an IP integer to IP string
        private static string IPIntToString(int IP)
            byte[] addr = System.BitConverter.GetBytes(IP);
            return addr[0] + "." + addr[1] + "." + addr[2] + "." + addr[3];
Post by mattg » 2018-08-29 01:06
2018-08-28 22:34
insomniac2k2 wrote:
2018-08-28 18:54
I think this happens a bit
More so recently.
In the last few weeks, I've seen a couple of times where i have 30+ active SMTP connections with no activity in my logs. Also my hMailserver often doesn't want to 'Stop', presumably due to open connections
insomniac2k2
Post by insomniac2k2 » 2018-08-29 04:16
More like hundreds. And while I understand that this should not be a problem with locking hmailserver threads, it seems to be very common in my installation. I know that as soon as i see a bunch of banned IPs that match up to what is presently connected to my server, i can count oh Hmailserver slowly trickling emails until I either restart the service or forcefully disconnecting those SMTP sessions. It almost seems like a bug of sorts, but i cannot put a finger on it. I can drastically accelerate and expose this issue by introducing a delay in the OnClientConnect sub.
My best guess is that I am running up against the Max number of commands or Asynchronous tasks threads limits. I've lightly tested this by increasing my max on all 3 thread limits, and I believe that I have seen the issue follow the relative amount that I adjusted by.
2018-08-28 22:42
insomniac2k2
Post by insomniac2k2 » 2018-08-29 04:18
Thanks for being my google :)
I did actually get cports to work by applying SorenR's suggestion, but I do like this and will give it a try a bit later next week.
2018-08-28 23:47
using System;
    class Disconnector
            else
#if DEBUG
            Console.ReadKey();
#endif
        /// <summary>
        /// </summary>
        public enum State
            All = 0,
            Closed = 1,
            Listen = 2,
            Syn_Sent = 3,
            Syn_Rcvd = 4,
            Established = 5,
            Fin_Wait1 = 6,
            Fin_Wait2 = 7,
            Close_Wait = 8,
            Closing = 9,
            Last_Ack = 10,
            Time_Wait = 11,
            Delete_TCB = 12
        /// <summary>
        /// Connection info
        /// </summary>
            public int dwState;
        /// <summary>
        /// Testexample
        /// </summary>
        /// <summary>
        /// </summary>
#if DEBUG
#endif
        /// <summary>
        /// </summary>
        /// <summary>
        /// </summary>
        /// <summary>
        /// </summary>
        /// <summary>
        /// </summary>
            try
                row.dwState = 12;
        /// <summary>
        /// </summary>
        /// <summary>
        /// </summary>
            try
                int iBytes = 0;
                allocated = true;
                return tcpRows;
            finally
            return ptr;
insomniac2k2
Post by insomniac2k2 » 2018-08-29 04:33
I have this problem across 4 independent installations. Definitely more often now than before.
2018-08-29 01:06
2018-08-28 22:34
insomniac2k2 wrote:
2018-08-28 18:54
More so recently.
Post by SorenR » 2018-08-29 10:51
Well, I'm going to look at this: http://wkillcx.sourceforge.net/
Programmed in assembler, the language I started with before Anders Hejlsberg launched PolyPascal and TurboPascal 8)
Programming in assembler is a lost art. Later in life I got to work with terminal emulators (DCA IRMA 3270) and the initial versions were programmed in assembler (MS-DOS) ... 47 kb executeable to replace a IBM 3278 terminal complete with filetransfer and all. Then someone brilliantly suggested switching to C++ to enable native Windows 3.x mode ... The installation disc went from a 1.44 MB floppy to a fully packed CD :roll:
insomniac2k2
Post by insomniac2k2 » 2018-08-29 14:05
Just an update of testing this script with autoban and cports. I am seeing a drastic reduction of spam that is hitting my users junk email folder. I originally started using this at 40%. I have since adjusted it to 25%. I'm now considering around 15%. Before I do so, I'll do another spot check on anything near 15% to see if anything comes back legitimate.
On another note, I'm also testing SorenR's snowshoe verification. All I can say is wow. Snowshoe spammers had my companies on their VIP list or something. Near 8 thousand IP's banned in 2 days.
So now I guess we see exactly how large a ban list can get before hmail implodes....
antons
Post by antons » 2018-10-23 10:48
Hello!
Which of these scripts will be worked on server2003R2?
Post by jimimaseye » 2018-10-23 12:32
The vbs should be independent of the os.
antons
Post by antons » 2018-10-24 13:17
I got the following error:
"ERROR" 2616 "2018-10-24 14:15:40.312" "Script Error: Source: msxml6.dll - Error: 800C0008 - Description: System error: -2146697208.[nl] - Line: 59 Column: 2 - Code: (null)"
Server 2003R2, Hmailserver 5.6.4
when use script from Po-In, posted 2018-05-24 13:46
nitro
Post by nitro » 2018-11-08 16:43
I thought it would be more efficient for the script to add the ip to a firewall rule in windows, thus preventing the same ip from reaching the mail server. It is necessary to optimize the code and control the limit of ip's as a rule.
.......	Percentage = "0" 'Default value
	Dim objShell
	Dim objExec
	Dim strPSResults
	Dim stAllIpBaned
		Percentage= CheckAbuseIPDBConfidence(ClientIP)
			Result.Value = 1
			EventLog.Write ("AbuseIPDB: IP Address " & ClientIp & " rechazado: % en AbuseIPDB: " & Percentage & "%.")
			' Add to firewall rule
				' Create shell object
				Set objShell = CreateObject("Wscript.Shell")
				' Execute the combined command
				Set objExec = objShell.Exec("powershell -windowstyle hidden -command (Get-NetFirewallRule -DisplayName Ban_IP | Get-NetFirewallAddressFilter ).RemoteAddress")
				' Read output into VBS variable
				strPSResults = objExec.StdOut.ReadAll
				stAllIpBaned = ClientIP
				' Replace in output powershell
	 			strPSResults = Replace(strPSResults, chr(13), ",",1,1000) ' Max RemoteAddress in W2016 srv
				strPSResults = Replace(strPSResults, chr(10), "",1,1000)
				' Add detected ip to output powershell
				stAllIpBaned = strPSResults + stAllIpBaned
				' Send old ip's and new ip to Firewall Rule
				Set objExec = objShell.Exec("powershell -windowstyle hidden -command Set-NetFirewallRule -DisplayName Ban_IP -RemoteAddress"&" "&stAllIpBaned)
				Set objShell = Nothing
			Result.Value = 0..............
Production 5.6.8-B2437.20_OpenSSL_1.0.2s W.Server 2016 Datace [2x Intel Xeon E5-2660 8GB RAM]
nitro
Post by nitro » 2018-11-12 13:38
I paste here the modified @ Po-In code so that it automatically inserts the ip addresses detected in a ban rule ip. I believe that in this way the load of Hmailserver will be reduced by not having to make new queries of the same ip in AbuseIPDB. Use Windows Server 2016, where supposedly it is allowed to add up to 10,000 ip's on the same rule, since I use Hmailserver in an environment with few email accounts I think that, for me, it is enough with an email notification when the rule is being filled.
I have been using Hmailserver since 2012 when, due to circumstances of life and crisis, I was assigned the task of installing and maintaining a mail server. From here I want to thank the creator and the whole community for having facilitated my task. Thank you.
	WhiteList = "#127.0.0.1#1.2.3.4" 'Variable array for whitelisted IP addresses to exclude, localhost, maybe your servers IP address, your WebClient IP address whatever
	Dim objShell
	Dim objExec
	Dim strPSResults
	Dim ip
			Result.Value = 1
				ip = ClientIP
				strPSResults = Replace(strPSResults, chr(13), ",",1,10000)
				strPSResults = Replace(strPSResults, chr(10), "",1,10000)
				if len(strPSResults) - len(replace(strPSResults, ",", "")) > 9000  then ' Alert max 10.000 ips per rule
					EventLog.Write ("**** ATTENTION RULE BAN_IP 90%  ****")  ' Write in log file
					' Send email Alert max 10.000 ips per rule
						dim MessageRecipientName, MessageRecipientAddress, MessageSubject
						dim oApp, sBackupLog, oMessage
						MessageRecipientName = "MAIL SERVER"  'CHANGE ME
						MessageRecipientAddress = "recipient@address.com"  'CHANGE ME
						MessageSubject = "ATTENTION RULE BAN_IP 90%"
						Call oApp.Authenticate("useradmin", "password")
						oMessage.From = "hMailServer" & "<recipient@address.com>"
						oMessage.FromAddress = "from@addresses.com"
						oMessage.Body = "ATTENTION RULE BAN_IP 90%." & vbNewLine & vbNewLine & sBackupLog
					' End Send email Alert max 10.000 ips per rule
				END If
				ip = strPSResults + ip
					Set objExec = objShell.Exec("powershell -windowstyle hidden -command Set-NetFirewallRule -DisplayName Ban_IP -RemoteAddress"&" "&ip)
			' End Add to firewall
			ElseIf
			Result.Value = 0
		objXMLHTTP.Send ""
				Exit For
df5zx
Post by df5zx » 2018-11-24 16:31
Hello everybody,
I wanted to try that as well, but I do get the same error like Antons:
What could it be ???
tnx for help,
Jürgen
insomniac2k2
Post by insomniac2k2 » 2018-12-05 20:28
Thanks for your contribution Nitro. I've done Windows firewall bans from script before, but im giving this a try again. I really like the prospect to reducing bans on Hmail and putting the load on Windows better.
In my case, I have near 80,000 bans in Hmail. I've kind of been watching it like a science experiment. It's pretty nasty to parse the IP Range list when you want to take a look in the UI. This type of ban mitigates that issue.
nitro wrote:
2018-11-12 13:38
	Dim objShell
	Dim objExec
	Dim strPSResults
	Dim ip
			Result.Value = 1
				ip = ClientIP
				END If
			ElseIf
			Result.Value = 0
		objXMLHTTP.Send ""
				Exit For
insomniac2k2
Post by insomniac2k2 » 2018-12-10 04:52
I figured I should post a little logic that I added for the ban rule. I'm running windows 2012R2 presently, and it seems like the ban list is limited to 1000 entries. On a busy day, I can fill 1. In order to mitigate this and also mitigate running out of ban space, use the scripting below to copy your existing ban list, rename it, and clean your active list. Thus making room for 999 (in my case 989) fresh new scumbag ip addresses. I implemented this yesterday, and I'm already on my 2nd rule. If you care about possible overlap of rules, just add something like Time to the curDate variable. Works great!
Add all code below "If len"
	Dim curDate
	curDate =  "_" & Month(Date) & "_" & Day(Date) & "_" & Year(Date)
	Set objExec = objShell.Exec("powershell -windowstyle hidden -command copy-netfirewallrule -name Hmailblock -newname"&" Hmailblock"&curDate)
	Wait(1)
	Set objExec = objShell.Exec("powershell -windowstyle hidden -command get-netfirewallrule -name"&" Hmailblock"&curDate& " | set-netfirewallrule -newdisplayname Hmailblock"&curDate)
	Wait(1)
	Set objExec = objShell.Exec("powershell -windowstyle hidden -command set-netfirewallrule -displayname Hmailblock -RemoteAddress 55.55.55.55")	'this can be any IP really. It just clears the list. Yeah I know its lazy...
	EventLog.Write ("**** ATTENTION RULE BAN_IP 99%, Creating new firewall rule ****")  ' Write in log file
You need the "Wait" Function to make this logic work:
Function Wait(sec)
Post by SorenR » 2018-12-10 15:31
There is a way to control your Firewall witn VBScript (Windows 7 and up) using the COM API of Windows Firewall with Advanced Security (WFAS).
My systems are pre-Windows 7 :oops: Eventually I will update them but I found that the only object NOT supported by my server is ** CreateObject("HNetCfg.FwPolicy2") ** :roll:
Sample code...
http://www.ohmancorp.com/files/RefWin-A ... WRules.txt
https://docs.microsoft.com/da-dk/previo ... -exception
And... I came across this one...
' http://psscripts.blogspot.com/2012/12/automatically-block-rdp-attacks-on-your.html
' fail2ban.vbs:
If wscript.arguments.count = 2 then
    Dim firewall, rule, rulename, ip, re, account
    'Change this value! This rule must already exist in your inbound firewall rules
    rulename = "Fail2Ban"
    account = wscript.arguments.item(0)
    ip = wscript.arguments.item(1)
    'MsgBox "Debug message: Invalid login with account " & account & " from IP " & ip
    Set re = new regexp
    re.Pattern = "\b(([01]?\d?\d|2[0-4]\d|25[0-5])\.){3}([01]?\d?\d|2[0-4]\d|25[0-5])\b"
    If re.Test(ip) And Not IsException(account, ip) Then
        Set firewall  = CreateObject("HNetCfg.FwPolicy2")
        Set rule = firewall.Rules.Item(rulename)
        If Not (rule Is Nothing) Then
            If InStr(1,rule.RemoteAddresses,ip,1) = 0 Then
                rule.RemoteAddresses = rule.RemoteAddresses & "," & ip
        Set firewall = Nothing
        'Invalid IP or excemption from rule
end If
'Handle exception cases here, you don't want to ban your own IP, for instance...Customize to your needs
Function IsException(account, ip)
  Dim exip
  exip = "My.IP"
  IsException = False
  If ip = exip Then
    IsException = True
insomniac2k2
Post by insomniac2k2 » 2018-12-10 22:29
Go 2019. :) 1000 bans per list!
I say that, because for me it's really easy. I use hmailserver as a hardened relay. I'd hate to have to migrate to a more updated server..
2018-12-10 15:31
Sample code...
' fail2ban.vbs:
    Set re = new regexp
end If
  Dim exip
  exip = "My.IP"
  IsException = False
  If ip = exip Then
    IsException = True
nitro
Post by nitro » 2018-12-13 17:19
insomniac2k2 wrote:
2018-12-10 04:52
	Dim curDate
	Wait(1)
	Wait(1)
Function Wait(sec)
I will use your solution, unfortunately the maximum size that can be passed in a parameter is limited to 32700 characters. 15 characters per ip 2180 ip.
From that size we will get a nice error in our log:
Script Error: Source: WshShell.Exec - Error: 800700CE - Description: The filename or extension is too long.
insomniac2k2
Post by insomniac2k2 » 2018-12-16 17:08
While the rolling ban rule logic that I posted above works fine, I have really busy servers. I've found that I can have up to 10 redundant attempts to create a new rule at a time. Fortunately only one can be created by using my logic, but it causes a bit of hammering. I decided to break out the firewall rule count check into a separate script and call it from task scheduler every 5 minutes. This keep all verification logic off the event handler and lets it do what it does best.
Here is the code that I call from task scheduler if anyone is interested:
MakeFirewallrule.vbs -
Dim datevalue, dtsnow, dtsvalue, timevalue, curDate
Dim dd, mm, yy, hh, nn, ss
'Individual date components
dtsnow = Now()
dd = Right("00" & Day(dtsnow), 2)
mm = Right("00" & Month(dtsnow), 2)
yy = Year(dtsnow)
hh = Right("00" & Hour(dtsnow), 2)
nn = Right("00" & Minute(dtsnow), 2)
ss = Right("00" & Second(dtsnow), 2)
timevalue = hh & "-" & nn & "-" & ss
datevalue = yy & "-" & mm & "-" & dd
curDate =  "_" & Month(Date) & "_" & Day(Date) & "_" & Year(Date) & "_" & timevalue
'verify how many IP's are in firewall rule and create rule if needed
		Set objExec = objShell.Exec("powershell -windowstyle hidden -command (Get-NetFirewallRule -DisplayName Hmailblock | Get-NetFirewallAddressFilter ).RemoteAddress")
	if len(strPSResults) - len(replace(strPSResults, ",", "")) > 995  then ' Alert max 1000 ips per rule
		Wait(2)
		Wait(2)
	END If
Function Wait(sec)
I call this vbs from this batch file. You can do it whatever way works in windows for you:
makenewfirewallrulewhenfull.cmd -
@echo off
pushd "C:\Program Files (x86)\hMailServer\Events"
cscript makenewfirewallrule.vbs
exit
The rolling firewall rules end up looking like the attached image. I strip out the redundant 55.55.55.55 ip's every once in a while. Some day when i care, I will strip it out with code.
Post by SorenR » 2018-12-16 19:05
I built a simple IDS / PortMonitor using tables in the database. It was either DB access or reading and writing files as I needed to pass data across multiple hMailServer triggers. File handling and session locking sucks :mrgreen: so I turned to SQLLite at first and later to MySQL as this is used by my server.
IDS: External connection from server that never progresses to actually sending mail will become autobanned after 3 "hits".
Functionality:
OnClientConnect will check IP Address in DB, if exist AND above limit -> Autoban.
IF exist AND below limit -> increment counter.
IF connection results in sending an email, the IP Address is removed from DB immediately.
PortMon: ANY connection attempt from "illegal" countries are logged, after 5 attempts they are autobanned.
Both tables are monitored by a script via Scheduler in order to remove old entries and prevent tables from growing uncontrolled.
Maybe you can use this as inspiration on how to offload some of the work from hMailServer.
I envision that any IP Address destined for the Firewall is simply added to the table and the connection is disconnected with a "Result.Value=1". Any further processing is then handled by an external process reading the DB tables and updating the Firewall apropriately. Benefit is that multiple mailservers can deliver "bad" IP Addresses into the queue and update a dedicated Firewall.
'********** hMailServer IDS Code (MySQL)        **********
Private Const idsDBDrv = "DRIVER={MySQL ODBC 5.3 Unicode Driver};Database=#DB#;Uid=#UID#;Pwd=#PWD#;Option=3;"
Private Const idsTab01 = "hm_ids"
Private Const idsHit01 = 3
Private Const idsMins  = 120
Private Const idsTab02 = "hm_portmon"
Private Const idsHit02 = 5
'   DRIVER={MySQL ODBC 5.3 Unicode Driver};Server=localhost;Port=3306;Database=#DB#;Uid=#UID#;Pwd=#PWD#;Option=3;
'   Table:   CREATE TABLE %ids% (
'                   id        INTEGER       PRIMARY KEY AUTO_INCREMENT,
'                   timestamp DATETIME,
'                   ipaddress VARCHAR (192) UNIQUE,
'                   hits      INTEGER);"
'   Table:   CREATE TABLE %portmon% (
'                   port      INTEGER,
'                   hits      INTEGER);"
'* Function idsDBMaint()
'*    Dim oConn : Set oConn = CreateObject("ADODB.Connection")
'*    oConn.Open idsDBDrv
'*    If oConn.State <> 1 Then
'*       EventLog.Write( "idsDBMaint - ERROR: Could not connect" )
'*       Exit Function
'*    End If
'*    oConn.Execute "DELETE FROM " & idsTab01 & " WHERE DATE_ADD(timestamp, INTERVAL 12 HOUR) < NOW();"
'*    oConn.Execute "DELETE FROM " & idsTab02 & " WHERE DATE_ADD(timestamp, INTERVAL 24 HOUR) < NOW();"
'*    oConn.Close
'* End Function
Function idsDelete(sIPAddress)
   oConn.Open idsDBDrv
      EventLog.Write( "idsDelete - ERROR: Could not connect" )
      Exit Function
   oConn.Execute "DELETE FROM " & idsTab01 & " WHERE ipaddress = '" & sIPAddress & "';"
   oConn.Close
Function idsCheck(sIPAddress) : idsCheck = False
   oConn.Open idsDBDrv
      EventLog.Write( "idsCheck - ERROR: Could not connect" )
      Exit Function
   Set oRecord = oConn.Execute("SELECT * FROM " & idsTab01 & " WHERE ipaddress='" & sIPAddress & "';")
   On Error Goto 0
   If Err.Number <> 0 Then
      EventLog.Write( "idsCheck - ERROR: Table " & idsTab01 & " does not exist!" )
      Exit Function
   If oRecord.BOF And oRecord.EOF Then '   IPAddress is NEW!
      oConn.Execute "INSERT IGNORE INTO " & idsTab01 & " (timestamp,ipaddress,hits) VALUES (NOW(),'" & sIPAddress & "',0);"
      oConn.Execute "UPDATE " & idsTab01 & " SET hits=(hits+1),timestamp=NOW() WHERE IPAddress='" & sIPAddress & "';"
   Else '   In case of more than one record, unlikely since "ipaddress" have a UNIQUE constraint.
      While Not oRecord.EOF
         idsCheck = (oRecord("hits") >= idsHit01)
         If (DateDiff("n", oRecord("timestamp"), Now()) > idsMins) Then '   IPAddress is known - but too old.
            oConn.Execute "UPDATE " & idsTab01 & " SET hits=1,timestamp=NOW() WHERE IPAddress='" & sIPAddress & "';"
         Else '   IPAddress is known - bump counter.
         oRecord.MoveNext
      Wend
   oRecord.Close
   oConn.Close
Function idsPortMon(sIPAddress, iPort) : idsPortMon = False
   oConn.Open idsDBDrv
      EventLog.Write( "idsPortMon - ERROR: Could not connect" )
      Exit Function
   Set oRecord = oConn.Execute("SELECT * FROM " & idsTab02 & " WHERE ipaddress='" & sIPAddress & "';")
   On Error Goto 0
      EventLog.Write( "idsPortMon - ERROR: Table " & idsTab02 & " does not exist!" )
      Exit Function
      oConn.Execute "INSERT IGNORE INTO " & idsTab02 & " (timestamp,ipaddress,port,hits) VALUES (NOW(),'" & sIPAddress & "'," & iPort & ",0);"
      oConn.Execute "UPDATE " & idsTab02 & " SET hits=(hits+1),timestamp=NOW() WHERE IPAddress='" & sIPAddress & "';"
         idsPortMon = (oRecord("hits") >= idsHit02)
         oRecord.MoveNext
      Wend
   oRecord.Close
   oConn.Close
'   System Scripting Runtime COM object ("SScripting.IPNetwork")
'   http://www.netal.com/ssr.htm
'   Binary -> http://www.netal.com/software/ssr15.zip
'   http://countries.nerd.dk/isolist.txt
Function NerdLookup(strIP)
   Dim a
   a = Split(strIP, ".")
      strIP = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".zz.countries.nerd.dk")
   If Left(strIP, 3) <> "127" Then
      NerdLookup = "000"
      NerdLookup = Right("00" & CStr(a(2)*256 + a(3)), 3)
   Dim strPort
   '   Only allow non-SMTP connect from "Rigsfællesskabet"/"Naalagaaffeqatigiit"/"Ríkisfelagsskapurin" = The Danish Realm.
   '   000 = N/A, 208 = Denmark, 304 = Greenland, 234 = Faroe Islands
   If (oClient.Port <> 25) Then
      If InStr("|208|304|234|", NerdLookup(oClient.IPAddress)) = 0 Then
         If idsPortMon(oClient.IPAddress, oClient.Port) Then
            Result.Value = 1
            strPort = Trim(Mid("SMTP IMAP SMTPSSUBM IMAPS", InStr("25   143  465  587  993  ", oClient.Port), 5))
            If AutoBan(oClient.IPAddress, "PORTBLOCK - " & strPort, 1, "d") Then _
               EventLog.Write( "AutoBan(" & oClient.IPAddress & ", PORTBLOCK - " & strPort & ", 1, d)" )
            Exit Sub
            Result.Value = 1
            Exit Sub
   '   Only test SMTP traffic
   If InStr("|25|587|465|", oClient.Port) > 0 Then
      If idsCheck(oClient.IPAddress) Then
         Result.Value = 1
         If AutoBan(oClient.IPAddress, "IDS", 7, "d") Then _
            EventLog.Write( "AutoBan(" & oClient.IPAddress & ", IDS, 7, d)" )
         Exit Sub
   '   Cleanup IDS registry
   idsDelete(oClient.IPAddress)
Post by SorenR » 2018-12-16 19:49
Just a note...
hMailServer API have an object (Database) used to WRITE to the system database using ExecuteSQL, ExecuteSQLScript or ExecuteSQLWithReturn.
Unfortunately there is NO way to READ from the database using the API. BUT... If all you need to do is to dump IP Addresses to an external script, that is one way to do it.
Could be like this... :mrgreen:
If isBAD(oClient.IPAddress) Then
   DumpToDB(oClient.IPAddress)
   Result.Value = 1
   Exit Sub
insomniac2k2
Post by insomniac2k2 » 2018-12-17 01:55
Thanks for sharing this code. Some day in the future I plan on doing quite a bit with some custom whitelisting, as well as doing stuff quite similar to what you are doing with this IDS code.
I love the thought of a central database database, as I run about 10 hmail based servers as hardened relays. At the moment, these servers slowly build their own lists. One list to rule them all have obvious benefits!
Post by SorenR » 2018-12-17 02:08
"One list to rule them all, One list to find them, One list to bring them all and in the darkness bind them." :mrgreen:
nitro
Post by nitro » 2018-12-19 11:54
2018-12-16 19:05
No MSSQL, no party....
2018-12-17 02:08
Three List's for the big bosses under the sky,
Seven for the Dwarf-users in their halls of stone,
Nine for VIP Men doomed to die,
One for the Admin Lord on his dark throne
In the Land of Hmailserver where the Shadows lie.
Merry Christmas. :D
nitro
Post by nitro » 2018-12-20 13:49
After a while using the code I have been able to observe that for my server it is enough to have a firewall rule for each month. Something as simple as concatenating the month and the year after the name of the rule allows me to have created 12 rules for the next year and only review them if at any time it exceeds 2000 ip's.
	Dim objShell
	Dim objExec
	Dim strPSResults
	Dim ip
		Percentage= CheckAbuseIPDBConfidence(ClientIP) 'Check % in AbuseIPDB
			Result.Value = 1
			Set objExec = objShell.Exec("powershell -windowstyle hidden -command (Get-NetFirewallRule -DisplayName Ban_IP" & Month(Date()) & Year(Date()) &" | Get-NetFirewallAddressFilter ).RemoteAddress")
			ip = ClientIP
			If len(strPSResults) - len(replace(strPSResults, ",", "")) > 2000  then  ' Alert max 2.000 ips per rule
				EmailAlert() 													     ' Send email Alert max 2.000 ips per rule
			Set objExec = objShell.Exec("powershell -windowstyle hidden -command Set-NetFirewallRule -DisplayName Ban_IP" & Month(Date()) & Year(Date()) & " -RemoteAddress"&" "&ip)
			Set objExec = Nothing
			Result.Value = 0
Public Function EmailAlert() ' Send email Alert
		MessageSubject = "ATTENTION RULE BAN_IP 90%" & Month(Date()) & Year(Date())& "."
		oMessage.Body = "ATTENTION RULE BAN_IP 90% ." & vbNewLine & vbNewLine & sBackupLog
	Set oApp = Nothing
Public Function CheckAbuseIPDBConfidence(IPAddress) 'Check % ip in AbuseIPDB
		objXMLHTTP.Send ""
				Exit For
Post by SorenR » 2018-12-20 15:41
With respect to the IDS code I posted earlier. I have reduced the script footprint in hMailserver from previously quoted 241 lines of active code to 55 lines of code. Plus it's no longer using the AODB.Connection and all the extra API calls - so all in all it should speed things up with a factor 500 (or something to that effect :wink: ).
I use AutoBan in my script but it could just as well be code to add IP Addresses to a firewall.
The "handler" part is not yet finished, but from hMailServers perspective - the "handler" is irellevant wrt. performance as it is running outside hMailServer.
As long as the "handler" code can access the database (socket or IP), it can be written in whatever programming language you prefer. :idea: :wink:
Actually, if you use IPTables on a 'Nix Box, you can run the "handler" directly on the 'Nix Box and access the database across the LAN. 8)
*** NEW ***
'********** hMailServer IDS Client Code (MySQL)        **********
Private Const idsTable = "hm_ids2"
'   DRIVER={MySQL ODBC 5.3 Unicode Driver};Server=localhost;Port=3306;Database=%idsdb%;Uid=%idsuid%;Pwd=%idspwd%;Option=3;
'   Table:   CREATE TABLE %idsTable% (
'                   port      INTEGER,
'                   hits      INTEGER);
Function idsAddIP(sIPAddress, iPort)
   strSQL = "INSERT IGNORE INTO " & idsTable & " (timestamp,ipaddress,port,hits) VALUES (NOW(),'" & sIPAddress & "'," & iPort & ",0);"
   Call oDB.ExecuteSQL(strSQL)
   strSQL = "UPDATE " & idsTable & " SET hits=(hits+1),timestamp=NOW() WHERE IPAddress='" & sIPAddress & "';"
Function idsDelIP(sIPAddress)
   strSQL = "DELETE FROM " & idsTable & " WHERE ipaddress = '" & sIPAddress & "';"
   Dim strPort
         Call idsAddIP(oClient.IPAddress, oClient.Port)
         Result.Value = 1
         Exit Sub
      Call idsAddIP(oClient.IPAddress, 0)
      Call idsDelIP(oClient.IPAddress)
*** OLD ***
'                   hits      INTEGER);"
'                   port      INTEGER,
'                   hits      INTEGER);"
   oConn.Open idsDBDrv
      Exit Function
   oConn.Close
   oConn.Open idsDBDrv
      Exit Function
   On Error Goto 0
      Exit Function
         oRecord.MoveNext
      Wend
   oRecord.Close
   oConn.Close
   oConn.Open idsDBDrv
      Exit Function
   On Error Goto 0
      Exit Function
         oRecord.MoveNext
      Wend
   oRecord.Close
   oConn.Close
Function Wait(sec)
Function LockFile(strPath)
   Const Append = 8
   Const Unicode = -1
      Dim oFile, i
      For i = 0 To 30
         If Not (Err.Number = 70) Then
            Set LockFile = oFile
            On Error Goto 0
            Exit For
         On Error Goto 0
         Wait(1)
   If (Err.Number = 70) Then
      Err.Clear
   ElseIf (Err.Number <> 0) Then
      Err.Clear
   Dim a
      NerdLookup = "000"
            .Priority = 20
            .Expires = True
            .Save
         AutoBan = True
      On Error Goto 0
      .Close
   Dim strPort
            Result.Value = 1
            Exit Sub
            Result.Value = 1
            Exit Sub
         Result.Value = 1
         Exit Sub
Post by SorenR » 2018-12-20 18:42
My "handler" ... It's running alpha test right now. Nothing has blown up yet, so we'll see ... :mrgreen:
handler.vbs runs every 5 minutes.
You can regard this whole excercise a Proof of Concept on how to offload tasks from hMailServer execution.
Option Explicit
'   COM authentication
Private Const PASSWORD = "SECRETPASSWORDDONOTFORGETTOCHANGE"
'********** hMailServer IDS Handler Code (MySQL)        **********
'                   port      INTEGER,
'                   hits      INTEGER);
Function Wait(sec)
   Const Append = 8
   Const Unicode = -1
      Dim oFile, i
      For i = 0 To 30
            On Error Goto 0
            Exit For
         On Error Goto 0
         Wait(1)
      EventLog.Write( "ERROR: BanJob.vbs" )
      Err.Clear
      EventLog.Write( "ERROR: BanJob.vbs : Function LockFile" )
      Err.Clear
'*    Dim oApp : Set oApp = CreateObject("hMailServer.Application")
'*    Call oApp.Authenticate(ADMIN, PASSWORD)
            .Priority = 20
            .Expires = True
            .Save
         AutoBan = True
      On Error Goto 0
      .Close
'********** Code        **********
Dim strPort, Done
oConn.Open idsDBDrv
   EventLog.Write( "Handler - ERROR: Could not connect to database" )
   Quit 1
Done = False
Do Until Done
   ' On Error Resume Next
   Set oRecord = oConn.Execute("SELECT * FROM " & idsTable & " WHERE PORT = 0 AND HITS >= '" & idsHit01 & "';")
   ' On Error Goto 0
      EventLog.Write( "Handler - ERROR: Table " & idsTable & " does not exist!" )
      WScript.Quit 1
      Exit Do
            oConn.Execute "DELETE FROM " & idsTable & " WHERE IPAddress='" & oRecord("ipaddress") & "';"
            If AutoBan(oRecord("ipaddress"), "IDS", 7, "d") Then
               EventLog.Write( "AutoBan(" & oRecord("ipaddress") & ", IDS, 7, d)" )
         oRecord.MoveNext
      Wend
   Done = True
Loop
Done = False
Do Until Done
   Set oRecord = oConn.Execute("SELECT * FROM " & idsTable & " WHERE PORT > 0 AND HITS >= '" & idsHit02 & "';")
   ' On Error Goto 0
      WScript.Quit 1
      Exit Do
            strPort = Trim(Mid("SMTP IMAP SMTPSSUBM IMAPS", InStr("25   143  465  587  993  ", oRecord("port")), 5))
            If AutoBan(oRecord("ipaddress"), "PORTBLOCK - " & strPort, 1, "d") Then
               EventLog.Write( "AutoBan(" & oRecord("ipaddress") & ", PORTBLOCK - " & strPort & ", 1, d)" )
         oRecord.MoveNext
      Wend
   Done = True
Loop
WScript.Quit 0
tunis
Post by tunis » 2018-12-21 15:18
Should not the database record always be removed if it's banned or old.
         If Not (DateDiff("n", oRecord("timestamp"), Now()) > idsMins) Then
         oRecord.MoveNext
      Wend
or
         oRecord.MoveNext
      Wend
HMS 5.6.8 B2437.17 on Windows Server 2019 Core VM.
HMS 5.6.8 B2451.21 on Windows Server 2016 Core VM.
Post by SorenR » 2018-12-21 17:37
Good point - I actually did that - after updating the forum :roll:
Anyways, a while back I changed the AutoBan() function so it's not really a problem - it will catch it and ignore it.
         ' EventLog.Write( "Wohoo... IPAddress: " & oRecord("ipaddress") & " Port: " & oRecord("port") & " Hits: " & oRecord("hits") )
         If (DateDiff("n", oRecord("timestamp"), Now()) <= idsMins) Then
         oRecord.MoveNext
      Wend
I have a (another) job that runs every 30 minutes where this is included;
oConn.Execute "DELETE FROM " & idsTable & " WHERE PORT = 0 AND DATE_ADD(timestamp, INTERVAL 12 HOUR) < NOW();"
oConn.Execute "DELETE FROM " & idsTable & " WHERE PORT > 0 AND DATE_ADD(timestamp, INTERVAL 24 HOUR) < NOW();"
tunis wrote:
2018-12-21 15:18
