Word Search
bcpaul
Word Search
Post by bcpaul » 2016-01-26 00:49
Based on
Word Filter - V.2.5 by Kids SafeGuard
Forum Link: viewtopic.php?f=14&t=4317
This script will search all incoming/outgoing emails for flagged words from a text file. The text file is located in the same folder as the script - C:\Program Files (x86)\hMailServer\Events\filter.csv
The script below is inserted into the events.vbs file: Find the Sub OnDeliverMessage(oMessage) in C:\Program Files (x86)\hMailServer\Events\EventHandlers.vbs and replace it with the code below
If the word is found, a copy is sent to another email account (just for this use) with the found word, from, to in the subject (all recipients). Maybe create an account called found@yourdomain.com. Just don't use it to send emails from.
NOTE: csv file format is as follows:
word or phrase to search,1
OR
word or phrase to search,0
However, the number is ignored--for now :)
The word searched for in the email MUST have a space on either side of the word, or it will not trigger a find.
This version works with hmailserver 5.6.4 on Windows using IIS
	Dim Location
	Location = "C:\Program Files (x86)\hMailServer\Events\filter.csv"
	Dim objFSO
	Dim objTextFile
	Dim strWords,i
	Dim restrict
	dim nMessage
	Set nMessage = CreateObject("hMailServer.Message")
	Set objTextFile = objFSO.OpenTextFile(Location, 1)
	Do While objTextFile.AtEndOfStream <> True
		strWords = split(objTextFile.Readline, ",")
		restrict = strWords(1)
		strBadWord = " " & strWords(0) & " "
		'strBadWord = strWords(0)
		'EventLog.Write("TESTING for" & content)  ' LOG IN hmailserver/
		' *** IMPORTANT !!! make sure the FromAddress is not and cannot be used to SEND any emails or hmailserver will be stuck in infinite loop of sending emails
		if InStr(1,oMessage.HTMLBody,strBadWord, 1) > 0 and oMessage.FromAddress <> "found@yourdomain.com" then
			'-- Get hMailServer to output the *real* mailboxes it detected. --'
			Dim LoopCount
			Dim Recipients
			For LoopCount = 0 To oMessage.Recipients.Count-1
			Recipients = Recipients & " TO: " & oMessage.Recipients(LoopCount).Address '& " (To: " & oMessage.Recipients(LoopCount).OriginalAddress & ")"
			'Message.HTMLBody + "<br>"
			nMessage.HTMLBody = oMessage.HTMLBody
			nMessage.From = "Email Scanner"
			nMessage.FromAddress = "no-reply@yourdomain.com"
			nMessage.Subject = "Flagged Word:" &strBadWord & " Sent from:" & oMessage.FromAddress & Recipients
			nMessage.ClearRecipients()
			nMessage.AddRecipient "Name", "found@yourdomain.com"  ' address of emails that have matched words get sent to
			nMessage.Save()
			Exit Do
	Loop
	oMessage.Save()
Re: Word Search
Post by jimimaseye » 2016-01-26 13:03
bcpaul wrote:The word searched for in the email MUST have a space on either side of the word, or it will not trigger a find.
So if my blocked word is "shit" and email comes in with "This is shit!", then it wont get caught?!
A fundamental flaw I think. As most words are nouns they are VERY likely to be at the end of sentences and therefore punctuated without a trailing space.
Out of interest, what does your script offer that the original script doesnt?
EDIT: see my proposed changes to the original script to tackle the flaw : viewtopic.php?p=182419#p182419
bcpaul
Re: Word Search
Post by bcpaul » 2016-01-28 01:01
lol, yes flawed. Not at all familiar with VB. Thanks. Would be nice to be able to edit my own post....
Re: Word Search
Post by mattg » 2016-01-28 02:46
bcpaul wrote: Would be nice to be able to edit my own post....
Can only do within 30 minutes, if no replies have been made I believe
This is done to stop complete re-writes of posts after they have been answered...thus making the answers provided not relate to the new question.
Re: Word Search
Post by jimimaseye » 2016-01-28 10:46
If you want to repost an updated solution then just do another post to the thread in completeness.
Also, I note another problem in your script: you only check HTMLbody. That assume emails being sent in to you have HTMLbodys. What if the incoming message is in plain text format only? (answer: it wont get caught.)
