change Sender Address
Hello Guys,
my name is Timur from Germany. I have a problem with hmailserver and would appreciate, if someone could help me. In my Lan i have some smtp clients that dont support smtp auth. thats why i set up an hmailserver with smtp relayer and disables "requires smtp auth" in ip ranges settings.
as far as these smtp clients use the same sender address thats configured in my smtp relayer account everything works fine. lets call this Email address smtprelay@mydomain.com. Unfortunaltely i have some smtp client, that cannot use smtprelay@mydomain.com as the sender address.They have subdomain sender addresses, like server1@sub.mydomain.com. so i decided to replace the sender address by a rule. So i created:
criteria
from|contains|sub.mydomain.com
Actions
Set header value|from|smtprelay@mydomain.com
but its not working
how can i access the modified Email?
in hmailserver_awstats.log its trying to send with server1@sub.mydomain.com
in htmailserver log it says
"DEBUG" 4300 "2019-12-17 05:42:24.381" "Applying rules"
"DEBUG" 4300 "2019-12-17 05:42:24.381" "Applying rule Rewrite sender"
"DEBUG" 4300 "2019-12-17 05:42:24.381" "Performing rule action"
"DEBUG" 4300 "2019-12-17 05:42:24.381" "Performing local delivery"
"DEBUG" 4300 "2019-12-17 05:42:24.381" "Local delivery completed"
"SMTPC" 6828 73 "2019-12-17 05:47:57.958" "83.246.107.173" "RECEIVED: 354 Start mail input; end with <CRLF>.<CRLF>"
"SMTPC" 6828 73 "2019-12-17 05:47:57.958" "83.246.107.173" "SENT: [nl]."
"SMTPC" 4352 73 "2019-12-17 05:47:58.036" "83.246.107.173" "RECEIVED: 550 5.7.60 SMTP; Client does not have permissions to send as this sender"
"SMTPC" 4352 73 "2019-12-17 05:47:58.036" "83.246.107.173" "SENT: QUIT"
"SMTPC" 5296 73 "2019-12-17 05:47:58.067" "83.246.107.173" "RECEIVED: 221 2.0.0 Service closing transmission channel"
thanks for help
Timur
criteria
Actions
but its not working
thanks for help
Timur
Re: change Sender Address
Here is a script to do that
Add to your eventhandlers.vbs, and enable scripting in the admin gui
From this thread, kudos to @tunis
viewtopic.php?f=9&t=32387#p202248
if instr(oMessage.FromAddress,"sub.domain.com") >0 then
oldFrom = oMessage.FromAddress
oMessage.FromAddress = "new@example.com"
oMessage.From = "<new@example.com>"
EventLog.Write("Testing account From rewrite " & oldFrom & " - to - " & oMessage.FromAddress )
oMessage.save
Result.value = 0
end if
it worked like a charm. Thank you so much!!!
Hello MattG,
can i bother you once more.
is it possible to change the script to make it universal. What i mean is, i have different sender addresses, but they have the same pattern, for example: server1@sub.mydomain.com, server5@sub2.mydomain.com or server2@sub125.mydomain.com
the script should eliminate the part of the subdomain, regardless which value it has. So it should replace it with: server1@mydomain.com, server5@mydomain.com or server2@mydomain.com
Is this possible?
i would appreciate your help
thanks
Timur
Is this possible?
thanks
Timur
just change this line
to be like
if instr(oMessage.FromAddress,".domain.com") >0 then
And maybe even you can remove the leading . to just have "domain.com"
to be like
ok, but how do i pick the local Part of the Email address?
for example server5@sub2.mydomain.com and put it in
oMessage.From = "<server5@mydomain.com>"
left(oMessage.FromAddress, instr(oMessage.FromAddress, "@")-1)
I think the -1 is needed without testing, but it may not be.
Post your script as it stands if you are still stuck please
how can i add mydomain.com ?
this does not work:
oMessage.FromAddress = left(oMessage.FromAddress, instr(oMessage.FromAddress, "@") & "mydomain.com" )
this does not work:
Bracket is in the wrong place
oMessage.FromAddress = left(oMessage.FromAddress, instr(oMessage.FromAddress, "@")) & "mydomain.com"
it worked, thanks
Posted for anyone who might find this useful: to replace one domain with another. This also updates the Message ID value successfully.
Dim domainOld, domainNew
domainOld = "domain1.com"
domainNew = "domain2.com"
If (instr(oMessage.FromAddress, domainOld) > 0) Then
oMessage.FromAddress = Replace(oMessage.FromAddress, domainOld, domainNew)
oMessage.From = Replace(oMessage.From, domainOld, domainNew)
oMessage.HeaderValue("Message-ID") = Replace(oMessage.HeaderValue("Message-ID"), domainOld, domainNew)
'EventLog.Write("Testing account From rewrite " & oldFrom & " - to - " & oMessage.FromAddress & " ID:" & oMessage.HeaderValue("Message-ID") )
Result.value = 0
