Block attachments in .zip files
mikedibella
Post by mikedibella » 2016-12-14 23:36
I wanted a way to extend blocking of attachments to include attachments with restricted extensions in .zip files.
ZipScanner.exe is a simple command line scanner that does that.
It uses the hMailServer COM API to read the list of restricted extensions, and blocks a message if a .zip file is attached containing a file with a restricted extension.
To use it, copy ZipScanner.exe into the hMailServer bin directory and set the following on the "External virus scanner" tab:
Use external scanner: checked.
Scanner executable: <path to ZipScanner.exe>\ZipScanner.exe "%FILE%" "api-username" "api-password"
Return value: 1
"api-username" is the admin account or another account with Server level permission.
ZipScanner.exe will log results to the Application log. To get clean event messages, merge ZipScanner.reg into the registry and change the following keys under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\Application\ZipScanner
EventMessageFile: modify the default value, if necessary, to be <path to ZipScanner.exe>\ZipScanner.exe.
LoggingLevel: set to 0 for errors only; 1 for summary logging of blocked messages; 2 for verbose logging of all processed messages.
ZipScanner is written in Borland Delphi as a console application and uses libraries from the The Indy Project for message processing. It does not scan recursively, so zips within zips will not be checked.
Pascal source code is included, but The Indy Project libraries are required to compile. A source and compiled file for the event log resource file is included, and a compiled resource file for the executable which can be read and modified directly by Delphi.
ZipScanner.zip
(241.01 KiB) Downloaded 168 times
Re: Block attachments in .zip files
Post by jimimaseye » 2016-12-14 23:59
An alternative method is also available here: viewtopic.php?t=30002
Another alternative is to use Clamwin/ClamAV (viewtopic.php?f=21&t=26829) with Sanesecurity definitions (http://sanesecurity.com/) which has this feature builtin using their foxhole rules (http://sanesecurity.com/foxhole-databases/).
Post by RvdH » 2019-07-10 14:40
I had some spare time last weekend, so i tried to re-create mikedibella's project in C#
It uses MimeKit and also supports attachments in TNEF formated mails (winmail.dat)
ZipScanner Options:
  -u, --username=VALUE       specify your hMailserver username.
  -p, --password=VALUE       specify your hMailserver password.
  -f, --file=VALUE           specify path to *.eml.
  -b, --blockcorrupted       block corrupted zip archives
  -z, --zip                  disallow zip archives within zip archives
  -v, --verbose              increase debug message verbosity
  -h, --help                 show this message and exit
By using optional -z parameter you can add .zip to the list of restricted extensions, thus: disallow zip archives within zip archives
Optional -b parameter checks the Zip archive file signature, if this option is enabled it return 2 instead of 1 when a corrupted archive is found
Scanner executable: <path to ZipScanner.exe>\ZipScanner.exe -u="username" -p="password" -f="%FILE%"
Return value: 2
(source included)
Post by SorenR » 2019-07-10 22:23
Did you have a look at this?
https://www.hmailserver.com/forum/viewt ... p?p=213170
Seems that hMailServer attachment handling is not the best... I'm experiencing lost and hidden attachments :roll:
I got the results with my modified 5.4.2 ... Currently building a new 64 bit server to play with. I'd love to use your build but I have some minor modifications and the latest you have on Github is .17 ... :mrgreen:
I think part of the attachment (Mime) handling is done by the Boost library functions and I know that has been updated since 5.4.2.
Post by RvdH » 2019-07-10 23:00
No sorry, hadn't had a look at that (yet)
But i found out, this approach has it issues as well, for example with winmail.dat (TNEF) messages
Above doesn't use any of the hMailServer internal MIME handing, it simply takes the *.eml and MimeKit library takes care of the rest, MessagePart, MimePart and Attachment parsing, TNEF parsing etc.
Really loved working with MimeKit, that is one powerful library if you ask me!
Post by SorenR » 2019-07-11 00:12
2019-07-10 23:00
I read this, it's somewhat similar to what you are doing - editing the .eml file outside hMailServer.
https://www.hmailserver.com/forum/viewt ... 96#p185491
and thought I'd have a go at it...
How difficult could it be to rename a "filename" in a text file :roll: I'll just run it through RegEx :lol:
Sub WarningAttachments(oMessage)
    Dim oFSO, i, strWarning, strRegEx, strFile, strNewFile, bSave, bAddWarning, MailFile
    bSave = False
    '   Disclaimer
    bAddWarning = True
'   strWarning = "C:\Program Files (x86)\hMailServer\Addons\Utilities\Attachement_Warning_Readme.txt"
    strWarning = "C:\\hMailServer\Addons\Utilities\Attachement_Warning_Readme.txt"
    '   Set the extensions you want to rename, each must be in the format (\.htm.?)$ and separated with a |
    '   Eg: .Pattern = "(\.docm)$"      '   rename .docm files. Microsoft Word Open XML macro-enabled document.
    '       .Pattern = "(\.doc(m|x)?)$" '   rename .doc, .docm and .docx files.
    '       .Pattern = "(\.xlsm)$"      '   rename .xlsm files. Microsoft Excel Open XML macro-enabled workbook.
    '       .Pattern = "(\.xls(m|x)?)$" '   rename .xls, .xlsm and .xlsx files.
    '       .Pattern = "(\.html?)$"     '   rename both .htm and .html files.
    '                                   '   The "\." translate to a ".".
    '                                   '   The "?"  indicate preceding letter is optional.
    '                                   '   The "$"  indicate End-Of-String.
    strRegEx = "(\.html?)$|(\.doc(m|x)?)$|(\.xls(m|x)?)$"
    MailFile = CreateObject("Scripting.FileSystemObject").OpenTextFile(oMessage.FileName, 1).ReadAll
        .Global = True
        .MultiLine = True
        .IgnoreCase = True
        '   Run test.
        For i = 0 To oMessage.Attachments.Count-1
            .Pattern = strRegEx
            If .Test(oMessage.Attachments(i).Filename) Then
                EventLog.Write("Attachement will be renamed for " & oMessage.To & ": " & oMessage.Attachments(i).Filename)
                strFile    = "name=" & Chr(34) & oMessage.Attachments(i).Filename & Chr(34)
                strNewFile = "name=" & Chr(34) & oMessage.Attachments(i).Filename & ".WARNING" & Chr(34)
                .Pattern = strFile
                '   Rename all ocurrences of oMessage.Attachments(i).Filename in the file.
                MailFile = .Replace(MailFile, strNewFile)
                '   Flag that we need to save the message later
                bSave = True
    If bSave Then
        CreateObject("Scripting.FileSystemObject").OpenTextFile(oMessage.FileName, 2).Write(MailFile)
        oMessage.RefreshContent
        If bAddWarning Then oMessage.Attachments.Add(strWarning)
    Set oFSO = Nothing
Well... The warning is attached but the renamed attachments disappear into thin air...
Am I missing something fundamental ?
Post by RvdH » 2019-07-11 12:49
2019-07-10 22:23
*.21 pushed to github
How do you attach the files? Simply in Outlook?
Is the Mimepart order always the same? Can you supply a complete copy of scripts, rules and archives? Send me a pm if you wish...
Post by SorenR » 2019-07-11 13:51
2019-07-11 12:49
2019-07-10 22:23
Using my trusted Outlook 2003 (modified to allow blocked extensions) and from my GMail. It does not matter if I send as Plain text, Rich text or HTML.
Complete script in previous post.
Rule is simple: Account Postmaster, account rule: if subject = "*WARNING*" then run "WarningAttachments"
Repeating the test is done by forwarding the same mail from my Sent Mail folder.
Content of the .htm and .html files:
<%@LANGUAGE="VBSCRIPT" CODEPAGE="65001"%>
Private Sub testEmail( emailto )
    Dim oMatch, oMatches
        .Pattern = "(([a-zA-Z0-9_\-\.]+)\@([a-zA-Z0-9_\-\.]+)\.([a-zA-Z]{2,5}))"
        .Global = True
        .MultiLine = True
        .IgnoreCase = True
        Set oMatches = .Execute(emailto)
    emailto = ""
    For Each oMatch In oMatches
        emailto = oMatch & ";" & emailto
    With CreateObject("CDO.Message")
        .Configuration.Fields.Item(             "http://schemas.microsoft.com/cdo/configuration/sendusing" ) = 2
        .Configuration.Fields.Item(            "http://schemas.microsoft.com/cdo/configuration/smtpserver" ) = "localhost"
        .Configuration.Fields.Item(        "http://schemas.microsoft.com/cdo/configuration/smtpserverport" ) = 25
        .Configuration.Fields.Item(      "http://schemas.microsoft.com/cdo/configuration/smtpauthenticate" ) = 0
        .Configuration.Fields.Item(               "http://schemas.microsoft.com/cdo/configuration/sendtls" ) = False
        .Configuration.Fields.Item(            "http://schemas.microsoft.com/cdo/configuration/smtpusessl" ) = False
        .Configuration.Fields.Item( "http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout" ) = 10
        .Configuration.Fields.Item(          "http://schemas.microsoft.com/cdo/configuration/sendusername" ) = "user@domain.tld"
        .Configuration.Fields.Item(          "http://schemas.microsoft.com/cdo/configuration/sendpassword" ) = "password"
        .Configuration.Fields.Update
        .Subject = "Test subject"
        .From = "user@domin.tld"
        .To = emailto
        .TextBody = "Test body"
        .Send
    WScript.Echo( "eMail(s) sent to " & emailto & " at " & Now() )
Call testEmail(Request.QueryString( "emailto") )
Yeah, I copied an old test file from another project :mrgreen:
The other issue where I clone a message to forward blocked extensions to Postmaster, I call "oMessage.Attachment.Clear" and oMessage.Attachment.Count = 0. I then re-attach the .ps1 and .vbs files ... I end up with an extra .txt file ... Where did that one come from ? And where do the .html file go suddenly so it eludes being deleted and gets re-attached ... I'm inclined to call them X-Files :wink:
Thanks for the update on Github... I'll go figure out how to get this Github thing to work with my VS :mrgreen:
BTW... The Outlook thing... (11.0 = Office 2003, change as needed, restart Outlook)
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Office\11.0\Outlook\Security]
"Level1Remove"=".vbs;.ps1;.asp"
Post by RvdH » 2019-07-13 12:01
jimimaseye , can you remove the off-topic posts?
I can't remove a attachement in the forum once a topic can't be edited, right? I found a (tiny) bug in my above ZipScanner attachement
Post by RvdH » 2019-07-13 12:10
ZipScanner Options:
Return value: 2
When you click "Test" it will return 10, this is absolutely fine as the test message doesn't contain valid MIME parts
(source included)
ZipScanner.zip
(418.86 KiB) Downloaded 104 times
Post by jimimaseye » 2019-07-14 00:18
2019-07-13 12:01
I've removed the attachment. Please check. ( If there is any other then post the link to the exact post please. )
