Improved Auto-Ban
EduardoFoltran
Improved Auto-Ban
Post by EduardoFoltran » 2018-07-27 16:59
Hi!
I would like to suggest an implementation to improve the auto-ban security feature but first I believe it should be useful to put this proposal under context.
I had some users with a severe problem of spam. Despite my best effort, I could not make a sensible impact on the amount of spam these particular users received every day. The reason for that was clear to me. I am in Brazil and my users are Brazilian people who send and receive messages in Portuguese. The same is true for the Brazilian spammers. All spam originated in Brazil stay in Brazil. For that, they never reach spamtraps of the majors DNSBL services worldwide. The messages are schemes and advertisements targeted to Portuguese speakers. I looked for a DNSBL focused on Brazilian spam, but I found none. So I decided to create my own.
Since november 2017 I have been working in this DNSBL service. I establish 7 levels of “spamness” ranging from “whitelisted” to “drop-it-now”. For a while, I used real accounts of my users, witch volunteer for it, as spamtraps, implemented some algorithms to spot spammers and asked all others to mark as spam all undesired email they receive. In less than a month the impact was huge. I was able to reduce 60% of the spam and after 3 months I had group of very happy users congratulating me. Now I am not using any real account as spamtraps and I am setting proper spamtraps over the internet.
Having all that experience with the DNSBL and the spamtraps, I started to look more closely to the IPs that fell into the auto-ban feature of HMS. Most times I look, there is some IPs banned. I started to check those IPs on my DNSBL and they always fell in the “drop-it-now” level. That means, those IPs are spammers trying to kidnap some user account.
**The proposal**
With this background, I propose to implement some kind of auto-ban based on a DNSBL service. So, if a given IP is listed in a DNSBL list, there is no need to wait it fail login. It should be banned just for trying to login.
I believe it could work like this:
1- The “bad-guy” IP connects to HMS and receives the 220 salute, meanwhile, HMS starts to check its reputation on a DNSBL.
2- The “bad-guy” goes on with EHLO formalities.
3- If the “bad-guy” wants to deliver a message, going to the MAIL, RCPT, DATA path, treat it normally.
4- If the “bad-guy” ask for AUTH, close connection and ban it.
I hope you find this suggestion useful.
Eduardo
Re: Improved Auto-Ban
Post by SorenR » 2018-07-27 18:25
How's your vbs ??
   For i = 0 To 10
      If InStr(Message.HeaderValue("X-hMailServer-Reason-" & i), "RBL Rejection Message") Then
         Call AutoBan(oClient.IPAddress, "DNSBL - " & Message.HeaderValue("X-hMailServer-Reason-" & i), 7, "d")
I made this "StartUp" eventhandler some time back that should make the above possible. It will require a modified hmailserver.exe due to the OnHELO procedure
http://www.hmailserver.com/forum/viewto ... 20#p203420
Option Explicit
' COM authentication
Private Const PASSWORD = "########"
Function Wait(sec)
Function LockFile(strPath)
   Const Append = 8
   Const Unicode = -1
      Dim oFile, i
      For i = 0 To 30
         On Error Resume Next
         If Not (Err.Number = 70) Then
            Set LockFile = oFile
            On Error Goto 0
            Exit For
         On Error Goto 0
         Wait(1)
   If (Err.Number = 70) Then
      Err.Clear
   ElseIf (Err.Number <> 0) Then
      Err.Clear
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
      .Pattern = strRegEx
      .Global = bGlobal
      .MultiLine = True
      .IgnoreCase = True
' System Scripting Runtime COM object ("SScripting.IPNetwork")
' http://www.netal.com/ssr.htm
' Binary -> http://www.netal.com/software/ssr15.zip
' ALTERNATIVE: DNSBL      = sbl.spamhaus.org
'              ReturnCode = 127.0.0.3
'              Score      = 5
Function IsSnowShoe(strIP) : IsSnowShoe = False
   Dim a
   a = Split(strIP, ".")
      strIP = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".sbl.spamhaus.org")
   If (strIP = "127.0.0.3") Then IsSnowShoe = True
Function LongIntegerFromIP(p_strIP)
   Dim arrTemp, i, lngTemp
   arrTemp = Split(p_strIP, ".")
   For i = 0 To UBound(arrTemp)
      lngTemp = lngTemp + CLng(arrTemp(i)) * (256 ^ (3 - i))
   LongIntegerFromIP = lngTemp
Function isAutoBan(oMessage)
   Dim strRegEx, i, a, Match, Matches, m_strIP, m_strLowerIP, m_strUpperIP
   strRegEx = "(?:[0-9]{1,3}\.){3}[0-9]{1,3}"
      If oMessage.Headers(i).Name = "Received" Then
         If Lookup("by backup-mx.post.tele.dk", oMessage.Headers(i).Value) Then
            Set Matches = oLookup(strRegEx, oMessage.Headers(i).Value, False)
            If Matches.Count > 0 Then
               For Each Match In Matches
                  m_strIP = LongIntegerFromIP(Match.Value)
                  For a = 0 To oApp.Settings.SecurityRanges.Count-1
                     If (oApp.Settings.SecurityRanges.Item(a).Priority = 20) Then
                        m_strLowerIP = LongIntegerFromIP(oApp.Settings.SecurityRanges.Item(a).LowerIP)
                        m_strUpperIP = LongIntegerFromIP(oApp.Settings.SecurityRanges.Item(a).UpperIP)
                        If (m_strIP >= m_strLowerIP) And (m_strIP <= m_strUpperIP) Then
                           Result.Value = 2
                           Result.Message = "5.7.1 CODE08 The SMTP service on IP address (" & Match.Value & ") is not welcome here."
                           Exit Function
               Exit Function
'********** Subroutines        **********
Sub XEnvelope(oMessage)
   Dim i, strEnvelope1, strEnvelope2
      If (i = 0) Then
         strEnvelope1 = oMessage.Recipients(i).Address
         strEnvelope2 = oMessage.Recipients(i).OriginalAddress
         strEnvelope1 = strEnvelope1 & ", " & oMessage.Recipients(i).Address
         strEnvelope2 = strEnvelope2 & ", " & oMessage.Recipients(i).OriginalAddress
   oMessage.HeaderValue("X-Envelope-To") = strEnvelope1
   oMessage.HeaderValue("X-Envelope-OriginalTo") = strEnvelope2
' sType can be one of the following;
' "yyyy" Year, "m" Month, "d" Day, "h" Hour, "n" Minute, "s" Second
            .LowerIP = sIPAddress
            .UpperIP = sIPAddress
            .Priority = 20
            .Expires = True
            .Save
      On Error Goto 0
      .Close
Sub SPAMList(oMessage, strMatch)
   Dim i
   If (oMessage.HeaderValue("X-hMailServer-Spam") = "YES") Then
      i = CInt(oMessage.HeaderValue("X-hMailServer-Reason-Score"))
      i = 0
   oMessage.HeaderValue("X-hMailServer-Reason-0") = "SPAMlisted - (Score: 5)"
   oMessage.HeaderValue("X-hMailServer-Reason-Score") = 5 + i
   oMessage.HeaderValue("X-Blacklist-RegEx") = strMatch
Sub WhiteList(oMessage, strMatch)
   Dim i
      ' oMessage.Headers.ItemByName("X-hMailServer-Spam").Delete
      oMessage.HeaderValue("X-Whitelist-RegEx") = strMatch
      oMessage.HeaderValue("X-hMailServer-Spam") = "NO"
      oMessage.HeaderValue("X-hMailServer-Reason-Score") = i * -1
Sub OnClientConnect(oClient)
   ' Exclude Backup-MX & local LAN from test
   If (Left(oClient.IPAddress, 10) = "80.160.77.") Then Exit Sub
   ' Filter out "impatient" servers. Alternative to GreyListing.
Sub OnHELO(oClient)
   Dim strRegEx, Match, Matches
   ' SnowShoe SPAM detection
      Result.Value = 2
      Result.Message = "5.7.1 CODE01 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Call AutoBan(oClient.IPAddress, "SNOWSHOE - " & oClient.HELO, 7, "d")
      Exit Sub
   ' Deny servers with specific HELO/EHLO greetings
   strRegEx = "^(\[87\.51\.72\.165\])$|" &_
              "^(mydomain\.tld)$|" &_
              "^(mx\.mydomain\.tld)$|" &_
              "^(.*\.[a-z]{4,})$|" &_
              "(0\.0\.0\.0)|" &_
              "(127(?:\.[0-9]{1,3}){3})"
         Result.Value = 2
         Result.Message = "5.7.1 CODE02 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means. {" & Match.Value & "}"
         Call AutoBan(oClient.IPAddress, "BLACKLIST - " & oClient.HELO, 7, "d")
         Exit Sub
   ' Validate HELO/EHLO greeting
   Const myKnown = "^(LouisesPC)$|^(LouisesHuawei)$"
   strRegEx = strFQDN & "|" & strIPv4 & "|" & strIPv6 & "|" & myKnown
      Result.Value = 2
      Result.Message = "5.7.1 CODE03 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Call AutoBan(oClient.IPAddress, "Bad HELO - " & oClient.HELO, 7, "d")
      Exit Sub
'  ********** SPAM test: DNSBlackLists, HeloHost, MXRecords, SPF
'  ********** SPAM test: SURBL, DKIM, SpamAssassin
   Dim i, a, strRegEx, Match, Matches
   ' Exclude authenticated users test
   If (oClient.Username <> "") Then Exit Sub
   ' Banned sender via Backup-MX ?
   If (Left(oClient.IPAddress, 10) = "80.160.77.") Then Call isAutoBan(oMessage)
   ' Reject "X-Envelope-From:"
   strRegEx = "(\@dcs-dz\.com)$|" &_
              "(\@danmarkmail\.com)$|" &_
              "(\@epsp-telagh\.com)$|" &_
              "(\@vrshoesale\.com)$|" &_
              "(\.bid)$|(\.kim)$|(\.men)$|(\.top)$|(\.win)$|(\.xyz)$|(\.zip)$"
   Set Matches = oLookup(strRegEx, oMessage.FromAddress, False)
         Result.Value = 2
         Result.Message = "5.7.1 CODE04 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means. {" & Match.Value & "}"
         Exit Sub
   ' Reject "From:"
   strRegEx = "(Sweetme)|(Kira Johns)|(July Girl)|(Hot Mama)|(Little Miss)|" &_
              "(Baby Boobs)|(Booby Girl)|(Booby Booms)|(aylinhansen)|" &_
              "(\.bid)$|(\.kim)$|(\.men)$|(\.top)$|(\.win)$|(\.xyz)$|(\.zip)$|" &_
              "(\.bid\>)$|(\.kim\>)$|(\.men\>)$|(\.top\>)$|(\.win\>)$|(\.xyz\>)$|(\.zip\>)$"
   Set Matches = oLookup(strRegEx, oMessage.From, False)
         Result.Value = 2
         Result.Message = "5.7.1 CODE05 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means. {" & Match.Value & "}"
         Exit Sub
   ' Reject "Subject:"
   strRegEx = "^(yo|hi|sup|hello|greets|hey t?here)(!?)(.?)(8?-?\)?)?$"
   If (oMessage.HeaderValue("X-Blacklist-RegEx") = "") Then
      Set Matches = oLookup(strRegEx, oMessage.Subject, False)
            Result.Value = 2
            Result.Message = "5.7.1 CODE06 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means. {" & Match.Value & "}"
            Exit Sub
   ' Reject "Body:"
   strRegEx = "(\.xyz\/)|(thisemailwillchangeyourlife)|(Please sign the contract)"
   If Lookup(strRegEx, oMessage.Body) Or Lookup(strRegEx, oMessage.HTMLBody) Then
      Result.Value = 2
      Result.Message = "5.7.1 CODE07 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Exit Sub
   ' Additional SPAM processing
   If oMessage.HeaderValue("X-hMailServer-Spam") <> "YES" Then
      ' Blacklist IP Range
      ' http://www.analyticsmarket.com/freetools/ipregex
      ' 216.82.240.0 - 216.82.255.255 = MessageLabs Inc. (Symantec Inc.)
      ' ^216\.82\.(2(4[0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$
      ' strRegEx = "^216\.82\.(2(4[0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$"
      ' Set Matches = oLookup(strRegEx, oClient.IPAddress, False)
      ' If Matches.Count > 0 Then
      '    For Each Match In Matches
      '       Call SPAMList(oMessage, "BlackList oClient.IPAddress: Value '" & Match.Value & "'")
      '    Next
      ' End If
      ' Blacklist "X-Envelope-From:"
         strRegEx = "^(job\@.*)$|" &_
                    "^(.*\@.*\.[a-z]{4,})$"
               Call SPAMList(oMessage, "BlackList oMessage.FromAddress: Value '" & Match.Value & "'")
      ' Blacklist "From:"
         strRegEx = "(\<.*\@.*\.[a-z]{4,}\>)"
               Call SPAMList(oMessage, "BlackList oMessage.From: Value '" & Match.Value & "'")
      ' Blacklist "Subject:"
         strRegEx = "(Fakta Gavekort)|" &_
                    "(Vi inviterer dig til at tilslutte dig)|(Dette er ikke en reklame)|" &_
                    "(Blockchain-momentum)|" &_
                    "(du vil finde rigtig meget brugbar information herinde)|" &_
                    "(ringede til dig, men du tog den ikke)|" &_
                    "(Noget helt fantastisk er ved at ske)|" &_
                    "(iPhone (3G|4|5|6|SE|7|8|9|X)(C|S)?( Plus)?)"
               Call SPAMList(oMessage, "BlackList oMessage.Subject: Value '" & Match.Value & "'")
      ' Blacklist Body
         strRegEx = "(Du har fået denne mail tilsendt angående et jobtilbud)|" &_
                    "(Vi har registreret, at du har et overskydende)|" &_
                    "(I øjeblikket tildeler vi alle nyopstartede brugere)|" &_
                    "(Din konto er i risiko for at blive suspenderet)|" &_
                    "(Vi leder efter en ny person)|" &_
                    "(Leo Vegas er)|(velkomstbonus til din)|" &_
                    "(beskytte dit kort mod svig)|(I have a proposal)|" &_
                    "(You are receiving this email because you opted in via our website)|" &_
         Set Matches = oLookup(strRegEx, oMessage.Body, False)
               Call SPAMList(oMessage, "BlackList oMessage.Body: Value '" & Match.Value & "'")
            Dim strHTMLBody : strHTMLBody = oMessage.HTMLBody
            ' <!-- ... -->   PHP: "<!--[^>]*-->"        JavaScript: "<!--[\s\S]*?-->"
            ' /*   ...  */   PHP: "(\/\*)[^>]*(\*\/)"   JavaScript: "(\/\*)[\s\S]*?(\*\/)"
            ' With CreateObject("VBScript.RegExp")
            '    .Pattern = "<!--[\\s\\S]*?(?:-->)?<!---+>?|<!(?![dD][oO][cC][tT][yY][pP][eE]|\\[CDATA\\])[^>]*>?|<[?][^>]*>?"
            '    .Global = True
            '    .MultiLine = True
            '    .IgnoreCase = True
            '    strHTMLBody = .Replace(strHTMLBody, "")
            ' End With
            ' My.WriteLog( Len(strHTMLBody) & " : oMessage.HTMLBody (FLT1) : " & strHTMLBody )
               .Pattern = "(\/\*)[\s\S]*?(\*\/)"
               .Global = True
               .MultiLine = True
               .IgnoreCase = True
            Set Matches = oLookup(strRegEx, strHTMLBody, False)
                  Call SPAMList(oMessage, "BlackList oMessage.HTMLBody: Value '" & Match.Value & "'")
   ' Whitelist senders Eg. notification+m5kkb25r@facebookmail.com
      ' Whitelist "X-Envelope-From:"
      strRegEx = "^(notification\+)[a-z,0-9,_]{8}(\@facebookmail\.com)$|" &_
                 "^(security\@facebookmail\.com)$|" &_
                 "^(bounces\+3390280\-2e2e\-soren\=mydomain\.tld\@mail\.computerworld\.dk)$|" &_
                 "^(bounce-mc.us1_498933.[0-9]{7}-jane=mydomain.tld@mail[0-9]{1,3})|" &_
                 "^(transaction\@notice\.aliexpress\.com)$|" &_
                 "^(noreply\@compugroupmedical\.dk)$|" &_
                 "^(metin\@srv\.eatonline\.dk)$|" &_
                 "^(mobilprivat\@telia\.dk)$|" &_
                 "^(no-reply\@telia\.crm-ts\.com)$|" &_
                 "^(bounce\@gjensidige\.no)$|" &_
                 "^(info\@billigvvs\.dk)$|" &_
                 "(\@hk\.dk)$|" &_
                 "(\@cirkusrevyen\.dk)$|" &_
                 "(\@bounce\.kundemail\.power\.dk)$|" &_
                 "(\@(email|insideapple)\.apple\.com)$"
            Call WhiteList(oMessage, "WhiteList oMessage.FromAddress: Value '" & Match.Value & "'")
      ' Whitelist "From:"
         strRegEx = "^(Goodreads <no-reply\@mail\.goodreads\.com>)$|" &_
                    "^(EasyPark <no-reply\@easypark\.net>)$|" &_
                    "(support\@patchingprotocol\.com)|" &_
                    "(account-update\@amazon\.com)|" &_
                    "(no_reply\@snapchat\.com)|" &_
                    "(no-reply\@myunidays\.com)|" &_
                    "(noreply\@sundhedsjobs\.dk)|" &_
                    "(\@bloderforeningen\.dk)|" &_
                    "(\@yousee\.dk)|" &_
                    "(\@id\.apple\.com)|" &_
                    "(\@seas-nve\.dk)"
               Call WhiteList(oMessage, "WhiteList oMessage.From: Value '" & Match.Value & "'")
   ' Add X-Envelope... headers
   Call XEnvelope(oMessage)
'  ********** Saving EML to DATA
'  Sub OnDeliveryStart(oMessage)
'  End Sub
'  ********** Antivirus check, Global rules
'  Sub OnDeliverMessage(oMessage)
'  End Sub
'  ********** Local rules, Message delivered to recipient(s)
'  Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
'  End Sub
'  Sub OnExternalAccountDownload(oFetchAccount, oMessage, sRemoteUID)
'  End Sub
'  Sub OnBackupFailed(sReason)
'  End Sub
'  Sub OnBackupCompleted()
'  End Sub
'  Sub OnError(iSeverity, iCode, sSource, sDescription)
'  End Sub
Post by mattg » 2018-07-27 22:33
Good idea Eduardo
As SorenR says, using a build that includes OnHelo much of this is possible
http://www.hmailserver.com/forum/viewto ... 60#p201392 is a link to one such build
ALSO, in your hmailserver.ini you can stop AUTH for certain ports. Many of us block AUTH on port 25 using this.
IN my case, using RvdH's build linked above, and SorenR's Autoban scripts, I autoban the following
- Spam scores over 15 - get one high spam score, and BAM no more messages for a few weeks
- RvdH's build also has an 'OnClientLogon', where I catch those trying to connect from another country on IMAP and POP3 ports - these aren't normally Autobanned by hmailserver as only SMTP Is autobanned by hMailserver. I'm in Australia, international is pretty definitive here.
- I have some non-standard ports. Any use of these with a failed logon gets autobanned
- Using SorenR's scripts I check for known EHLO responses for spammers, and Autoban the IP. This includes those who respond to EHLO with my public IP address.
- I also automatically check my logs every few minutes for things like those who TRY to AUTH on port 25 and are rejected, they too get added to my Autoban list
My autoban list has been sitting consistently at around the 90 to 100 entries since before the world cup started, but a few times reached into the hundreds. I now keep stats of my autoban list at the end of every day.
And just checking my stats, I don't have any bans from foreign IP addresses for over a month. I'll have to check that my script is still working...
EduardoFoltran
Post by EduardoFoltran » 2018-07-30 19:49
Hi Mattg and SorenR
Thanks for the feedback! I blocked login from port 25 and it indeed had an impact on auto-ban.
I am studying SorenR’s script to see if I can do something without the OnHelo event. I am using Matin’s compilation and I am not planning to change it in a near future. I believe such event should be on the main compilation as well. It opens some interesting possibilities.
I realize that there is a lot of stuff one can do with a list of banned IPs. For example, I figured out how ZeroBounce checks email addresses. They use several fake servers that pretend to send an email in order to check if the address exists or not. I am trying some addresses on their free test just to collect information. The domains they use always go to a website of a company of some kind that looks like a legitimate business, but digging deeper, one can see they are not real.
A list of IPs of such services should be permanently banned!
Thanks again!
Eduardo
