When working with the Live Log function, it is extremely annoying if, for example, the webmailer or your own client crumbles the LOG. Then you often overlook things that you are waiting for.
Would it be possible somehow to exclude localhost (127.0.0.1) and possibly one or more IP addresses from logging?
Status/Logging: Filter out localhost and some others?
Re: Status/Logging: Filter out localhost and some others?
Try running your log through this: https://log.damnation.org.uk/
... ty for that ... Looks good ... But isn't a live view
My question was about the LiveView built into HMS. This is often very useful to follow in near real time what is happening and what is not working, e.g. if a client is sporadically unable to log in.
- Senior user
If you right-click on an entry in the live view it will filter that session only.
... uhhh! That I have'nt know before... Thanx... That I will try ...
use Snaketail, colorize what you want as you like.
http://snakenest.com/2014/snaketail-ver-1-9-released/
HMS 5.7, MariaDB 10.4.10, SA 4.0.0, ClamAV 0.103.8
- jimimaseye
- Moderator
There is also a vbscript here on the forum that does the same thing (real-time update). You can use that to react to different custom conditions if you wish.mattg wrote: ↑2021-10-20 01:17I use BareTail
https://www.baremetalsoft.com/baretail/
i also write lots of custom logs
... ty all. I'll check out all of the suggestions
