Strip the IP and (host-)name of the original sender
Bob.Dig
Post by Bob.Dig » 2020-10-04 14:44
Like described viewtopic.php?f=7&t=35385, other servers have an option to strip above mentioned personal data from emails they send. This would be a nice option to have in hmailserver too.
Re: Strip the IP and (host-)name of the original sender
Post by mattg » 2020-10-05 01:25
Can you name the other servers that do this...
Post by RvdH » 2020-10-07 08:47
https://www.hmailserver.com/forum/viewtopic.php?t=18467
' Strips out private IP addresses from Received header
' if the client's IP address is in 172.16.0.0/16
 ' Check client's IP address
 if Left(oClient.IPAddress, 7) = "172.16." Then
   Dim oHeaders
   set oHeaders = oMessage.Headers
   ' Iterate over the headers looking for Received:
   Dim i
   For i = oHeaders.Count -1 To 0 Step -1
      dim oHeader
      Set oHeader =oHeaders.Item(i)
      ' Check if this is a header which we should modify.
      if LCase(oHeader.Name) = "received" Then
         ' Log the header value in case we need it later on
         EventLog.Write("Pre-anonymisation: " + oHeader.Value)
         ' Set up the regex
         Dim myRegExp
         Set myRegExp = New RegExp
         myRegExp.Global = False
	 myRegExp.Pattern = "\bfrom[\-\sA-Za-z0-9\.\]\[\(\)]*by mail.example.com\b"
         ' Do the replacement
	 oHeader.Value = myRegExp.Replace( oHeader.Value, "from mailclient by mail.example.com" )
         ' Dump the modified header
         EventLog.Write("Post-anonymisation: " + oHeader.Value)
   ' Save all the changes...
Post by jimimaseye » 2020-10-07 09:23
That will also strip the local received headers of inbound external mail too. A condition would be required to check it's outbound email.
Bob.Dig
Post by Bob.Dig » 2020-10-07 10:03
And also it should work for non-local users too. I don't rely on it in any way. I think it is just a good, somewhat privacy focused, feature, witch is missing in that great peace of software, that other servers offer, which I can't name, because I don't know stuff.
But thinking of it more, I don't run any scripts, so I probably won't that one ether. It would be nice to have it truly integrated, but if not, please don't write scripts just for me. I gave my PC a reasonable name already. :D
Post by mattg » 2020-10-07 11:04
I think that the last thing that hMailserver does for mail that is Local >> (local |External) is add the received from header
even after all rules and scripts are run
i think that script will ONLY impact on incoming mail
