As Far as I know, there is no backup progress indicator.
The tab is a bit confusing.
When I clicked Start it appeared to me that nothing had happened.
I then clicked Save and the button greyed out and stayed greyed out and nothing happened.
I then clicked Start again and nothing appeared to happen.
I then clicked on Show Log and it had an error that backup had already started.
Not sure that it had gone right I started all over.
Also, add what file it is being saved as. Took me a few minutes to figure that out.
Whew! Please advise. Thanks.
Add Backup Progress Indicator
Re: Add Backup Progress Indicator
yep
I DID use a tails program (baretail) to watch the backup log when I was using internal backups
