I guess the subject explains it.
I'd like to see a spot to add a list of (incoming) email addresses on the Domains->domain name--> advanced tab. Since the list will be only for the domain and the domain may also have aliases perhaps the list would just be the portion of the email address left of the @ sign (not the domain names)
The section could be called "Reject email addresses"
Under the catch-all address settings (under greylisting checkbox) I'd like to be able to add, change, delete this list of emails.
If an email address is on the list whenever that email address arrives instead of going into the catch-all that address would receive back either a 541, 550 during "rcpt to:" in the smtp negotiation.
On that same screen the rejection message could default to 541 or 550, but i'd also like to be also have a place to chose what message gets returned (maybe a choice of numbers, or even be able to add my own)
Rejection list of email address for a domain set as catch-all
- jimimaseye
- Moderator
Re: Rejection list of email address for a domain set as catch-all
You might like this: https://www.hmailserver.com/forum/viewt ... 20&t=29306
Does your required list of addresses mean senders address (ie FROM)?
So why use a catch-all?
It seems like you want to selectively accept or reject mail
You could (should) do this with a script I reckon
- jimimaseye
- Moderator
HelloSent: Sun May 10, 2020 4:16 am
by p007138b
On-the-fly Disposable/Catchall Addresses with Blacklisting is exactly what i am trying to accomplish.
I am using the catch-all address on the advanced tab to send all email to the domain to one address. I have been setting up emails with different companies. I.E. hmailserver@mydomain.com for the registration here on this forum.
I tried to configure it based on what you described on the posting, but nothing comes through except the main account i have set up as the "catch-all"
when i telnet to the server and attempt to do mail from: and rept to: when i put the address which should go into the catch-all i get "451 Please try again later"
On the distribution list i have announcements only selected and the catch-all address i want to use
under the routing tab, does it matter what port is used?
under the routing tab are the bottom two "when sender matches route, and when recipient matches route" left as default?
below is what i have for the eventhandlers.vbs fileCode: Select all
' Sub OnClientConnect(oClient) ' End Sub Sub OnSMTPData(oClient, oMessage) DisposableBlackList(oMessage) End Sub ' Sub OnAcceptMessage(oClient, oMessage) ' End Sub Sub OnDeliveryStart(oMessage) DisposableBlackList(oMessage) End Sub ' Sub OnDeliverMessage(oMessage) ' End Sub ' Sub OnBackupFailed(sReason) ' End Sub ' Sub OnBackupCompleted() ' End Sub ' Sub OnError(iSeverity, iCode, sSource, sDescription) ' End Sub ' Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage) ' End Sub ' Sub OnExternalAccountDownload(oFetchAccount, oMessage, sRemoteUID) ' End Sub Function DisposableBlackList(oMessage) Dim k, i, j, D, A, R, E, aUsername, oApp, oDomain, oDistributionList, cBlacklisted, DomainFound, RecipientDomain, DisposableBLExists Set oApp = CreateObject("hMailServer.Application") Call oApp.Authenticate("Administrator", "myhmailserverpassword") R = oMessage.recipients.count E = 0 For j = 0 To R -1 If oMessage.Recipients(j).IsLocalUser = false Then aUsername = Split(oMessage.Recipients(j).Address,"@") DomainFound = 0 RecipientDomain = lcase(aUsername(1)) For D = 0 to oApp.Domains.count-1 For A = 0 To oApp.Domains.item(D).DomainAliases.Count -1 If lcase(oApp.Domains.item(D).DomainAliases.Item(A).Aliasname) = RecipientDomain Then RecipientDomain = lcase(oApp.Domains.Item(D).name) End if Next if lcase(oApp.Domains.item(D).name) = RecipientDomain then DomainFound = 1 Set oDomain = oApp.Domains.ItemByName(RecipientDomain) DisposableBLExists = 0 For k = 0 To oDomain.DistributionLists.Count -1 If lcase(oDomain.DistributionLists.Item(k).Address) = lcase("DisposableBlacklist@" & RecipientDomain) Then Set oDistributionList = oDomain.DistributionLists.Item(k) if oDistributionList.Active and not oDistributionList.RequireSenderAddress = "" then DisposableBLExists = 1 cBlacklisted = 0 For i = 0 To oDistributionList.Recipients.Count -1 If lcase(oDistributionList.Recipients.Item(i).RecipientAddress) = lcase(replace(oMessage.Recipients(j).Address,aUsername(1),RecipientDomain)) Then Result.Value = 1 cBlacklisted = 1 R=R-1 eventlog.write(now() & " SMTP - CATCHALL BLACKLIST mail blocked to " & oMessage.recipients.item(j).address & " from " & oMessage.fromaddress ) End If Next if cBlacklisted = 0 then ReDim preserve RecordedRecipients(E) RecordedRecipients(E) = oDistributionList.RequireSenderAddress E=E+1 End If else DisposableBLExists = 0 End If End If Next If DisposableBLExists = 0 then ReDim preserve RecordedRecipients(E) RecordedRecipients(E) = oMessage.recipients.item(j).address E=E+1 End if End If Next if DomainFound = 0 then ReDim preserve RecordedRecipients(E) RecordedRecipients(E) = oMessage.recipients.item(j).address E=E+1 End if Else ReDim preserve RecordedRecipients(E) RecordedRecipients(E) = oMessage.recipients.item(j).address E=E+1 End If Next if R > 0 then oMessage.clearRecipients For j = 0 to ubound(RecordedRecipients) oMessage.AddRecipient "", RecordedRecipients(j) Next End if End Function
I will address your email in steps:
1, You will always be better maintaining conversation in the forum (I have posted your PM to the thread and answering it here). Others can also answer and you will likely get a quicker response. (Avoid PM's unless it is personal details).
2,
The script as posted works. I advise to review carefully what is required in the instructions from 1 through to 3. It does say that all disposable address will be delivered to the main account that is defined as the catchall (1d) after which you can use rules to distribute to other 'real' accounts as required but you need it setting up as instructed (pay attention to disabling you current 'catchall' account (1g) and ensuring you setup up the distribution list (1b). Do not skip any steps).I tried to configure it based on what you described on the posting, but nothing comes through except the main account i have set up as the "catch-all"
3,
This is not related to my script but is more likely die to greylisting being enabled. Review your settings (or run https://www.hmailserver.com/forum/viewt ... 20&t=30914 so we can do it for you).when i telnet to the server and attempt to do mail from: and rept to: when i put the address which should go into the catch-all i get "451 Please try again later"
4,
No but you must have the domain name correct.under the routing tab, does it matter what port is used?
This is similar but not the same. The idea of my script means that you do not have to visit as Administrator and create every new account in HMS Admin prior to use and, instead, can simply quote the address as you wish. You only need to visit HMS Admin to add it to a block list if/when you want to disable it.Sent: Sun May 10, 2020 4:53 am
Recipient: jimimaseye
I think I may have found a different solution.
If i add the email I want rejected as an account on the domain and uncheck the enable checkbox, the server responds to the telnet with "550 Account is not active" for that email address.
